Re: telescoping arm
Re: telescoping arm
Maybe a totally inovative method is required , we have a secret method that might stun you at its simplicity
How about the parraleelagram method? |
Re: telescoping arm
This is a perfectly viable solution to a "tall arm". For some prime examples of 4-bar linkage systems check out the robots from 1997, 1998. 4-bar linkages also made appearances last season as well (25, 461, 233, others) Check this one out: http://www.firstrobotics.net/03galle...0513-1_jpg.htm John |
Re: telescoping arm
I was just thinking about how to extend a telescoping arm, and it just came to me!
last year teams built arms that they wanted to extend in auton mode to hit the wall quickly but this year, the arms would be for manipulating the 2X ball, or hooking the bar but they dont need to extend by themselves how do you extend the telescoping antenna on a portable radio or TV? (you PULL it out, and it stays there) all you need to do is design a telescoping arm that locks when extended and to extend it, hook the end on the lip of the mobile goal, or on your alliace bot (or anywhere else you are allowed to grab something on the field) and then backup your bot to pull the arm all the way out. I dont think it could be any simplier than that! :c) |
Re: telescoping arm
Re: telescoping arm
I don't know if this helps but this is the way we did it for three years 2000, 2001, and 2002 this is the 2002 one inch version, It drives whith chain or cable. and except for 2000 (cable) it is very reliable and compact. Last edited by D.Fahringer : 17-01-2004 at 20:20. |
| Reflected Inertia? | archiver | 2001 | 9 | 24-06-2002 03:50 |
| anyone use an arm to help balance | archiver | 2001 | 8 | 24-06-2002 02:46 |
| Controlling Arm travel - Limit Switch or Mechanical Stop? | archiver | 2001 | 8 | 23-06-2002 23:55 |
| telescoping arm & ten second rule | Ben Mitchell | Rules/Strategy | 4 | 18-02-2002 21:37 |
| Robot Controller arm | David Kelly | Technical Discussion | 0 | 28-06-2001 16:37 |
