Go to Post Thank you lord I knew there was a reason I got 10 books on autonomous robotics. - Adam Y. [more]
Unread 13-01-2004, 00:42
Jeff Sharpe Jeff Sharpe is offline
#0473 (Montana State Robotics)
Jeff Sharpe is on a distinguished road
Cool Rule <G05> vertical pipe structure?
Has the configuration of the vertical pipe structure surrounding the ball tees been released? I'm wondering how much room we have to reach behind the bonus balls without losing 25 pts.
Unread 13-01-2004, 00:52
KenWittlief KenWittlief is offline
KenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond repute
Re: Rule <G05> vertical pipe structure?
I believe you can reach off the field as far as you want (as long as you dont touch the foor or the spectators in the stands :c)
The only restiction I see in the rules is you have to reach through the pipe openings, not around them.
Unread 16-01-2004, 23:37
TomWx's Avatar
TomWx TomWx is offline
AKA: Tom Wexler
FRC #0708 (Hatters Robotics)
Rookie Year: 2000
TomWx is a splendid one to beholdTomWx is a splendid one to beholdTomWx is a splendid one to beholdTomWx is a splendid one to beholdTomWx is a splendid one to beholdTomWx is a splendid one to behold
Send a message via AIM to TomWx
More than likely, this will be a referee call. Q&A has clarified that while a robot may expand outside of the imediate tee area, it still must be safe, or your robot will be shut down for safety, since I'm certain there will be people walking within feet of the tee areas.
Tom Wexler
FIRST Volunteer Coordinator, SCH District and Championship - Newton Field
Mentor, Team 708 Hatters Robotics
