Go to Post Education is important, but for some, FIRST is their education. - Sam Lipscomb [more]
Unread 17-01-2004, 06:38
D.Viddy's Avatar
D.Viddy D.Viddy is offline
AKA: Dylan Vester
FRC #3176 (Purple Precision)
D.Viddy is an unknown quantity at this point
Re: Trouble with pwm outputs
Originally Posted by Just3D
If for some reason you get the power set up once more and it still fails, try this, it will help clear up any future printf statements:
Code:
printf("%d\n", &pwm02);
Notice the ampherstand (&). This will tell printf to read the value of pwn02 rather than the memory address of pwn02 (this is why 10000 or so seemed so out of range; memory addresses range all the way up to the maximum RAM).
As for the digits between the % and the 'd', lpramo55 was right in saying the number controls the number of digits output. If you write a 3, it will display 3 digits, adding zeroes as necessary. This also works with decimal places. For example: If you wrote
Code:
float f = 34.67;
printf("%2.1f", &f);
The output would be 34.7, rather than 34.670000.
The number between the '%' and the 'f' in this case represents 2 digits, plus a decimal point, plus 1 additional digit.
Hope this helps!
NOTE: Do not use floats with the robot programming because it has no floating point processor. Instead, stick to ints and unsigned chars, using "%i", and "%d" as needed.
If I'm not mistaken, doesn't the rewritten printf function not support the %f format for floating point. If I am right. How would I display a floating point number in the terminal window?
Dylan Vester - (Programmer)
Running a P4 1.8 Ghz
Team 998, We can't win...
Unread 17-01-2004, 10:56
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
depending on the size, you might just multiply it by 1000 to give you an integer (if the number is -32.767 < x < 32.767) or some other power of 10 (i.e. if you have values -320.767 - 320.767, mult. by 100)
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Tether for new EduBot Controller gburlison Programming 9 18-12-2003 17:53
pwm 13-15 wayne 05 Programming 2 04-10-2003 12:08
PWM and burning out motors patrickrd Technical Discussion 7 19-06-2003 15:30
Hints For Rookie Programmers Noah Programming 30 20-02-2003 20:07
relay and pwm outputs nick_champ_2 Electrical 1 31-01-2003 13:08
