Go to Post A robot with hands would be cool! - Koko Ed [more]
Unread 13-01-2004, 22:02
Ben B Ben B is offline
Iceman
AKA: Ben-Jam-In
#0973 (Greyhound Revolutionary Robotics)
Team Role: Student
Ben B is an unknown quantity at this point
Send a message via AIM to Ben B
Problem compiling edubot
When comiling files for our edubot, this happens:
Deleting intermediary files... done.
Executing: "c:\mcc18\bin\mcc18.exe" -p=18F8520 "ifi_utilities.c" -fo="ifi_utilities.o" /i"C:\mcc18\h" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "c:\mcc18\bin\mcc18.exe" -p=18F8520 "main.c" -fo="main.o" /i"C:\mcc18\h" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "c:\mcc18\bin\mcc18.exe" -p=18F8520 "printf_lib.c" -fo="printf_lib.o" /i"C:\mcc18\h" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "c:\mcc18\bin\mcc18.exe" -p=18F8520 "ifi_startup.c" -fo="ifi_startup.o" /i"C:\mcc18\h" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "c:\mcc18\bin\mcc18.exe" -p=18F8520 "user_routines.c" -fo="user_routines.o" /i"C:\mcc18\h" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "c:\mcc18\bin\mcc18.exe" -p=18F8520 "user_routines_fast.c" -fo="user_routines_fast.o" /i"C:\mcc18\h" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "c:\mcc18\bin\mplink.exe" /l"c:\mcc18\lib" "18f8520user.lkr" "C:\Documents and Settings\default\Desktop\Brian's Mess\EDUbot\EDU_Default_Code_2003-12-15\ifi_utilities.o" "C:\Documents and Settings\default\Desktop\Brian's Mess\EDUbot\EDU_Default_Code_2003-12-15\main.o" "C:\Documents and Settings\default\Desktop\Brian's Mess\EDUbot\EDU_Default_Code_2003-12-15\printf_lib.o" "C:\Documents and Settings\default\Desktop\Brian's Mess\EDUbot\EDU_Default_Code_2003-12-15\ifi_startup.o" "C:\Documents and Settings\default\Desktop\Brian's Mess\EDUbot\EDU_Default_Code_2003-12-15\user_routines.o" "C:\Documents and Settings\default\Desktop\Brian's Mess\EDUbot\EDU_Default_Code_2003-12-15\user_routines_fast.o" "C:\Documents and Settings\default\Desktop\Brian's Mess\EDUbot\EDU_Default_Code_2003-12-15\ifi_library.lib" /m"EduCode.map" /o"EduCode.cof"
MPLINK 3.40, Linker
Copyright (c) 2003 Microchip Technology Inc.
Errors : 0
MP2COD 3.40, COFF to COD File Converter
Error - Source file 'C:\Documents and Settings\default\Desktop\Brian's Mess\EDUbot\EDU_Default_Code_2003-12-15\ifi_utilities.c' name exceeds file format maximum of 62 characters.
Errors : 1
BUILD FAILED: Fri Jan 25 18:53:33 2002
We have tried numerous reinstalls, but nothing has worked...
Oh heavens, what will we do?
Unread 13-01-2004, 22:09
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Problem compiling edubot
Errors : 1
This is an easy one.
You've buried your code too deep.
Even though it looks like it's as high as it can get being on your desktop, on the disk it really isn't because Windows allows for multiple users to each have their own desktop.
Move your EDUbot directory to the top level local disk "C:" directory.
i.e., drag it to My Computer -> local disk (C)
There is a limitation in MPLAB where it can only handle a directory path of 62 characters or less, so you have to keep the source files higher up. In your case you ran over the limit about here:
"C:\Documents and Settings\default\Desktop\Brian's Mess\EDUbot.."
Unread 13-01-2004, 23:55
Larry Barello Larry Barello is offline
http://www.barello.net
#0492 (Titan Robotics Club)
Larry Barello has a spectacular aura aboutLarry Barello has a spectacular aura about
The simple answer: move your development directory from your desktop to c:\ (the root of the C drive).
Unread 14-01-2004, 00:51
echos's Avatar
echos echos is offline
Jack of all trades
#1125
echos will become famous soon enough
Send a message via ICQ to echos Send a message via AIM to echos Send a message via MSN to echos Send a message via Yahoo to echos
probally the best idea is to get/use a zip drive for storing your project makes it easily portable and is rather seamless as far as access times.
Victor problem Andy Baker Electrical 15 24-06-2003 09:49
Ok one problem cantwell03 Programming 3 13-02-2003 07:28
Can RC servos be used with EDUbot? ChrisH Technical Discussion 4 31-12-2002 01:45
The problem with scouting... archiver 2001 10 23-06-2002 23:49
Major problem with chipphua motors aka Scott White Motors 18 19-03-2002 19:44
