Go to Post Your iphone may be more intuitive for some of your students than a screw driver. - Isaac501 [more]
Unread 14-01-2004, 08:46
Joe P Joe P is offline
Joe P will become famous soon enoughJoe P will become famous soon enough
Question Big Ball Handler
Has anybody researched the advantages and disadvantages of doing a ball handler using motors versus pneumatics?
Unread 14-01-2004, 10:05
kevin.li.rit's Avatar
kevin.li.rit kevin.li.rit is offline
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
kevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond repute
Send a message via Yahoo to kevin.li.rit
Re: Big Ball Handler
To handle the big ball your motors going to have to constantly run to hold the ball along its circumfrence.
Using pneumatics to hold the ball, the piston would apply a constant force to hold up the ball so you wouldn't have to run your motor constantly.
I would use pneumatics.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 14-01-2004, 10:15
P.J. Baker's Avatar
P.J. Baker P.J. Baker is offline
needs a clever user title
FRC #0177 (Bobcat Robotics)
Rookie Year: 1999
P.J. Baker is a glorious beacon of lightP.J. Baker is a glorious beacon of lightP.J. Baker is a glorious beacon of lightP.J. Baker is a glorious beacon of lightP.J. Baker is a glorious beacon of light
If your mechanism is designed properly, you should NOT have to continuously run a motor to hold a big ball.
I would not use pnuematics for this task if it was the only thing I was using the pneumatics for. It takes 2 or 3 functions (IMO) before adding the pneumatics to the robot starts to make sense.
Also, with the pneumatics you should be careful with how easy it is to release the ball. In 2001, many teams dropped the big ball because they had a hair trigger on their pneumatic claw. The cylinders can be adjusted (I think) to have slower action. I would definitely do this if I were using one to grasp the big balls.
Unread 14-01-2004, 10:28
patrickrd's Avatar
patrickrd patrickrd is offline
AKA: Patrick Dingle
Rookie Year: 1999
patrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to behold
Send a message via AIM to patrickrd
I wouldn't be so quick to make this decision. Whether to use a motor or pneumatics requires a number of considerations...
- Are you planning to use pneumatics elsewhere on the robot? (the cost of using pneumatics is at least 10 lbs). This, in my opinion, is the main reason you may choose not to use pneumatics.
- How easy will it be to run pneumatic tubing vs. wires to the place of application? Tubing is generally more difficult since it can not make sharp turns like wire can.
- Do you want precise control over the posisition of the ball handler? Perhaps to use your component for some other function as well? If so, then a motor would be advantagous because you can stop at intermediate positions.
- A motor would not necessarily have to apply a constant load. If you use a worm gear or screwdrive-based design, the device will stop when you turn off power, and not move. The ball will remain deflected by a constant amount while it is in your possession, and the force will be transferred to the screwdrive, not the motor.
Pneumatics is almost definately easier, but the easy solution is not always the best solution.
- Patrick
Systems Engineer - Kiva Systems, Woburn MA
Alumni, Former Mechanical Team Leader - Cornell University Robocup - 1999, 2000, 2002, 2003 World Champions
Founder - Team 639 - Ithaca High School / Cornell University
Alumni - Team 190 - Mass Academy / WPI
Unread 14-01-2004, 12:58
Matt Adams's Avatar
Matt Adams Matt Adams is offline
b(o_o)d
FRC #1525 (Warbots)
Rookie Year: 2000
Matt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond repute
Send a message via AIM to Matt Adams
Pneumatics vs. Motors...
I'd tend to agree with Patrick. Pneumatics is a serious weight commitment, especially the onboard pump. Properly geared motors with lead screws could possibly do the same thing for compareable weight after your run all the brass fittings, pump, tank... I have a hunch that we won't be using them this year. In order to justify them, you really need to ask, "After I throw all these pneumatics and the pump, and the gauges and the storage tanks and the tubing, is this really going to be lighter than a motor and a gearbox with a lead screw?
I'd imagine you'd need to use at least 3 pneumatics before having a justified weight trade off.
However, if you can remove the pump from the system and be careful about calculating how much you'll use pneumatics over the course of the a match, you could probably make a fair trade off with a pair of short 3/4" bore pneumatics (perhaps for shifting).
Just a few thoughts,
Matt
Matt Adams - Engineer at Danaher Motion
Team 1525 - Warbots - Deerfield High School
Goaltending- the next big controversy Wayne C. General Forum 69 23-01-2004 14:07
Plug for the big yellow ball wun Kit & Additional Hardware 22 15-01-2004 14:54
2004 Game BBFIRSTCHICK General Forum 112 19-04-2003 17:12
Curie Division Robots information... (not complete) archiver 2001 3 24-06-2002 03:13
30" ball sits up there real pretty archiver 2001 18 23-06-2002 22:49
