Go to Post I've worked with space based navigation and lever arms and planes and Kalman filters. .. and I have never, ever once considered looking up to navigate. - purduephotog [more]
Unread 14-01-2004, 14:17
MBosompra MBosompra is offline
MBosompra is an unknown quantity at this point
Tank tracks vs. Wheels
My team (820) and I are considering using either Tank tracks or wheels. I have a few questions for those of you who know anything at all about tank tracks.
1) what are the pros and cons of tank tracks?
-we know that we'll gain torque
-we'll be able to make it up the step
-we think we won't loose much speed
2) Can we buy premade tank tracks? If so, from where and how much?
3) How do we make tank tracks?
4) How long does it take to build the tracks
5) Any words or advice or experieces would be greatly appreciated.
Unread 14-01-2004, 14:22
Adam Shapiro's Avatar
Adam Shapiro Adam Shapiro is offline
FRC #0555 (Montclair Robotics)
Adam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud of
Send a message via AIM to Adam Shapiro
Re: Tank tracks vs. Wheels
Speaking from experience (we used treads in 2002):
Pros: One of the major pros of using treads is that you get a lot more traction on the bot. It will be much harder for other bots to push you around. Treads (with correct design) also make it easier for you to drive up the platform (from the 6" side panel).
Cons (Important!): Treads require a lot of torque as they produce a great deal of friction with the carpet. This is a major problem, especially if you aren't the greatest with a drive system and gearing (just like us in 2002), as turning becomes almost impossible and causes the breakers to blow quite frequently. Depending on where you buy them (we purchased ours from BrecoFlex) they may take quite a while to get to the school. Ours took over 4 weeks and left us with almost no practice time (under a day before shipping).
I'm not denouncing treads but I would be careful before using them.
Mentor to Teams 555, 1929, and 2070!
Currently working in hardware design at Cisco.
Cornell University DARPA Urban Challenge - http://www.cornellracing.com
Co-Captain Team 555 - 2003,2004,2005
Trust, Love, and Magic
Unread 14-01-2004, 14:32
Paul H's Avatar
Paul H Paul H is offline
Renegade of Funk
AKA: Paul Huston
FRC #0033 (Killer Bees)
Paul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant future
Send a message via AIM to Paul H
One thing you can do is mount a caster or two on pistons to deploy. This will almost emulate a 2 wheel drive and make it much easier to turn.
If you look at Truck Town Thunder's 2002 robot, it wobbled or hopped each time they turned it.
Unread 14-01-2004, 14:39
Ryan Albright's Avatar
Ryan Albright Ryan Albright is offline
Just Browsing
AKA: ryan albright
Ryan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond repute
Send a message via ICQ to Ryan Albright Send a message via AIM to Ryan Albright Send a message via MSN to Ryan Albright Send a message via Yahoo to Ryan Albright
I am speaking from experience wiht treads to
we used treads in 2001 they do have great traction and all but they also add alot of weight. We did not like are experience wiht treads we debated using them this eyar but that was quickely turned down. I think its mostly a team preference i think if we used them again we might like them but just the experience with them and wheels we like wheels better but expermient see hwo you like them
Alumni of 710 2001-2004
Mentor 1083 2005
2005 UCF regional lead safety advisor
2005 Championship Safety advisor
Unread 14-01-2004, 14:43
ggoldman's Avatar
ggoldman ggoldman is offline
FRC #0401
ggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud of
Send a message via AIM to ggoldman
You might want to look into one of the robots at the JPL (NASA jet propulsion laboratory) that can climb stairs and whatnot. IT uses tank treds with two extra "arms" to climb over terrain...
Happy hunting
G GOLDMAN
Unread 14-01-2004, 15:20
Mike Norton's Avatar
Mike Norton Mike Norton is offline
FRC #0061
Team Role: Teacher
Rookie Year: 1995
Mike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to all
Tank track are great.
We have had tracks for 10 years. So we know tracks and we know how far to push them.
1) Tracks are great to climb, push, pull, and to control.
2) Tracks are light if made right. they go a fast or as slow as you gear them.
if you look at theses pic's you can see how much power tracks can give you
http://www.valleytech.k12.ma.us/robo...ng%20Robot.jpg
http://www.valleytech.k12.ma.us/robo.../ClearRamp.JPG
Here is a close up of one of our track systems
http://www.valleytech.k12.ma.us/robo...02%20Track.jpg
Bad thing about tracks are if you go past there point of no return they rip
http://www.valleytech.k12.ma.us/robo...s/MVC-671S.JPG
these were Breco Flex timing belts. they have made better belts for us so they don't rip as easy. the cost is $270 per belt. the not so strong belts run around $140
If you want you can go back and look how our tracks have change in the past years
http://www.valleytech.k12.ma.us/robo...photos2002.htm
We left out 1999 becuase that year was a good year of climbing. you have to figure that one out on your own.
If you need anything esle just e-mail me
Unread 14-01-2004, 21:55
Alexander McGee's Avatar
Alexander McGee Alexander McGee is offline
Hoonigan
AKA: Alexander S. McGee
no team (no team)
Rookie Year: 1998
Alexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond repute
Send a message via AIM to Alexander McGee Send a message via Yahoo to Alexander McGee
Only when our arms were up. If you lowered them, it wouldnt. LOL, it was funny to watch though.
-Alexander S. McGee
Intellectual Property Attorney, Mechanical Engineer, Gear-head
Unread 14-01-2004, 22:22
Thanks to everyone for answering my questions. I have a few more for you guys.
1) How much roughly did it cost your team to build the whole tread system?
2) Did you have to have the inner wheel machined? Did you have anything machined?
3) How many of the belts did you guys rip?
4) How would my team go about making a tank tread?
5) I'm worried about turning with the treads, I think that it'll be a lot harder with treads and that we'll probably trigger the breakers.
6) Is it at all possible to buy a premade system and then just install it on our robot?
Unread 15-01-2004, 00:00
Solace's Avatar
Solace Solace is offline
Head Hurts. Coffee. More. Now!
AKA: Jake
#0571 (Team Paragon)
Solace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to behold
Send a message via AIM to Solace
the easiest way to make turning easier on a tracked robot (or any robot for that matter) is to lower the center idler wheel down about 50 thousandths of an inch. This decreases your effective track length while turning, and still allows you to keep most of your traction.
a slightly more complicated, yet more effective solution is to have a mechanism that lifts one end of your robot off of the groung using skids or casters. when you get yourself into a situation when you need your traction again, you just plop the full length of your treads back onto the ground.
...What is a man,
If the chief good and market of his time
Be but to sleep, and tool? A nerd, no more.
2004 UTC New England #2 seed
2004 UTC New England Champions with 716 & 230
2004 Archimedes #2 seed, undeafeated in Qualifiers (for what its worth)
Jake
Team Paragon #571
Unread 15-01-2004, 06:47
Don Wright's Avatar
Don Wright Don Wright is offline
FRC #0469
Don Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond repute
Send a message via MSN to Don Wright Send a message via Yahoo to Don Wright
Here is something I found the other day when investigating drivetrain solutions. We still might use these, but maybe somebody else can as well.
It's pre-made, relatively cheap, can easily made lighter, and all you have to do is bolt some motors in to get it to work. Maybe it will work for you. I called them and they have a lot on stock (plus some other neat things on the site):
http://www.robotcombat.com/store_tanktreads.html
Only $140 + shipping for the set. They are only 20" long, but if you put them on the front of a bot with casters or the like on the back for stability (or even some kind of suspension), it could be a good combination.
Good luck.
Donald F. Wright Jr.
Product Manager
AVL Instrumentation & Test Systems, Inc.
Unread 15-01-2004, 07:57
Originally Posted by 2000vfr800
...with casters or the like on the back.
Be very careful with casters! Even with treads you will lose a measure of control with your casters (although the surface area from the treads will most likely override this). We had that problem in 2001 (our rookie year) in which we used a combination of wheelchair wheels and casters; with that combination I believe our robot drove in a straight line only once or twice during the season...
Unread 15-01-2004, 08:06
Don Wright's Avatar
FRC #0469
Very good point...but hey...I'm an electircal enginer and my solution is, "We'll fix it with software!"
Honestly, it's a good point. Casters were just a quick suggestion.
Product Manager
Unread 15-01-2004, 08:10
I love it! I'm actually an EE/programmer by "trade" but I'm also co-captain of our team so one of my jobs is to know everything in a general sense as well as to know all of our past failures!
Unread 15-01-2004, 08:37
KenWittlief KenWittlief is offline
KenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond repute
castors work great if you close the steering control loop with a yaw rate sensor - then the SW can tell how much the driver wants to turn, and how fast the bot actually IS turning, and correct itself.
We did this last year - it works extreemly well!
  #15   Spotlight this post!
Unread 15-01-2004, 20:42
Tom Bottiglieri Tom Bottiglieri is offline
FRC #0254 (The Cheesy Poofs)
Tom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond repute
we have used treads for the past 3 years and have had nothing but luck with them.. they can climb pretty much anything if u design them right or have the proper lead in.. now about cost: my team put together a system last year that cost less than 400 dollars.. considering the amount of extra stability they give u, i would think its deffinitly worth it. i just cant imagine driving a bot that uses wheels and slides all over the place
What do you use for wheels? Andrew Technical Discussion 36 08-01-2004 10:20
tank treads vs. threaded wheels lj8758 Technical Discussion 14 24-01-2003 00:30
Lots of Wheels and F = u x N archiver 2001 17 23-06-2002 23:37
Good or bad: back wheels coming off the ground Gui Cavalcanti Technical Discussion 2 17-03-2002 22:09
"Motors and Drive train edition" of Fresh From the Forum Ken Leung CD Forum Support 6 29-01-2002 12:32
