Go to Post "By three ways we may learn wisdom: first is by reflection, which is noblest; second by imitation, which is easiest; and third by experience , which is the bitterest." - bEdhEd [more]
Unread 14-01-2004, 15:40
Jesse Jesse is offline
Jesse is on a distinguished road
Pivoting arm?
If we were to have a pivoting arm that is over 36 inches when out, but it is being started in an upright position, is it allowed?
Unread 14-01-2004, 15:53
David Kelly's Avatar
David Kelly David Kelly is offline
A Legacy of Impact
FRC #0234 (Cyber Blue)
Rookie Year: 1999
David Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond repute
Send a message via AIM to David Kelly Send a message via Yahoo to David Kelly
Re: Pivoting arm?
If it falls with-in the footprint prior to the start of the match, then you are okay. You may expand as much as it wants once match starts. Your robot will literally be shoved into a glass box to make sure it will fit the dimentions of the footprint during inspection for the competition, so be sure you will fall with-in that footprint.
2010 Indiana Robotics Invitational Planning Committee
2010 Boilermaker Regional
Chairman's Award, Regional Finalist
2010 Kansas City Regional
Entrepreneurship Award
2010 Championships
Autodesk Inventor Award Winner
Unread 14-01-2004, 16:18
team222badbrad's Avatar
team222badbrad team222badbrad is offline
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
Rookie Year: 2000
team222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond repute
Send a message via AIM to team222badbrad
Re: Pivoting arm?
You may expand your robot in any position you want after the match starts. However you must reset your robot to the exact position that it was in the box. In other words you cannot have a robot on the field in starting position that is 30 by 36 by 70 inches it has to be 30 by 36 by 60.
The general rule of thumb is to build your robot 2 inches smaller to allow space on each side in case you want to add objects later on in the build season such as side panels.
FIRST is really picky about being a few inches off before the match but you MUST fit in the sizing box during inspection otherwise you wont compete!!!!!!!
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 14-01-2004, 17:46
Re: Pivoting arm?
Thx
pic: Arm vs Arm CD47-Bot Extra Discussion 2 13-03-2003 12:37
Reflected Inertia? archiver 2001 9 24-06-2002 03:50
Controlling Arm travel - Limit Switch or Mechanical Stop? archiver 2001 8 23-06-2002 23:55
Correction for arm skyfw Programming 6 06-04-2002 21:59
telescoping arm & ten second rule Ben Mitchell Rules/Strategy 4 18-02-2002 21:37
