Go to Post IF teams did NOT READ THE FIRST MANUAL AND Q&A SITE, it is not FIRST's fault, it is the TEAM'S fault - sburro [more]
Unread 14-01-2004, 17:30
Venkatesh Venkatesh is offline
FRC #0030
Venkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to behold
Fast and Slow Operations
I have been looking around at stuff for some time, and I have found many people saying different things about the Pic Microcontroller. Some people have said that division is slow w/o hardware support, some have said that floating point operations were ridiculously painful, etc.
I am looking a for a vaguely comprehensive guide as to what mathematical operations are slow and what operations are fast. Over here, we have found an excellent approximation for cosine, which uses only square roots, multiplication, and division.
If anyone has any related info, could you please post?
Thank you.
-- vs, me@acm.jhu.edu
Mentor, Team 1719, 2007
Team 30, 2002-2005
Unread 14-01-2004, 18:44
Greg Ross's Avatar
Greg Ross Greg Ross is offline
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
Rookie Year: 1998
Greg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond repute
Send a message via AIM to Greg Ross Send a message via Yahoo to Greg Ross
Re: Fast and Slow Operations
Looking at the data sheet for the PIC18FXX20, Multiply, Add, and Subtract (8 bit integer) should be really fast. 16 bit integer versions will be not as fast, but should still be fairly fast. And it goes downhill from there. (Because all operations other than 8 bit integer Add, Subtract, and Multiply have to be implemented in software.)
Greg Ross (The Grammar Curmudgeon formerly known as gwross)
S/W Engineer, Team 330, the Beach 'Bots
<--The Grammar Curmudgeon loves this cartoon.
“Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming "Wow! What a Ride!" Hunter S. Thompson
"Playing a practical joke means doing something mean and calling it funny." Me
Unread 15-01-2004, 01:45
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
also, most square root algorithms tend to be fairly slow. one thing you could try is having the robot generate a lookup table (basically an array) of the sines/cosines/tangents for each angle 0-180, and then accessing that when you need it - that way you can run the slow calculations once at startup, and use direct memory-access to get the values at runtime.
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Slow News Week Lloyd Burns Dean Kamen's Inventions 0 19-05-2003 19:59
Bridge Question for those who have played archiver 2001 11 24-06-2002 01:44
Speed is definately going to be a factor.... archiver 2001 14 24-06-2002 00:24
How fast? archiver 2001 4 23-06-2002 23:59
Speed? WernerNYK Technical Discussion 13 10-02-2002 23:54
