Pressure transducer
the TI pressure sensor, anyone know anything about it? can it messure vacuum? how sensitive is it? can i find specs online? thnx!
Re: Pressure transducer
Here is the TI pressure transducer division website: http://www.ti.com/snc/products/sensors/ipt.htm They r supposed to be 0-130 psi, 0-5v porportional output. Thats all i know. |
from the looks of things it looks like the 67 CP model, which the site says has a 1.5% error rate, so at 130ps its ~1.8 psi error. I'd also suppose that when the compressor is on, then reading are innacurate, watch the gage when you power up to see why. I've tried 5cp3-7 and all varients their of, and I do find a few sites in japanise. I dont know what they're saying though. for ti, though, "CP3" is some type of input pin on a TMS370Cx36 8-BIT MICROCONTROLLER, maybe first confused the "transducer" with a electroinc componet of the transducer... or its a proprietary part #...
| Nason pressure switches | JP_1163 | Pneumatics | 11 | 03-03-2003 23:03 |
| pressure switch | Antonio | Pneumatics | 10 | 31-01-2003 03:52 |
| pressure sensors | archiver | 2001 | 0 | 24-06-2002 02:15 |
| Need help with 255 Variable | Joseph F | Programming | 18 | 26-02-2002 14:49 |
| Pneumatic pressure sensor | Curtis Williams | Pneumatics | 3 | 04-02-2002 20:09 |
