IR sensors
What did the IR sensors come in or what do they look like? We are confused. If you have any information that would be great.
Re: IR sensors
They are small, black, 3-leaded parts with a rounded dome on one side. |
Re: IR sensors
Ok, we found the "hardware" for the IR sensor. However, we're not sure about the mounting board shown on the instructions. Is it the one that is in the padded envelope? If so, do we cut it down to a smaller size? Any help is much appreciated.
Re: IR sensors
-Kevin |
Re: IR sensors
By the way, remember that the instructions from the kit are wrong when it comes to wiring the transistor. http://www.chiefdelphi.com/forums/sh...ad.php?t=23878 |
Re: IR sensors
Thanks for the help, we're going in the right direction now although we need clarification/help on the rest of the IR system.
As described we understand the IR sensors on the robot "seek out/home in on" the sensor(s) located near the 10 point balls. Did we receive the parts needed to create the "sensor" at the 10 point ball location? Are they the square "reflectors" (look like bicycle reflectors w/wires- 4ea) in the kit? If so, what are they connected to? Given Kevin's posts relating to "code" for these sensors (at the balls) it sounds like there is some type of "controller" (computer?) running this end of things. Correct? Again, thanks for the help. David M. Ellich Coach, Team 1251 TechTigers/The Revolution "Technology for the 21st Century" |
Re: IR sensors
I also was wondering if the PWM connectors and the short wires depicted on the diagram that came with the beacon instructions are in the envelopes, because the one I have doesn't include them. Are they possible in the other envelopes for the other sensors. Also, Kevin, I'm not exactly sure how to wire up the sensor for our robot, such as you depicted. What does the sensor connect to? And, how does that connect to the controller? Thanks
Re: IR sensors
The IR Beacons were shipped in pieces and must be assembled per instructions. You are correct to say that a controller is needed -- Code is provided to use the EduBot controller for this purpose. |
#10
Re: IR sensors
You were given enough parts to make 2 Beacons.
In the sensor bag you will find Printed Circuit board x1, IR Transmittors x10 resistors x8, switches x2, and connectors x2. Print out the document http://www2.usfirst.org/2004comp/Inf...ng_diagram.pdf And it will assist you in the parts identification. Phil |
#11
Re: IR sensors
-Kevin |
#12
Re: IR sensors
The IR beacon parts in the kit are enough to build the two units (one for the robot and one at the balls). The EDUrobot controller is used with the beacon unit at the balls. Only thing left to do is use the appropriate code for each side. |
#13
Re: IR sensors
In what direction do the resistors neeed to be placed? And which part is the FET?
#14
Re: IR sensors
-Kevin |
#15
Re: IR sensors
THANKS! I just wanted to make sure, since I really don't feel like desoldering (it's such a pain!) Also, thanks for reminding me to switch pins 2 and 3, I never would've known (except when it didn't work!) Thanks again
| what type of sensors are good and convenient | magical hands | Programming | 7 | 04-01-2004 23:04 |
| Q&A Discuss: Optical sensors with EduBot | CD47-Bot | Extra Discussion | 2 | 01-03-2003 18:37 |
| Q&A Discuss: optical sensors | CD47-Bot | Extra Discussion | 0 | 15-02-2003 22:58 |
| Robogui ! sensors don't work | Fares | Programming | 2 | 07-01-2003 16:31 |
| pre-built autonomous sensors? | BandChick | Technical Discussion | 4 | 05-01-2003 22:06 |
