Go to Post I think it will be very hard to find one aspect of FIRST which doesn't inspire us. - Arefin Bari [more]
Unread 18-01-2004, 18:09
Kevin Watson's Avatar
Kevin Watson Kevin Watson is offline
La Caņada High School
FRC #2429
Kevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond repute
Re: IR sensors
Originally Posted by dmellich
Let me see if I have this straight.
The IR beacon parts in the kit are enough to build the two units (one for the robot and one at the balls). The EDUrobot controller is used with the beacon unit at the balls. Only thing left to do is use the appropriate code for each side.
No, there is a beacon on each side of the field, both driven by one EDU-RC.
-Kevin
Kevin Watson
Engineer at stealth-mode startup
http://kevin.org
Unread 18-01-2004, 18:15
Phil_Lutz's Avatar
Phil_Lutz Phil_Lutz is offline
Phil Lutz
#0851 (Froggers)
Phil_Lutz is on a distinguished road
Send a message via Yahoo to Phil_Lutz
Re: IR sensors
You have enough parts to build 2 beacons. Those beacons are placed on the center line of the playing field. Build one and power/controll it via your edubot.
That's the transmittor.
You then need to build the receiver for your robot.
Unread 18-01-2004, 18:30
CPUguy387's Avatar
CPUguy387 CPUguy387 is offline
AKA: Matt
#1189 (Breaking Pointe)
Team Role: Student
CPUguy387 is an unknown quantity at this point
Send a message via ICQ to CPUguy387 Send a message via AIM to CPUguy387 Send a message via Yahoo to CPUguy387
Re: IR sensors
Where can I reorder another FET? One of the ones I had broke when I was trying to desolder it and switch pin 2/pin 3
M@
Unread 20-01-2004, 12:27
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: IR sensors
The beacon parts are for the two beacons that will be on either side of the field. Neither gets mounted on the robot itself. Drive the beacons with the EDU controller running the beacon software provided at the IFI web site (labeled "IR Tracking Code - Kevin.org").
The robot gets just the one piece IR sensor (4 are assumed in Kevin Watson's code) hooked directly up to digital inputs 1-4. Drive these with the navigate software also in the download above.
Unread 20-01-2004, 21:13
CPUguy387's Avatar
AKA: Matt
Team Role: Student
Re: IR sensors
We ordered 2 more FETs just incase. Before I put the one on my second beacon, I just wanted to make sure which digram is correct. Is this one still wrong? http://www2.usfirst.org/2004comp/Inf...ng_diagram.pdf Should I still reverse the pins 2 and 3? I just wan to make sure again before I order more.
M@
Unread 21-01-2004, 09:18
Just Itinerant
Re: IR sensors
That circuit is incorrect.
Luckily the FET seems to be internally protected against hooking it up incorrectly or teams would have been burning them out right and left.
On the FET looking at the front (with the metal ground plate at the back)
pin 1 on the left goes to the white (signal) wire on the PWM cable from the EDU controller.
pin 2 goes to the negative side of the circuit you built.
pin 3 goes to the black PWM wire (common or ground) from the EDU controller.
You can see an updated circuit diagram Kevin Watson posted at http://kevin.org/frc/ beacon_transmitter_2.pdf
You can only see your circuit running with a digital camera, or by hooking up one of the IR sensors to a digital input like 6 and adding a printf to print the value of rc_dig_in06 in the beacon code.
Unread 19-01-2004, 11:32
Matthew_H's Avatar
Matthew_H Matthew_H is offline
Ubergeek
#1028 (Ubergeeks)
Matthew_H will become famous soon enough
Send a message via AIM to Matthew_H Send a message via MSN to Matthew_H
Exclamation Re: IR sensors
What is the exact size that we cut the victorboard? If there is somewhere I could find it, that would be great.
what type of sensors are good and convenient magical hands Programming 7 04-01-2004 23:04
Q&A Discuss: Optical sensors with EduBot CD47-Bot Extra Discussion 2 01-03-2003 18:37
Q&A Discuss: optical sensors CD47-Bot Extra Discussion 0 15-02-2003 22:58
Robogui ! sensors don't work Fares Programming 2 07-01-2003 16:31
pre-built autonomous sensors? BandChick Technical Discussion 4 05-01-2003 22:06
