Go to Post "Take a man to a FIRST contest and he's entertained for three days. Teach a man to build a FIRST robot, and he's out of your hair for six weeks a year..." - kmcclary [more]
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Unread 01-15-2004, 04:48 PM
KenWittlief KenWittlief is offline
KenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond repute
Mulit-postioning with pnuematics this year?
Since we are allowed to use more than what we have been limited to in the past, there is something Ive been wanting to try for a while, maybe this year we can.
Ive always wanted a way to be able to use a pnuematic cylinder with more control than full out or full in.
If we use extra valves on the exhaust side (the ones we dont normally put fittings on) couldnt you pressurize one side and have the cylinder go all the way out, then pressurize the other side, and have the cylinder goto the CENTER position?
if you had a position sensor, and you used the flow restrictors, couldnt you control the amount of air in each side (using more than one valve) to position it anywhere between the two extreems?
Anyone ever play around with this or try it?
any thoughts? seems like it would be perfect for controlling the position of an arm, infinitely variable.
Unread 01-15-2004, 05:17 PM
Rob Colatutto's Avatar
Rob Colatutto Rob Colatutto is offline
Roboticsrob
FTC #10092 (Green.Griffins;)
Rob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to behold
Re: Mulit-postioning with pnuematics this year?
You are correct. My high school team did this in 2001 and 2003 for our arms. The system lets you stop the piston where ever you want. We never had any sensors on it but you could easily do it with some on there. The way we had it set up was, run from the regulator into a double solenoid, then the air would flow dirrectly to the extension connector (front) on the piston, but then the retraction (back) air flow would be routed through a single solenoid to with its relief valves looped together. This allowed us to stop the pneumatic at any position with some fancy programming, but you would have to ask an old 263 programmer how to do that. One thing to watch out for is the lever arm's weight on that pneumatic. We had a slight drifting problem with the arm when we had 10 pounds on the end of it 4.5 feet from the pneumatic. With the right calculations this can be solved though.
Follow me on twitter @roboticsrob and my FTC team @griffins10092
Unread 01-15-2004, 05:19 PM
Rickertsen2 Rickertsen2 is offline
Umm Errr...
None #1139 (Chamblee Gear Grinders)
Rickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant future
Send a message via AIM to Rickertsen2 Send a message via Yahoo to Rickertsen2
The setup isn't ideal, but you can prolyl bootleg it to work. The cylinders are fince for this, and it is done all the time but not with this type of valve. You will also need some position feedback(I don't think the reed switches will work. They are probably not fast enough.). If you try what you describe above, i would be interested to hear the results.
1139 Alumni
Unread 01-16-2004, 12:18 AM
maxgebhardt's Avatar
maxgebhardt maxgebhardt is offline
resident insomniac
#0555 (we dont have a team name, and what are you gonna do about it!)
Team Role: Student
maxgebhardt is on a distinguished road
Send a message via AIM to maxgebhardt
well, even if the new postion switches won't work at high speed, you could try and tighten the valves to slow the speed of the extention as much as possible. my qustion is do you damage the solenoid?
Always remember... "with sufficient thrust pigs fly just well thank you."
team motto:
Trust, Love and Magic 2003
AFLAC 2002
Will stop for broken speed controlers 2001
{CPA}Maxzilla UT 2004
Unread 01-16-2004, 08:48 AM
Andrew Dahl's Avatar
Andrew Dahl Andrew Dahl is offline
#0497 (Orange Crush)
Andrew Dahl is an unknown quantity at this point
can we get a diagram of this
dahl
2002 VCU Regional winner of the GM Industrial Design award
whooot!
Unread 01-16-2004, 09:08 AM
I havent thought this through all the way, or tested anything , so Im reluctant to draw up a schematic. Someone might take it and base their design on it, only to learn much later that it wont work for some reason.
The basis idea I have is this. The pnuematic valves work buy releasing the full pressure in the line (60psi) to one end of the cylinder, and venting the other side open to the room - so its like one end of the cylinder is always disconnected.
The big valve they give us also has fittings for the vent outputs - so you could connect those to another set of valves
that would allow you to control the 'open' end - and instead of releasing all the air, contol how much is released
the second valves would not be connected to the pressureized line at all - they would be vent control valves
so when you pressurize one end of a cylinder, then switch it the other way, the first end will not loose all its air, unless you open the additional vent control valve - and depending on how long you leave it open, the air in that side will be allowed to vent out, a little, a lot, or all of it
and that should control how far the cylinder moves towards the other end, a little, a lot, or all the way.
Unread 01-16-2004, 09:34 AM
geo's Avatar
geo geo is offline
A Nuke Would Do The Job!
FRC #0865 (WARP 7)
geo is a jewel in the roughgeo is a jewel in the roughgeo is a jewel in the roughgeo is a jewel in the rough
Does anybody has a picture or diagrams?
Last time I tried to control the position of a cylinder with a double solenoid and I attached other one in the relase end. It worked. But sometimes the cylinder retracted slowly even I close the relase end.
2006 Greater Toronto Regional Winner!(with 1114 & 1503)
2002 Canadian Regional Winner!(with 610 & 781, our rookie year )
Unread 01-16-2004, 09:40 AM
working on it- i think i found the digrams that we used to create it on the 2001 bot
dahl
whooot!
Unread 01-16-2004, 10:49 AM
Jedi Padawan's Avatar
Jedi Padawan Jedi Padawan is offline
Electrical Expert Student
AKA: Dan Howell
Jedi Padawan is on a distinguished road
Send a message via AIM to Jedi Padawan
Ok so if I'm getting this right you are wanting to use one cylinder in multiple positions?? is this possible even with the magnetic cylinders?? I was thinking of that but wasn't exactly sure if that was going to be possible without doing something that might "modify" it.
It's all fun and games till the bosh motor breaks.....
Unread 01-16-2004, 11:13 AM
Roboticsrob
Its possible without any modifications at all.
We had the same problem at first last year untill we discovered a leak on our pneumatics system right after the storage tank. As long as there are no leaks and the system can hold over 60psi before the match starts you will not have a problem.
Unread 01-16-2004, 11:56 AM
ngreen ngreen is offline
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
yes, this is very possible. We used a pneumatic lift last year that could stop in multiple positions.
I drew a fast diagram in paint of how we did it last year.
Basically it involves routing all exhaust from the double solenoid through a single solenoid and putting a stop or loop on the NOT ON state of the solenoid. Make sure you stop the exhaust of the single solenoid too. Then you can program the single and double solenoids to work together. When you push one button on the joystick the single solenoid kicks on to allow the exhaust to escape to atmosphere, and when it is released the solenoid will switch to the pressured side and stop. We used two buttons, extending and retracting but made so they would trigger on side of the double solenoid and put the single solenoid into the ON state. With a little more programming you could probably be pretty exact as to when you stop.
I'll include the diagram. Any questions just ask.
I added a picture of last years robot in a halfway position. The cylinders are behind the yellow fiberglass poles.
Unread 01-16-2004, 03:00 PM
Thanks for the photo and diagram
and I have to say, nicely done! Your bot looks super - this would be an ideal way to actuate and arm moving up and down to grab something like
oh, I dont know, a 30" diameter ball?
Unread 02-01-2005, 09:54 PM
bombadier337's Avatar
bombadier337 bombadier337 is offline
1337 U53R
AKA: Shaver
None #1541 (MidloCANics)
bombadier337 is just really nicebombadier337 is just really nicebombadier337 is just really nicebombadier337 is just really nice
Send a message via AIM to bombadier337
After months of reading, I finally made my own account. Anyway, I'm from team 1541, we are a rookie team, but we are doing pretty good so far. We have some video of our testing of multi-position pneumatics at http://www.sartanyac1541.com . We used the SMC to plug into the actuator, and then the exhaust is routed into the festo valve which opens whenever the extend or retract button is being held down. It took a little fooling around to get it, but now we have everything running off one spike. :-)
Championship Qualification - How you would've done it Ken Leung Championship Event 6 10-26-2003 02:00 PM
Problems with this year... and a solution? archiver 2001 2 06-24-2002 03:23 AM
Wow! what a year archiver 2000 8 06-23-2002 10:43 PM
why why why...? archiver 2001 34 06-23-2002 10:13 PM
Making heads or tails of the new announcement... Jessica Boucher General Forum 66 09-26-2001 11:13 AM
