Go to Post To change culture, you're going to have to get people to listen. - Yipyapper [more]
Unread 08-02-2002, 11:39
Anton Abaya's Avatar
Anton Abaya Anton Abaya is offline
None #0419 (Rambots)
Rookie Year: 1999
Anton Abaya has a spectacular aura aboutAnton Abaya has a spectacular aura aboutAnton Abaya has a spectacular aura about
Send a message via ICQ to Anton Abaya Send a message via AIM to Anton Abaya
PWM Wires
Do PWM wires and end terminals have other names?
We need more terminals that will go into the speed controllers and the control system.
anyone know what they're called?
-anton
Unread 08-02-2002, 11:56
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
Innovation first sells PWM cables for $5 a piece...
http://www.innovationfirst.com/first...cessories.html
I'll bet, however, that you can buy all the connectors and wire to make 10 (just an off-hand guess) with $5...
But in answer to your original question, no, I don't know what the technical name for the terminals is...
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Unread 08-02-2002, 12:44
CaptainPlaid's Avatar
CaptainPlaid CaptainPlaid is offline
#0314 (Megatron Oracles "Big MO")
CaptainPlaid is an unknown quantity at this point
Good luck on finding components. I have been trying for 3 weeks to no avail. I have found that the 3ft length is almost always way too long and makes things look sloppy. However, Innovation First is offering 12, 24, and 36 in lengths this year which will help.
BTW, if any one knows a source especially for the end connectors (m and f) please post it.
Thanks
I have not failed. I have just found 10,000 ways that won't work.
Thomas Edison
Unread 08-02-2002, 13:17
DakotaFox DakotaFox is offline
DakotaFox is an unknown quantity at this point
These are the same cables that are used in R/C aircraft to control the servos.
If you have a hobby shop that sells R/C supplies you could check there to see if they have cable ends.
Good Luck!
Unread 08-02-2002, 17:57
Matt Reiland's Avatar
Matt Reiland Matt Reiland is offline
'The' drive behind the drive
None #0226 (TEC CReW Hammerheads)
Rookie Year: 1999
Matt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond repute
Tower Hobbie should have them in stock as Aileron Servo Extension cables with Hitec connections
www.towerhobbies.com
http://www2.towerhobbies.com/cgi-bin/wti0095p.pgm
Unread 08-02-2002, 19:48
MrB's Avatar
MrB MrB is offline
871 Team Leader
AKA: Brian Buonomo
FRC #0871 (WI RoboTechs)
Team Role: Teacher
MrB is a jewel in the roughMrB is a jewel in the roughMrB is a jewel in the roughMrB is a jewel in the rough
Thanks
Jameco should have the connectors, I've order the plastic housings and pin inserts from them in the past. You can find what you need in this category "Straight Headers":
https://www.jameco.com/cgi-bin/ncomm...s=503;524;728;
Unread 11-02-2002, 14:23
I did not see them on that web site. Do you have a more specifc link or a part number?
Thomas Edison
Unread 11-02-2002, 19:05
MrB's Avatar
MrB MrB is offline
871 Team Leader
AKA: Brian Buonomo
Team Role: Teacher
sorry, I don't have a more specific link, but they sell the headers for the cables in that section, if you were going to make your own cables.
The next best thing would be WWW.TOWERHOBBIES.COM
Unread 11-02-2002, 22:35
Rookie Year: 1999
http://www2.towerhobbies.com/cgi-bin...1&I=LXVJ42&P=7
Unread 14-02-2002, 13:59
CJMJ CJMJ is offline
#0446 (Robodogs)
CJMJ is an unknown quantity at this point
PWM Pins and Housings
One of the engineers on our team calls them "C-Grid" connectors because they're at a .100 inch spacing. I ordered some [female] pins and housings from Digikey. If you go to their website, www.digikey.com, and search on 50-57-9003 (housing) and 16-02-0097 (female) pins you'll see what I ordered. I'm not 100% sure they'll work yet. They're due to arrive tomorrow. I'll post a follow-up message at that time. I'm also not sure yet if using these [or modifying the cables] are legal.
pwm 13-15 wayne 05 Programming 2 04-10-2003 12:08
PWM and burning out motors patrickrd Technical Discussion 7 19-06-2003 15:30
PWM Antonio Technical Discussion 21 06-01-2003 14:44
Loss of signal in PWM cables. archiver 2001 6 23-06-2002 23:29
PWM Wires... Anton Abaya Technical Discussion 3 04-02-2002 05:07
