Re: Removing Bosch Drill Pins - Cause of Failure?
Thats good news. The last slide in the powerpoint pres on the FIRST site said make a new shaft, etc. Am I correct that there are only two pins?[IMG]http://[/IMG] Mike |
yes, there are indeed 2 pins. Dr. Joe recommended a new shaft so that it wasnt threaded., making it easier to couple to another shaft, or mount a sprocket on.
Cory |
-dave |
We took ours out today. We were following the PowerPoint to the pixel and started to pull off other parts until we realized "hey, we already got the pins out, we're done!" Hehe. Anyway, it is an extremely easy procedure if you are careful. I can't wait to try them in the new "QuadraMax G2"
If or when you remove the pins there is no change in the output shaft. You can still use the supplied hardware to make a drive system. The output shaft of the supplied drill tranmission has a standard drill chuck termination with a left handed thread and a locking screw just like all drills. Teams that are new to this arrangment should remember to use that locking screw and be sure it is tight before final assembly. |
Thanks to everyone for clearing this up. We will be taking them out.
Ahhhhhh... THAT'S the problem!!!!
We too, had the problem of the clutch slipping after having removed the pins. Al Skierkiewicz, thank you. I was losing my mind, having rebuilt that gearbox three times. Here's another possible issue to contend with. We had treads last year and when we wanted to dead-recon turn by stopping one tread and continuing forward with the other, the bot had so little resistance on the stopped side (no backwalk pins) that it continued to roll forward and not turn at all. We had to actually change the program from 127 to 115 on the stopped side. Is there an easier way which we overlooked? |
I think what you were up against is the extreme friction produced by tank treads. Even with the speed controllers set to brake, there is not enough force to hold back the non-moving side. You have to visualize the transfer of forces as the robot tries to turn and that the treads are trying to slide sideways as well. Tank treads are OK for certain games but they are bad if you want manuerverability and low current demand. If you look at the Innovation First site I think they still have a paper showing the currents generated by different drive systems. You can't stop a tank but you can't turn it on carpet either. |
#10
And wear a shirt that you don't mind if it becomes permanatly grease stained. Wetzel |
| Bosch Drill Motor | rmmlg | Inventor | 7 | 17-12-2003 14:33 |
| Drill Motors: Pins IN or Pins OUT | Caleb Fulton | Motors | 28 | 03-02-2003 14:19 |
| Replacement Bosch drill motor assembly | james700 | Motors | 3 | 31-01-2003 21:08 |
| BOSCH Drill Transmission Assembly | archiver | 2001 | 2 | 23-06-2002 22:08 |
| Bosch Drill Motor CAD Files | Madison | Inventor | 10 | 09-12-2001 00:14 |
