Go to Post Don't date anyone on your team unless you are POSITVE that you will be able to handle yourself professionally, not only during your relationship, but even after it ends. - Jaine Perotti [more]
Unread 16-01-2004, 08:59
Larry Barello Larry Barello is offline
http://www.barello.net
#0492 (Titan Robotics Club)
Larry Barello has a spectacular aura aboutLarry Barello has a spectacular aura about
Explain this link error?
I have a generalized buffered serial I/O module. The problem is that the linker barfs if I declare more than ~200 bytes of memory in the module.
Looking at the linker map output, I see that the particular module data is loaded after the stack (0x700) which indeed leaves about 200 bytes free. The weird thing is that all the rest of ram stops before 0x300, so there is a 0x300 byte hole in my memory.
Any hints as to why and how I can move my module lower so I can declare my buffers?
Side question: any reason why I couldn't move the stack to 0x700? It makes it a tad smaller... Final question: given the tools we have is there anyway to determine how much stack is being used? I know printf uses at least 50 bytes.
Unread 16-01-2004, 11:06
Jeremy_Mc's Avatar
Jeremy_Mc Jeremy_Mc is offline
GitHubber
Jeremy_Mc will become famous soon enoughJeremy_Mc will become famous soon enough
Re: Explain this link error?
I'm not well-versed in the way of the stack, so I can't help you there...
but I do believe MPLAB has a tool to view the stack/memory. Check the Help File for where it's at.
GitHub - Collaborate on code, documentation, etc. - http://github.com
Basic Run Error BBFIRSTCHICK Programming 10 02-04-2003 22:43
EMERGENCY! EPROM FULL error?!? CHSguard72 Programming 2 05-03-2003 20:51
To CHIEF DELPHI, link permission archiver 2001 1 24-06-2002 03:04
Basic Run Error Ulibrium Programming 12 21-02-2002 01:02
programming error agenova Programming 1 20-02-2002 13:00
