Go to Post It's the corollary that you pick them no matter what shape they start the event in. Pink is known for showing up at their 1st regional with the robot in an unfinished state. And somehow, magically by the end of qualifications it just works, and they win. - Nuttyman54 [more]
Go Back   Chief Delphi > Technical > IT / Communications > 3D Animation and Competition
Unread 16-01-2004, 17:29
MConte05's Avatar
MConte05 MConte05 is offline
"Operation FIRST"
AKA: Matt Conte
#1098 (G.I.'s)
Team Role: Driver
MConte05 is on a distinguished road
Send a message via AIM to MConte05
Envioments for showing off objects
Ok, we have all seen it, where there is a model with no special envioment or anything like that, just a blank white one with a plane and a light, and shadows. And I am wondering if any of you know some way (trick or tip) to quickly set up those things?
Cause what I usally end up doing is setting the envioment background (using max 6) to white, and then put a huge plane (usally 1,000ft x 1,000ft) underneath the object. Set up a light and go. But the problem is that you end up seeing where the light fades, and it doesn't look like an endless envioment. Do you guys have any solutions to this?
Reason being is that I want to make the objects, put them into a quick envioment to make a nice render and show it off. But since I can't figure a way to get the envioment to look nice, I end up having to show it from the top or bottom looking up....Such as this WIP:
And I would rather have a nice clean looking white envio.....
Unread 17-01-2004, 16:15
djcapelis's Avatar
djcapelis djcapelis is offline
Fried Manic Custard
None #0675 (Geeks with Power Tools)
djcapelis will become famous soon enoughdjcapelis will become famous soon enough
Send a message via ICQ to djcapelis Send a message via AIM to djcapelis Send a message via Yahoo to djcapelis
Re: Envioments for showing off objects
Kinda off topic... but for any pov-ray users... a simply sky_sphere declaration is always a brilliant move.
Setups up an entire fricking world for you... insane.
"I have more friends than enemies, I'm working to resolve the issue."
Unread 17-01-2004, 17:04
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
Team Role: Coach
Doug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond repute
use a skylight w/ global illumination
Unread 17-01-2004, 21:25
Soukup's Avatar
Soukup Soukup is offline
Animation Guru
AKA: David Soukup
Soukup is on a distinguished road
easy steps
first have your environment underneath your object.
next make a box that is bigger than your viewport (you can't see the edges of the box from the perspective) and place it underneath your object.
Material it with a material called matte-shadow (where standard is, click and you'll see matte-shadow)
Click receive shadows.
add a skylight and an onmi for shadows (turn of shadows for the omin)
go to advanced rendering (in rendering menu and click on light tracer.
RENDER AWAY (there are better ways, but this is simple and will give u the desired effect
soukupd_gv@hotmail.com
Team 74 Alumni
2003 Great Lakes, Midwest, and West Michigan Regional Animation Award Winner
Unread 18-01-2004, 01:00
Salik Syed Salik Syed is offline
FRC #0701 (RoboVikes)
Salik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud of
Send a message via AIM to Salik Syed
oh yeah...thats not really Doug G...its me ....he is the mentor but i was on his computer so i use his profile....but ne ways use what is posted above the only problem with it is that it takes a long time...but if you want those nice shadows u must wait...some times 2-3 hours! (w/ light tracer)
Or what you can do is make like 20 Direct lights all pointing to the object but coming from all sides (all lights same distance from the object) turn on shadows, and set the strength to something like .2
Team 701
Mobile/immobile objects on field Steve782 Rumor Mill 12 08-01-2004 04:15
Map Coordinates on imported objects Jacob Reif 3D Animation and Competition 2 04-02-2003 01:27
Help - objects won't move in Max Kevin Thorp 3D Animation and Competition 7 28-01-2003 12:49
Beware of flying objects in FL... archiver 2001 13 24-06-2002 02:23
How do you make objects shine??? Ydnar 3D Animation and Competition 7 07-01-2002 21:13
