Go to Post What really matters is what you got out of the FIRST season, and how you can use it to build on what you know. - Adam Richards [more]
Unread 16-01-2004, 19:29
josephscrub josephscrub is offline
josephscrub has a little shameless behaviour in the past
Question Extendable Arm
Does anyone know how to make an extendable arm for hanging from a bar? Please, Please answer.
Unread 16-01-2004, 19:38
generalbrando's Avatar
generalbrando generalbrando is offline
Build, Break, Repeat
AKA: Brandon Mensing
FRC #0246 (Overclocked)
generalbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to behold
Send a message via AIM to generalbrando
Re: Extendable Arm
Take a look around at other threads and you should find some answers. (use the search function) You can have something spring loaded and release it, you can use pneumatics, motors, telescopes, etc. It might be better for you to contact someone directly if you don't get the help you need from looking around - that way you can have a conversation and get a better idea. You can AIM me at BostonRobot. Best of luck.
Lead Mentor of Team #246, Boston University Academy and Boston University, Overclocked
www.burobotics.org
Unread 16-01-2004, 21:18
KenWittlief KenWittlief is offline
KenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond repute
Re: Extendable Arm
if you want to reach the bar, you dont have to extend too far. Your bot frame can be 5 feet high, so with only one joint (elbow) and an arm that goes down to the opposite corner of the frame (bottom) you should be able to reach up 10 feet easily.
Unread 16-01-2004, 21:22
Re: Extendable Arm
in the drawing, the frame is 5feet high, the bot is 3 feet long, so if the arm goes all the way to the floor it can be
squareroot (5^2 + 3^2) = 5.8 feet
when raised up on the 5 foot frame, thats 10.8 feet
extended enough?
Unread 16-01-2004, 21:26
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
Re: Extendable Arm
you need to cut your 60" leg down to around 48-50" or so when you measure to find the "hypotenuse", since the bot is around 1' off the floor, but jt will still be plenty long enough.
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 16-01-2004, 21:31
Re: Extendable Arm
theres no reason the arm cant go almost all the way to the floor - have a spot notched out for it, or have your frame a little shorter than 3 feet long, then it can hang over the end
remember at T=1 you can lift the arm up to get it off the floor - the bot only has to fit inside a 2.5 x 3 x 5 foot cube at the beginning.
I went back and cleaned up the sketch in the post above to show the arm being almost on the floor when fully retracted.
Unread 16-01-2004, 22:21
Arefin Bari's Avatar
Arefin Bari Arefin Bari is offline
AKA: Ari
FRC #0108 (SigmaC@T)
Arefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond repute
Send a message via ICQ to Arefin Bari Send a message via AIM to Arefin Bari Send a message via MSN to Arefin Bari Send a message via Yahoo to Arefin Bari
Re: Extendable Arm
here is another idea... why not having a telescope arm which has a hook goes up to that bar (10 ft.) and then grabs it... then use pneumatics to pick yourself off the ground. have notches to lock down your mechanism in that certain position... pick the pneumatics back up... you will be off the ground and hanging in the bar. certain way you would atleast be off the ground about an inch or 2. the way i explained it i think i confused everybody. if anybody have any question you can always send me a pm or im me.... thanks
Reflected Inertia? archiver 2001 9 24-06-2002 03:50
stop arm from walking archiver 2001 6 24-06-2002 00:41
Controlling Arm travel - Limit Switch or Mechanical Stop? archiver 2001 8 23-06-2002 23:55
telescoping arm & ten second rule Ben Mitchell Rules/Strategy 4 18-02-2002 21:37
Robot Controller arm David Kelly Technical Discussion 0 28-06-2001 16:37
