Go to Post Bring 'em on, kiddies. You underestimate the power of Amanda Morrison. - Amanda Morrison [more]
Unread 17-01-2004, 13:22
pagemauck pagemauck is offline
pagemauck is an unknown quantity at this point
adc.h missing
Has anyone had a build fail with a missing adc.h header file error even if this file is in the project you are compiling? Kindof stuck on this one. not to familiar with this compiler - we normally use visual c++.
Thanks......
Unread 17-01-2004, 14:21
Jake Lewis's Avatar
Jake Lewis Jake Lewis is offline
Co-Team Lead
FRC #0537 (Charger Robotics)
Team Role: Leadership
Jake Lewis is an unknown quantity at this point
Send a message via AIM to Jake Lewis
Re: adc.h missing
goto menu: project->build->project
change the 4th and 5th boxes to the path of your header file folder and library file folder (they should be under mcc18\bin\ or something
Jake Lewis
Co-Lead, Team 537
jakisnaki@hotmail.com
Unread 20-01-2004, 11:37
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: adc.h missing
use:
C:MCC18\h for Include Path
C:MCC18\lib for Library Path
Unread 13-11-2004, 01:40
Steven Carmain Steven Carmain is online now
Bit Twiddler
FRC #6013 (Robowolves)
Steven Carmain will become famous soon enough
Re: adc.h missing
Sorry to bring up a dead topic, but I still can't get "adc.h" to be found. I have changed "C:MCC18h for Include Path" about a half a dozen times, and it still doesn't work. I searched all the forums (I think), and I can't find anything. I think I have compiled code before (not sure about this, but found code from about a year ago on an isolated laptop.) It is an isolated laptop, wasn't used for competition, Win. 98, and the "adc.h" file exists cause I have found it on the hard disk. The code was based off the default code (maybe 2/24/04 default), the only changes were a lot of trimming in Default_Routines and a little new code in that routine. The complier says:
Code:
Executing: "c:mcc18binmcc18.exe" -p=18F8520 "MAIN.C" -fo="MAIN.o" -D_FRC_BOARD -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
C:Steven11_10_04ifi_aliases.h:18: unable to locate 'adc.h'
error 1 spawning c:mcc18bincpp18
Halting build on first failure as requested.
BUILD FAILED: Sat Nov 13 01:02:08 2004
Any Ideas?
2016+ - Team 6013 Lead Engineer
2002-05 - Team 45 Software/Electrical
A robot is like a campfire: it takes a while to bulid it, and then everyone surounds it!
A world without standards is chaos. A world with standards is chaos.
Unread 13-11-2004, 07:57
Unsung FIRST Hero
Mike Betts Mike Betts is offline
Electrical Engineer
Rookie Year: 1995
Mike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond repute
Re: adc.h missing
Steve,
I have C:\mcc18\lib and I think the problem may be the first \ after the drive designator. That first \ designates the root of your drive.
Let us know how you make out.
Mike
Mike Betts
Alumnus, Team 3518, Panthrobots, 2011
Alumnus, Team 177, Bobcat Robotics, 1995 - 2010
LRI, Connecticut Regional, 2007-2010
LRI, WPI Regional, 2009 - 2010
RI, South Florida Regional, 2012 - 2013
As easy as 355/113...
Unread 13-11-2004, 08:10
Just Itinerant
Re: adc.h missing
Originally Posted by Steven Carmain
The complier says:
Code:
Any Ideas?
You appear to be missing ALL your "\"'s.
It should have read:
Code:
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8520 "
Here's a snapshot of the Project Options pop-up in question.
Name:	MPLAB general options.jpg
Unread 15-11-2004, 16:43
jdong jdong is offline
Linux Nerd
AKA: John D
#0245 (Adam-Bots)
jdong will become famous soon enoughjdong will become famous soon enough
Re: adc.h missing
In a fury of patching our AdamBotsLive Linux code, I've ran into this error, too.
Another hint is to make sure you have no syntax errors around your #include statements -- notably in main.c.
John Dong
Co-Captain, Webmaster / Programmer
Team 245 -- Rochester Adams Robotics
Unread 15-11-2004, 17:58
Bharat Nain's Avatar
Bharat Nain Bharat Nain is offline
Bharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond repute
Send a message via AIM to Bharat Nain Send a message via MSN to Bharat Nain
Re: adc.h missing
I have gotten errors like that, but usually I solve them by finding something wrong in the code I wrote(once a j on the top of the file(stupid reason) and once i declared variables wrongly.. or twice, cant remember), but never bothered to find why exactly it caused that error to relate to adc.h... but all I can tell you is, you dont wanna touch any of the files in the mcc18 folder...
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 15-11-2004, 19:32
pakrat pakrat is offline
Rich Ross
no team (The Rat Pack)
pakrat is just really nicepakrat is just really nicepakrat is just really nicepakrat is just really nicepakrat is just really nice
Send a message via AIM to pakrat
Re: adc.h missing
oh my goodness, this is what heppend to our stinking code at western michigan! BE careful, you might fry your computer... Luckily First provided us with another one because it was not our fault. I hope it goes well, i just imported it form another team.
Unread 16-11-2004, 06:56
Linux Nerd
AKA: John D
#0245 (Adam-Bots)
Re: adc.h missing
main.c:
#include "ifi_aliases.h"
ifi_aliases.h:
#include <adc.h>
adc.h is the first line the compiler sees.
John Dong
Who is missing stuff from KOP? Matthew_H Kit & Additional Hardware 52 05-02-2004 19:52
Receiving missing parts from KOP shyra1353 Kit & Additional Hardware 7 30-01-2004 00:58
Anyone missing a Crasftman Ratchet Set from Mayhem Kyle Fenton Off-Season Events 0 01-06-2003 14:23
missing kit parts Stephen Kowski Kit & Additional Hardware 57 22-01-2003 12:27
Field and shelf missing dimensions kmcclary Off-Season Events 3 12-10-2001 18:21
