Go to Post FIRST has always been less than just a school activity for me and more of a way of everyday life. - Amanda Morrison [more]
Unread 17-01-2004, 14:39
John JediMaster's Avatar
John JediMaster John JediMaster is offline
#0019 (Big Red)
John JediMaster is an unknown quantity at this point
Send a message via AIM to John JediMaster
Servos - How much can they lift?
Okay my team is considering using some servos for our robot. But we need to know how much at best they could lift. Note. I'm in charge of strategy for our team so if I say something that is technical nonsense, please correct me.
Thank you.
Unread 17-01-2004, 14:54
GregT GregT is offline
GregT will become famous soon enough
Send a message via AIM to GregT
Re: Servos - How much can they lift?
Thank you.
The servo provides 42 oz/in peak torque and rotates with a speed of .16sec/60 deg.
Let me know if you need help figuring out what those two specs mean.
The above was my opinion. I'm wrong a lot. I'm sarcastic a lot. Try not to take me too seriously.
Unread 17-01-2004, 17:29
Greg McCoy's Avatar
Greg McCoy Greg McCoy is offline
boiler up!
FRC #3940 (CyberTooth)
Greg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond repute
Send a message via AIM to Greg McCoy
Probably about as much as you can lift with your pinky finger
Unread 17-01-2004, 19:18
KevinB's Avatar
KevinB KevinB is offline
AKA: Alum
KevinB will become famous soon enoughKevinB will become famous soon enough
Send a message via ICQ to KevinB
Servos are much more stout than that ...
Unread 17-01-2004, 23:13
Jay Lundy Jay Lundy is offline
Programmer/Driver 2001-2004
FRC #0254 (The Cheesy Poofs)
Jay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to all
Going by GregT's numbers I doubt it.
If you placed something 2 inches from the base of your pinky, and your pinky had the same torque as the servo, then it could lift 21 oz (about 1.3 lbs).
If anything I bet your pinky is stronger than that.
Of course there are different kinds of servos with different torques.
Unread 17-01-2004, 23:26
The numbers I posted refer to the Kit of Parts servo. And yes, its less then your pinky finger can lift.
Greg
Unread 18-01-2004, 01:50
OneAngryDaisy OneAngryDaisy is offline
not on CD enough...
Rookie Year: 2000
OneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of light
Whatever you do, I would not reccomend using servos for something that requires uh... strength or consitency.. In 2001 we used a servo, or should I say 'attempted' to use a servo to latch on one of the goals. lets put it this way, we literally had to replace the servo after every match, and this was a 4v0 game with no robot interaction with eachother.
Moral: Servos inhale audibly
Unread 18-01-2004, 12:00
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
In past rules books, FIRST has said that servo manufacturers typically inflaste their specs by 2x. So, don't count on more then 20 in/oz of torque.
Unread 18-01-2004, 12:14
The servo is not designed for high torque applications. Start using it for such and you'll strip the gears. I can't think of many instances its appropriate to use the servo to interact with the "outside world" (ie grabbing a goal or ball).
I just quoted quoted the FIRST KOP manual on those servo stats. If this number hasn't been correct in past years and you are depending on more then 20 or so oz/in you should probably measure the torque yourself.
Greg
Unread 18-01-2004, 14:03
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Adam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to behold
Send a message via AIM to Adam Y.
I have never heard that before. Could you be thinking of r/c speed controllers? Does anyone remeber what servo they are. I believe last year the were hitech servos.
If either a public officer or any one else saw a person attempting to cross a bridge which had been ascertained to be unsafe, and there were no time to warn him of his danger, they might seize him and turn him back without any real infringement of his liberty; for liberty consists in doing what one desires, and he does not desire to fall into the river. -Mill
Unread 18-01-2004, 14:56
KevinB's Avatar
AKA: Alum
We used servos to control our forward and rear goal hook in this game ... and they both worked flawlessly every time.
Unread 18-01-2004, 15:29
Aignam's Avatar
Aignam Aignam is offline
This Space For Sale
AKA: Anthony Mangia
#1257 (Parallel Universe)
Team Role: Scout
Aignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant future
Send a message via AIM to Aignam Send a message via Yahoo to Aignam
I'd leave a servo for a small task, just to be safe. For the past two years, and perhaps this year, servos have been the essential component to 25's <sarcasm>elaborate</sarcasm> braking system.
Some Thoughts to Ponder
How does a sign turn into a lady friend? Don't optional stop signs ruin the purpose? What are pneumatics? Am I really banned from 229 for life? Can walls get bigger?
Aignam. Pronounced A-Num. Mangia backwards.
NJFIRST.org | Best Thread. Ever.
AIM: Aignam | ICQ: 265237569 | E-mail: AnthonyMangia@aol.com | HTTP: www.aignam.com
Unread 18-01-2004, 15:36
pras870's Avatar
pras870 pras870 is offline
AKA: Mike
#0870 (Team Rice)
pras870 can only hope to improve
Send a message via AIM to pras870
I've never seen a servo in recent years do anything besides simple tasks (such as switching transmissions in the drill motors). They simply do not have enough torque.
'02 SBPLI Rookie of the Year
'03 UTC Johnson & Johnson Award Winners
'03 SBPLI Kleiner Perkins Caufield & Byers Entrepreneurship Award Winners
'03 SBPLI Regional Winners
'04 SBPLI Xerox Creativity Award Winners
Unread 18-01-2004, 16:01
Matt D's Avatar
Matt D Matt D is offline
college time!
FRC #0254 (Cheesy Poofs)
Matt D is a name known to allMatt D is a name known to allMatt D is a name known to allMatt D is a name known to allMatt D is a name known to allMatt D is a name known to all
Everyone is telling you servos will not work for lifting, but no one is telling you what to do instead.
Use pnuematic cylinders! They are designed for lifting, you can get whatever size you need, and (new for this year) you can use as many as you want.
Skip the servos and go with pnuematics.
-Matt Durstenfeld
  #15   Spotlight this post!
Unread 18-01-2004, 16:14
pras870's Avatar
AKA: Mike
#0870 (Team Rice)
correction, you can't use as many as you want, you're limited to 4 if memory serves.
Creative uses for servos? dddriveman Motors 34 19-07-2003 00:33
Is it illegal to lift another robot off the ground? Tton Rules/Strategy 19 14-01-2003 21:28
Need help in creating program to use servo's to shift drive archiver 2001 19 24-06-2002 00:35
How much can the window assembly lift? archiver 2000 9 23-06-2002 22:59
Window lift motors... David Kelly Motors 2 21-01-2002 00:03
