| View Poll Results: How fast are you planning on going? Measured in feet/second | |||
| 0-4fps |
1 | 1.09% |
| 5-6fps |
12 | 13.04% |
| 7-8fps |
27 | 29.35% |
| 9-10fps |
22 | 23.91% |
| 11+fps |
30 | 32.61% |
| Voters: 92. You may not vote on this poll | |||
Is there a Need for Speed???
How many people are going for speed this year or is this year going to be a pushing match for the small balls and goals??
Re: Is there a Need for Speed???
i am surprised at how many teams are choosing a fast robot (11 ft/sec is reletively fast). first allow me to say that i am assuming for the sake of this argument that teams who are choosing fast robots are therefore sacrificing torqe. although my team doesn't agree with me, i think that a slow, powerful, and controllable robot would be advantagous for the specialized tasks this year.
being able to position your robot to either knock down the bonus ball, cap a goal with the 2x ball, or grab onto the bar would require very carefull driving, which is harder for a fast robot (though it can be slowed through programming or using a tranny). i also dont forsee many robots having to sprint across the field and back. most of the tasks of the competition are located on your side of the field, save for the bar and moving goals that are in the middle. a robot could score highly without ever crossing the field or traveling long distances. any robot that can climb up the six inch step will need sufficient power to do it. even if you are both fast and powerfull, running full speed into the step isnt the best thing for the robot. once on top of the platform a fast robot would have trouble maneuvering on the HDPE (fast robots consequently have less traction). lastly, i think being able to push other robots around would be usefull in a defensive strategy. it would be easy to block another robot from crossing the field just by positioning you robot in the same alley. i know my argument seems very strong for a slow bot, but this is just once side of the debate. i look foward too seeing what other people think of the game. |
Yes, speed will be a huge factor in this game. Once you have conrol of the balls and they're in the player station, the opponent cant do anything about it. Collecting the small balls is all about speed. The goals on the other hand is more power. But with my teams uber gearbox, we get both.
that is the truth...and the reasoning behind most teams thinking |
Speed will come into play big time during autonomous mode, in my opinion. It doesn't matter how powerful you are if your opponent can get to the 10 point balls faster than you can, and autonomous modes can be upset very easily anyways.
But really, I guess only time will tell which one will be better in this year's game - speed or power. Then again, why not have both? ![]() |
:-D ~Dori |
[quote=Then again, why not have both?
[/QUOTE]Well from our team's point of view before the season started we were pretty certain we were goin with a 2 speed dual motor type transimission, but when the game came out, well there is alot of emphasis that is put on the manipulation of objects. That means we have to take weight out somewhere to have these manipulators. So the why not is weight. |
We went nuts after just..er..1/4 last year. But this year we're way on track. :-D We're almost done design. But that's not the point. Yeah weight IS a big factor, last year we kept having to take stuff out 'cause we were too heavy...then we finally were, like, 129.8 lbs. hehe. |
#11
speed holes.
speed holes are your best friend. |
#12
i realize my post was very one sided. i wanted to support the side that i didn't expect many people to take. im just trying to think outside the (gear) box. im sure there are a ton of exceptions to everything i said, but i stand by my assumptions and generalizations.
i know that controlling the robot usually isnt a problem for the experience programmer and driver, but a rookie or inexperienced team may have trouble controlling a bot with a max speed of 12 ft/sec. this is my team's third year and we are still learning as we go along. our robot last year was meant to lock onto a stack of up to four bins, but partially since the robot had to be precisely lined up, we only managed to pull it off once. as for crossing the field, some robots will be crossing but i do think that it will be at a smaller frequency than last year. last year, robots started on the opposite side, crossed back to gather bins, then ran across again to knock down stacks (again, this is a generalization, and a bad one at that). this year i would not expect robots to make the circuit across the field and back more than once, if at all. |
#14
