Go to Post Being professional means doing things right. Being gracious means doing the right thing. They complement each other perfectly. But I think we should remember to use GP as a guide for our own behavior, not as a yardstick to measure others' shortcomings. - Alan Anderson [more]
View Poll Results: How fast are you planning on going? Measured in feet/second
0-4fps 1 1.09%
5-6fps 12 13.04%
7-8fps 27 29.35%
9-10fps 22 23.91%
11+fps 30 32.61%
Voters: 92. You may not vote on this poll
  #16   Spotlight this post!
Unread 18-01-2004, 00:11
oreocookeee oreocookeee is offline
Critic Extraordinaire
AKA: orie
#0810 (Mechanical Bulls)
Team Role: Leadership
oreocookeee is on a distinguished road
Send a message via AIM to oreocookeee
Re: Is there a Need for Speed???
i realize my post was very one sided. i wanted to support the side that i didn't expect many people to take. im just trying to think outside the (gear) box. im sure there are a ton of exceptions to everything i said, but i stand by my assumptions and generalizations.
i know that controlling the robot usually isnt a problem for the experience programmer and driver, but a rookie or inexperienced team may have trouble controlling a bot with a max speed of 12 ft/sec. this is my team's third year and we are still learning as we go along. our robot last year was meant to lock onto a stack of up to four bins, but partially since the robot had to be precisely lined up, we only managed to pull it off once.
as for crossing the field, some robots will be crossing but i do think that it will be at a smaller frequency than last year. last year, robots started on the opposite side, crossed back to gather bins, then ran across again to knock down stacks (again, this is a generalization, and a bad one at that). this year i would not expect robots to make the circuit across the field and back more than once, if at all.
  #17   Spotlight this post!
Unread 18-01-2004, 00:13
PMGRACER's Avatar
PMGRACER PMGRACER is offline
Mentor
AKA: PAUL GIANNOSA
Team Role: Mechanical
Rookie Year: 2000
PMGRACER is on a distinguished road
Teams that have high and low gear will have both torque and speed. Six wheel drive should be sufficeint. A turret will enable you to manuver easily.
Racing is an incurable addiction!!
  #18   Spotlight this post!
Unread 18-01-2004, 00:20
Gope Gope is offline
#0016 (Bomb Squad)
Gope is on a distinguished road
Speed is the key this year, without a doubt. Although, one must consider that we are limited not only by hardware and software but also by human reaction time. You need to make sure that you team doesn't over do speed, because as I have witnessed last year, too much speed very quickly becomes a lack of control and thus a nearly useless robot. This year, I feel that gears a needed, not to control torque but to control a maximum speed.
Teams I expect to be blazing fast: 25, 60, 111, 312, 343
I also expect this year to be the year of the driver. I think that this year we will, more than ever, see excellence in driving technique and skill to be as great of a deciding facot as the quality of robot(ofcourse, this is an overstatement, but not a huge one).
College and its wonders. First year and alot of other FIRSTs.
  #19   Spotlight this post!
Unread 18-01-2004, 13:31
KenWittlief KenWittlief is offline
KenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond repute
to control any bot well you need to do something more than let the joystick inputs control the motor PWM outputs directly
FEEDBACK is probabally THE most powerfull tools at an engineers disposal!
When a drive train is geared up for speed, the stall torque is not very far above the friction in the drive train when you first start to move. that means if you are using two drive wheels to steer, then its almost certain that one will drag a little more than the other, and when you try to make small movements, or to go straight, the bot will not act like you want it too.
that why you REALLY need a yaw rate sensor and/or wheel movement sensors to close the loop - so the SW can tell the difference between what the driver is asking for and what the bot is actaully doing, and make the necessary adjustments and corrections all by itself
closed loop steering and closed loop speed control is a BEAUTIFUL THING!
  #20   Spotlight this post!
Unread 18-01-2004, 13:45
Aignam's Avatar
Aignam Aignam is offline
This Space For Sale
AKA: Anthony Mangia
#1257 (Parallel Universe)
Team Role: Scout
Aignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant future
Send a message via AIM to Aignam Send a message via Yahoo to Aignam
Originally Posted by Gope
Teams I expect to be blazing fast: 25...
All I can say is...
But yes, I think speed is essential, this year. With so many tasks to be done, and so many levels for these tasks to be done on, even if your robot only intends to perform a few tasks particularly well, you still need a robot that can move across the field and from level to level quickly. A robot that is on the hanging bar before any others is also going to have a one-up on the other teams.
EDIT: After having read the rest of the posts on the thread:
This year is going to be the year of drive team cooperation. You need a quality robot, a quality human player, a quality driver, and a quality coach to keep your quality drive team's head from exploding.
Some Thoughts to Ponder
How does a sign turn into a lady friend? Don't optional stop signs ruin the purpose? What are pneumatics? Am I really banned from 229 for life? Can walls get bigger?
Aignam. Pronounced A-Num. Mangia backwards.
NJFIRST.org | Best Thread. Ever.
AIM: Aignam | ICQ: 265237569 | E-mail: AnthonyMangia@aol.com | HTTP: www.aignam.com
  #21   Spotlight this post!
Unread 18-01-2004, 16:30
Dorienne's Avatar
Dorienne Dorienne is offline
6 years and counting! :)
AKA: the only fish in FIRST
FRC #0007 (Team 007); FRC #1719 (Umbrella Corp)
Dorienne has a reputation beyond reputeDorienne has a reputation beyond reputeDorienne has a reputation beyond reputeDorienne has a reputation beyond reputeDorienne has a reputation beyond reputeDorienne has a reputation beyond reputeDorienne has a reputation beyond reputeDorienne has a reputation beyond reputeDorienne has a reputation beyond reputeDorienne has a reputation beyond reputeDorienne has a reputation beyond repute
Send a message via AIM to Dorienne
Very very true.
Also, hi! I'm from Team 007, and we allianced with you all at Duel on the Delaware. :-D
~Dori
Have you found NEMO yet?
Proud mentor to teams 007 and 1719!
  #22   Spotlight this post!
Unread 18-01-2004, 20:57
Levaman's Avatar
Levaman Levaman is offline
A Spy for SIR Intel. Inc.
AKA: A Spy in Plain Site.
#0616 (Southampton Indian Robotics)
Team Role: Scout
Levaman has a little shameless behaviour in the past
Send a message via AIM to Levaman
Speed Holes is a new term for me. I understand it and know that they hold pros/cons.
Pros: Speed
Less Weight
no need to swiss cheese
Cons: Weak Body unless done right
less surface area to push with in some cases
Not a bad idea, but see if you can build the robot with them built in.
  #23   Spotlight this post!
Unread 18-01-2004, 21:01
Ok... um
'speed holes' is a reference to a Simpsons episode. Homer was wacking his car with a pickaxe (I forget why) and Flanders asked him what in the world he was doing?
and Homer sarcastically replied "Im adding speed holes, dont you know anything about cars Flanders?"
  #24   Spotlight this post!
Unread 18-01-2004, 21:08
Jones571's Avatar
Jones571 Jones571 is offline
AKA: Corey
FRC #0571 (Paragon)
Jones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud of
Send a message via AIM to Jones571
speed holes? jake u out did your self with that reasoning. i will not let u swiss cheese our bot 14fps is fast enough with out cutting holes in it!
  #25   Spotlight this post!
Unread 18-01-2004, 22:40
Lisa Rodriguez Lisa Rodriguez is offline
Biology Grad Student.....
AKA: Lisa Rodriguez
FRC #0173 (RAGE)
Lisa Rodriguez has a brilliant futureLisa Rodriguez has a brilliant futureLisa Rodriguez has a brilliant futureLisa Rodriguez has a brilliant futureLisa Rodriguez has a brilliant futureLisa Rodriguez has a brilliant futureLisa Rodriguez has a brilliant futureLisa Rodriguez has a brilliant futureLisa Rodriguez has a brilliant futureLisa Rodriguez has a brilliant futureLisa Rodriguez has a brilliant future
Send a message via AIM to Lisa Rodriguez Send a message via MSN to Lisa Rodriguez
Jake, you didn't have speed holes last year, neither did we.
Speed will not be top priority, although very important. I believe manuverablility will be MAJOR this year, especially with the field being 6 feet shorter. Speed is always nice, but you can sometimes sacrafice speed for manuverablility, being that you need it. I know my new driver from last year had to practice A LOT in high gear (15fps i believe, if i remember correctly) in order to control the robot, It's a dangerous speed to stay at, especially if your driver does not have a lot of experience. My favorite is the two speed, like the one our team has had. High speed to go from one end to the other, low speed to manuver and have torque. But then again, that could be just me and that's all i've ever known, but hey, i still like it!!
This thing still works?
it's never over unless you let it be over
  #26   Spotlight this post!
Unread 18-01-2004, 22:53
Andrew Andrew is offline
Andrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to all
Speed is only valuable over a relatively long distance. 15 fps only makes sense if you are going to go the full 40 ft. across the field. Hopefully you don't run into an obstruction somewhere in the middle (like the steps or a robot coming the other way).
Acceleration will be much more important this year than speed. How rapidly can you reach top speed and how effectively can you maneuver.
I'm surprised at teams that want to go really, really fast in autonomy. Teams are probably going to go to the center of the field (since that's where most of the scoring objects are). Do you really want to meet a 15 fps robot coming the other way?
15 fps + 15 fps = 30 fps -> lots of robot parts on the field.
  #27   Spotlight this post!
Unread 18-01-2004, 23:25
Solace's Avatar
Solace Solace is offline
Head Hurts. Coffee. More. Now!
AKA: Jake
#0571 (Team Paragon)
Solace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to behold
Send a message via AIM to Solace
we did too have speed holes! i spent 4 hours cutting them!
the reason you guys didn't have them was because you weren't imaginative enough to max out your weight requirements
...What is a man,
If the chief good and market of his time
Be but to sleep, and tool? A nerd, no more.
2004 UTC New England #2 seed
2004 UTC New England Champions with 716 & 230
2004 Archimedes #2 seed, undeafeated in Qualifiers (for what its worth)
Jake
Team Paragon #571
  #28   Spotlight this post!
Unread 19-01-2004, 09:00
no, i want to get to the release ball first, then get outta the way of the other bot :^)
  #29   Spotlight this post!
Unread 19-01-2004, 10:49
Jones571's Avatar
AKA: Corey
FRC #0571 (Paragon)
even if you try to avoid it there will be lots of robot bashing this year trying to fit through the narrow allies on either side of the platform especialy with the goals takeing up a good portion of the area.
  #30   Spotlight this post!
Unread 19-01-2004, 11:56
Andy A. Andy A. is offline
Getting old
FRC #0095
Team Role: Coach
Andy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond repute
Just to clear up the speed hole issue;
When some one talks about speed holes, all they mean 99% of the time are holes drilled in the bot to make the weight limit. They got the term speed holes from a Simpsons episode, and because getting rid of extra(dead) structual wieght can only make you faster. Besides, when some one asks why you're bot looks like a macoroni strainer, its cooler to reply 'Oh, those are the speed holes' then 'Oh, we were 3 pounds overwieght...'
So when you see a bot that looks like swiss cheese, it really means the bot iss really really fast
-Andy A.
