Go to Post FIRST is an organization where you leave lasting impressions on people you don't even know. - rtfgnow [more]
Unread 18-01-2004, 23:50
Ian W. Ian W. is offline
College? What?
no team (Gompei and the Herd)
Ian W. is a name known to allIan W. is a name known to allIan W. is a name known to allIan W. is a name known to allIan W. is a name known to allIan W. is a name known to all
Send a message via AIM to Ian W.
Placement of Navigate ()
Ok, I'm not sure if this is my sleep-deprivation (yes, already), or I actually picked something up, but I can't make sense of this.
In user_routines_fast.c, Navigate() is called from Process_Data_From_Local_IO. Navigate however, needs to output it's data somewhere, and from my understanding, you need to excute putdata(&txdata) to output data, but I can't find a putdata(&txdata) after Navigate() is called.
So, does this mean I'm blind and unable to see lines of code, or that it's just not put in the right place?
I'd test myself, but I want to make sure before I put the code into the robot that it's not going to kill it.
AIM --> Woloi
Email --> ian@woloschin.com
Unread 19-01-2004, 00:50
Kevin Watson's Avatar
Kevin Watson Kevin Watson is offline
La Caņada High School
FRC #2429
Kevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond repute
Re: Placement of Navigate ()
The pwmxx variables are global, so they'll be updated the next time putdata() is called in user_routines.c/Process_Data_From_Master_uP().
Navigate() will need to be called from User_Autonomous_Code() instead of Process_Data_From_Local_IO() if you want to use it during autonomous period. It was placed where it is now so that we could start the demo by pulling the trigger on the joystick.
-Kevin
Kevin Watson
Engineer at stealth-mode startup
http://kevin.org
Unread 19-01-2004, 00:52
Adam Shapiro's Avatar
Adam Shapiro Adam Shapiro is offline
FRC #0555 (Montclair Robotics)
Adam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud of
Send a message via AIM to Adam Shapiro
I haven't worked too much with the new code as of yet as I've been doing electrical systems so far but from my understanding the Process_Data_From_Local_IO() function is called with every program loop. Is there any reason for putting your Navigate() function in this rather than the time-controlled process function?
Second, the Putdata() function is declared in the IFI_default.h file, making it global to all functions in files including this file. The function should be usable within your Navigate() function or any other function you declare.
Mentor to Teams 555, 1929, and 2070!
Currently working in hardware design at Cisco.
Cornell University DARPA Urban Challenge - http://www.cornellracing.com
Co-Captain Team 555 - 2003,2004,2005
Trust, Love, and Magic
Unread 19-01-2004, 01:06
College? What?
Yeah, I was aware that you could call Putdata() anywhere, but I saw references to the fact that this code was used in the Kickoff demo, so I figured either I accidentally deleted something, or it did something I didn't understand.
I still don't see any reason for putting Navigate() in the user_routines_fast.c file though.
AIM --> Woloi
Unread 19-01-2004, 01:07
College? What?
Ah, ok, I wasn't sure if the GetData() call would overwrite them at all, as I haven't looked through absolutely everything yet.
AIM --> Woloi
Unread 19-01-2004, 01:08
FRC #2429
Yes, to minimize latency between clock (and beacon data) updates and when Navigate() is called.
I suspect sprinkling calls to Putdata() throughout your code is asking for trouble.
-Kevin
Kevin Watson
http://kevin.org
Unread 19-01-2004, 01:13
Yea, I could see where it might cause some issues
Unread 19-01-2004, 01:23
FRC #2429
Getdata() doesn't overwrite the pwmxx variables.
-Kevin
Kevin Watson
http://kevin.org
Unread 19-01-2004, 03:24
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
Getdata does just that, it gets input data, and putdata puts output data - the output values are never overwritten (except by your code), just processed.
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 19-01-2004, 14:16
Astronouth7303's Avatar
Astronouth7303 Astronouth7303 is offline
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Astronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud of
Because YOU edit it. the only things you NEED to edit are User_Routines.h, User_Routines.c, and User_Routines_Fast.c
Unread 19-01-2004, 14:37
PuiChi PuiChi is offline
Confound it!
AKA: Bernice Yau
#0840 (ART)
PuiChi is an unknown quantity at this point
Question Re: Placement of Navigate ()
I'm new and know nothing about the IR navigation code. So where would you edit the navigation code? =o___O;;=
Unread 19-01-2004, 19:50
That depends on what you want to do with it. Most likely you want to use it during the autonomous mode, in which case I believe it would go in the User_Routines_Fast.c in the User_Autonomous_Code() function (although you could create your own functions/names and move thing around).
Unread 20-01-2004, 18:41
Teh Kaj Teh Kaj is offline
AKA: David Chin
#0840 (ART)
Teh Kaj is an unknown quantity at this point
Send a message via AIM to Teh Kaj
How would you point out in the area to the nav code in that area? I get that's the place you would edit, but how would add it in? Would you simply make a duplicate copy of the code in that area?
Placement of bins... Useless member Regional Competitions 0 09-03-2003 11:12
Q&A Discuss: Rotating-Light Placement CD47-Bot Extra Discussion 6 28-01-2003 15:38
Placement of Robot Shawn60 Rules/Strategy 3 18-01-2003 23:51
Rotating-Light Placement Winged Globe Rules/Strategy 1 07-01-2003 22:44
Placement of stuff in the box... archiver 2000 1 24-06-2002 00:19
