Go to Post A good leader will step down so the right people are in the leadership positions, regardless of age. - Phoenix Spud [more]
Unread 19-01-2004, 01:38
billstu billstu is offline
billstu is an unknown quantity at this point
IFI Loader problems
Has anyone had any strange IFI problems...
For some reason after clicking on download (after selecting the Hex file) my computer gets a blue screen of death... then reboots... It happens fairly quickly so I can't tell you what is reported on the blue screen...
I have a Toshiba Satellite, 512 MB Ram, 2.6 Ghz P4, XP Home SP1
??? lmk Thanks
Unread 19-01-2004, 08:31
Unsung FIRST Hero
Mike Betts Mike Betts is offline
Electrical Engineer
Rookie Year: 1995
Mike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond repute
Re: IFI Loader problems
??? lmk Thanks
I have never seen this. I use XP Home and have had no issues. Assuming your computer does not have a serial port, I would suspect your USB to Serial converter driver is at fault. Do a search for USB on these fori and you will find several threads which talk of problems with some converters.
Good luck.
Mike Betts
Alumnus, Team 3518, Panthrobots, 2011
Alumnus, Team 177, Bobcat Robotics, 1995 - 2010
LRI, Connecticut Regional, 2007-2010
LRI, WPI Regional, 2009 - 2010
RI, South Florida Regional, 2012 - 2013
As easy as 355/113...
Unread 19-01-2004, 14:06
Astronouth7303's Avatar
Astronouth7303 Astronouth7303 is offline
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Astronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud of
??? lmk Thanks
I have had problems with the loader, too. In My case, a legacy device claims an IRQ that COM2 uses. But mine just locks up.
Common Troubleshooting Steps:
1. Check What port your cable is connected to, and what COM Loader is using
2. Change What port your using
3. Check your hardware settings (Turn FIFO buffers off, just in case)
4. Reboot
5. Reinstall IFI_Loader
6. Recompile
7. E-mail IFI. they're real nice.
Some not-so-common Steps:
8. Remove unnecesary hardware (Modems frequently take the place of a COM port)
9. Barrow your friend's boot drive and use that (put hex on floppy)
10. Try safe mode
11. Is it actually a COM port?
12. Remove COM Mice (Use PS/2 or USB, if you can)
13. Check Bot
14. Check cable
Unread 19-01-2004, 15:11
Bharat Nain's Avatar
Bharat Nain Bharat Nain is offline
Bharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond repute
Send a message via AIM to Bharat Nain Send a message via MSN to Bharat Nain
??? lmk Thanks
Blue Screen ... It hapenned to me with some other hardware stuff, I re-installed XP, and it worked fine thereafter. Try that if nothing works.
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 20-01-2004, 01:29
I am using the usb to serial adapter... it turns out that I wasn't configuring the ifi app with the correct com port for the adapter. It was still weird getting that bsd... somewhere there is a bug to be squashed.
Thanks for the quick replies!
BS
Unread 31-01-2004, 04:59
WizardOfAz's Avatar
WizardOfAz WizardOfAz is offline
Lead Mentor
AKA: Bill Bennett
FRC #1011 (CRUSH)
WizardOfAz will become famous soon enough
Send a message via AIM to WizardOfAz
Just tried to switch from my laptop (working fine) to the computer in the shop for s/w development. The IFI_LOADER downloads the .hex file apparantly fine, but just as it is finishing we get stuck. Specifically:
the download window says "programming"
the terminal window pops up but displays nothing
the PROGRAM STATE light on the RC (EDURC in this case) stays orange
if I turn off then on the RC it's still orange
However, if I download the code from my laptop then use the shop computer IFI_LOADER to display the terminal window only (no download) it works fine.
Anybody seen this or have a suggestion? I will try a different com port when I go in later this morning, the computer has two.
Bill
Unread 31-01-2004, 08:39
WizardOfAz's Avatar
Lead Mentor
AKA: Bill Bennett
FRC #1011 (CRUSH)
Tried com2, no difference. Upgraded com driver, that didn't help either. Upgraded to most recent (1.07) IFI_LOADER, still same problem. Anybody got an idea?
Unread 12-02-2004, 18:42
Tridelvior Tridelvior is offline
Windbringer
#0348
Tridelvior is an unknown quantity at this point
I just got the blue screen and have been getting the blank terminal window for a while now. I have no idea what made it do that.
Team 348 Programmer/Animator/Slacker
Minion #341
Unread 12-02-2004, 19:57
Windbringer
#0348
oh goody. I just had the problem with the orange lights also. bad. very bad. HELP!!!!!!
Minion #341
Unread 13-02-2004, 09:10
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Ryan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud of
Bill
Is the OI on and either tethered or in radio contact to the RC? The prgram won't run unless the two are in contact, meaning the program state LED will be orange.
Unread 13-02-2004, 09:37
WizardOfAz's Avatar
Lead Mentor
AKA: Bill Bennett
FRC #1011 (CRUSH)
It's the EDU-RC (see above) so no tether, no OI.
It works fine (see above) with a different computer, so it's not an RC issue, except maybe as regards program download and serial port management.
Bill
Unread 13-02-2004, 10:40
Programming User
Bill
Didn't see the EDU part.
Unread 13-02-2004, 13:58
emusteve's Avatar
emusteve emusteve is offline
AKA: Steve Martin
#0470 (Alpha Omega)
emusteve is just really niceemusteve is just really niceemusteve is just really niceemusteve is just really nice
I've had some strange results with our edubot and the IFI Loader. I often have to load the new code to the edubot 2 or 3 times before it will take. I've just learned never to assume it's my fault if the code doesn't fire up the first time. Anyone else seen this?
Steve
Unread 15-02-2004, 18:03
n00b's Avatar
n00b n00b is offline
N00BIE!!!~
#1148 (The Saracens)
n00b is an unknown quantity at this point
??? lmk Thanks
bill:
you know what, i have the exact same problem with the exact same system... except i have a 2.8 ghz p4 ...
  #15   Spotlight this post!
Unread 16-02-2004, 17:36
Meredith Rice's Avatar
Meredith Rice Meredith Rice is offline
None #0433 (Firebirds)
Meredith Rice has a spectacular aura aboutMeredith Rice has a spectacular aura aboutMeredith Rice has a spectacular aura about
Send a message via AIM to Meredith Rice
For the last two days, every time I try to download a program to the RC with IFI, I get this pop up dialoge box saying
Run Time Error '76':
Path Not Found
This is after I bring up IFI and browse for the .hex I want. It happens with any program, even ones I havent touched. Anyone know what this means and how to fix it?
I'm proud to be a....
~*Looks like I've got FIRST fever again*~
IFI Loader Keys Programming 6 02-02-2004 14:37
IFI Loader for Linux rwaliany Programming 7 08-01-2004 01:48
Bug in IFI Loader rwaliany Programming 2 06-01-2004 21:26
IFI Loader on ME LBK Rules Programming 1 18-12-2003 17:49
Radio problems -- not archiver 2000 1 23-06-2002 22:23
