mounting of the small gear directly to the shaft of the drill
is there an easy way to mount the smaller gear provided in the kit directly to the output shaft do the drill motor?
(its the one that does not accept the 5/8 chanelled rod through it) and has not hub on it) thanks dahl |
| Coupling the drill motor with out the 15 tooth gear | Chopper_Dave | Motors | 1 | 17-01-2004 01:06 |
| drill motor mounting | whynot | Technical Discussion | 3 | 03-02-2003 08:24 |
| Cheap small gear source | archiver | 2000 | 2 | 23-06-2002 22:33 |
| "Motors and Drive train edition" of Fresh From the Forum | Ken Leung | CD Forum Support | 6 | 29-01-2002 12:32 |
| Connecting new gear to shaft? | mnkysp6353 | Technical Discussion | 10 | 29-01-2002 05:12 |
