Go to Post *quick grab the epoxy we can rebuild him, make him stronger than before* - amos229 [more]
Thread Tools Rating: Thread Rating: 6 votes, 4.83 average. Display Modes
Unread 19-01-2004, 15:14
WindTech WindTech is offline
AKA: Mitch Thompson
FRC #0481 (The Hitchhikers)
WindTech will become famous soon enoughWindTech will become famous soon enough
Send a message via AIM to WindTech
Lightbulb USFIRST Simulator 2004 (Play the playingfield in 3d)
Well...i brought something similar to this to my team last year, never finished it unfortunately. so, i figured i'd put somethin together for this year
its not done yet, but the physics are in place and all thats really left is making it user friendly to mod and start playing with different drive types, arms, features, so forth.
Capabilities:
Full integration of all obstacles/objects on the playing field
Dual-channel commands for 2 driver systems (as shown)
6 drive-shaft support (3 force applicators each side or whatever u want)
10 additional usable "joints" for functions in our imaginations
Generally handles at 210fps with over 80 moving objects on the screen.
Average poly count limit of 3500 (depending on your system really...)
Physics calculated: friction, viscosity(balls squish when proper force is applied and piping bends), torque, acceleration, gravity (yes you can change it ;p), mass (gravity wouldn't be much without mass now would it?), collisions, misc other things nobody thinks about often, and soon to be heat tolerance. All will be exportable to an excel document for later analysis; test database ports range in size from 10kb to 1.8mb.
In progress (and well on their way too)
USB joystick support (sidewinders are useful for this one - 15-pin works too...but how many people have 2x 15pin ports in their box?)
Non-code intensive modding system (just assign the variables)
C and PBASIC(leftovers from last year) code parser for testing
Its Shockwave/Macromedia Director(tm) based and ColdFusionMX is my best friend on this one. Online based 2v2's are coming...I'll host a server when I get it running (peer to peer is a pain in the rear because I'm too lazy to go and code another xtra just to do it...the physics for this are bad enough ;p)
Well, heres the link, and go ahead and enjoy
USFirst Simulator 2004
Oh btw...yes...the bot is a box...why? because i didn't feel like shoving anymore graphics onto an alpha test
And yes, I know there are field objects missing (like this is a hard problem to fix...) the core program is literally an engine - pseudocode generates the objects on the level itself for easy modification.
Controls: (temporary joystick for drive only)
the drive operates independant of the chassis
Q W E
A -- D
Z X C
Left/Right arrows - rotate chassis for positioning
Up/Down arrows - when stationary, these will pop the respective front/back sides of the bot (based on drive angle, not chassis) off the ground in order to climb the stairs (or you could use tires/treads but I'm just showing off the physics now ;p). Be fore-warned, the up/down arrows have no restrictions for debug purposes, if you hold them down, your bot will continue to rotate, and eventually cart-wheel out of the arena only to return when you exit/restart the program ;p
Notes:
ctrl+click the red mobile goal to push it around a bit; debug tool
one of the purple balls (start clicking) can be clicked/dragged about to try throwing it into the closer of the stationary goals (yes, it will bounce off of each of the individual pipes properly). The mobile goals only work properly with the 2X ball atm so if you manage to get it up there, take a screen shot ;p
If you encounter any scipt errors, or any problems, please post them here or contact me other wise so that I may start fixing them.
email: craftgod@earthlink.net
aim: Fenrisul
back-up email: wind@xdtech.net
Oh yeah, one last thing...no Autodesk products were used in the making of this simulator, NEWTEK FOR LIFE!!! (and of course macromedia )
Till then, peace. (And keep building!)
Unread 19-01-2004, 15:25
Bharat Nain's Avatar
Bharat Nain Bharat Nain is offline
Bharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond repute
Send a message via AIM to Bharat Nain Send a message via MSN to Bharat Nain
Re: USFIRST Simulator 2004 (Play the playingfield in 3d)
Awesome , not too many objects, but its fun when you have nothing to do
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 19-01-2004, 16:32
SpaceOsc's Avatar
SpaceOsc SpaceOsc is offline
16 Years of FIRST!
AKA: Oscar Vasquez
FRC #4501 (Humans)
Team Role: Coach
SpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant future
Send a message via AIM to SpaceOsc Send a message via Yahoo to SpaceOsc
Wow!!! i thought i was the only one that away wanted one of these. cool!
Im not Game Programer so i must ask how do u modify it?
Id like to be able to see the field from another camera angle
2014-2017: Team 4501 Coach/Lead Mentor
2002-2011: Team 702, Mentor
2001-2002: Team 702 Captain
Unread 19-01-2004, 16:53
ebmonon36's Avatar
ebmonon36 ebmonon36 is online now
AKA: Eric Bredehoeft
FRC #1018 (Robodevils)
ebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud of
Send a message via AIM to ebmonon36
That is so cool.
I moved the red goal and it hit the blue goal and flew off the screen. Then I stood the robot on end and drove it into a pile of balls against the wall and..welll...it's gone now too.
Eric
Unread 19-01-2004, 16:57
IMDWalrus's Avatar
IMDWalrus IMDWalrus is offline
This is a line...
AKA: Paul
FRC #0818 (Genesis '02)
IMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to behold
Send a message via AIM to IMDWalrus
Nifty. I love this little program!
One suggestion: could you possibly make it so that ALL of the balls are user-movable? That would make this little gem an even better timewaster...
[edit]It's already been suggested, but an option for multiple camera angles would be nice too. Then again, I can't program games very well, so I have no idea how hard it would be to do. Again, great job.[/edit]
Unread 19-01-2004, 17:05
AKA: Mitch Thompson
there are only a few objects on the field for debugging purposes, no reason to clutter it yet, but i assure you it works
Camera angles are coming, in the fashion of birdseye view (starcraft style ;p), freefly, drivers perspective, from each of their respective locations, audience view, and robo-cam (which will appear in a small side window and probably have some sort of avi-recording capability if i have enough time, but that stuff isn't on the top of my list)
modifying these things will be a snap, it'll be just like using a really simple CAD program, and placing objects such as motors, hydrolics, telescoping poles, and other misc things that will save to a file when you are done, allowing (when i finish the inet play anyway) other players to 'download' your design and play against it.
Due to the nature of this program, I didn't make it to look pretty, noting the lack of any kind of texture what so ever. It is designed to provide accurate results for testing out a design concept without actually having to physically build it first. I think if I put enough work into this...rapid development of conceptualized bots wont feel quite the same afterwards...
This whole thing is gonna be open source when I get it to a nice clean point and put in a bunch of comments/guides, till then if anybody here is familiar with Director, Lightwave, 3ds max, ColdfusionMX, or PHP, please by all means feel free to offer some talent.
Unread 19-01-2004, 17:29
Rickertsen2 Rickertsen2 is offline
Umm Errr...
None #1139 (Chamblee Gear Grinders)
Rickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant future
Send a message via AIM to Rickertsen2 Send a message via Yahoo to Rickertsen2
Wow. Very nice job. I see this really going somewhere.
3d stuff is not an easy feat. I speak from(limited) experience. You should feel proud.
<chopy sentences>Its pretty primitive at this point, but a feat none the less... The balls squish? I can't get that to happen. Nor can i get the bars to bend. Model heat tolerances? But why? Will there be texturing? The lighting is a bit dark. </choppy sentences>
1139 Alumni
Unread 19-01-2004, 17:32
Joe Matt's Avatar
Joe Matt Joe Matt is offline
Wake Up Get Up Get Out There
Joe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond repute
Call me sadistic, but I love throwing robots and goals out of the field like they were pieces of paper, only to see them fly off the field and into the abyss.
Improve the graphics, add a build-a-robot option, include AI, and you can really have a good product here! Imagine playing against human AI from famous FIRST teams! This has infinate possablilites!
Unread 19-01-2004, 17:36
Francis-134's Avatar
Francis-134 Francis-134 is online now
Lifer
FRC #0190 (Gompei and the Herd)
Francis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond repute
Talking Re: USFIRST Simulator 2004 (Play the playingfield in 3d)
OMG, this is so cool! I just cant wait for you to finish! You probably have already though of this, but when you come out with the next release, could you put something on the robot so we can tell which way is front and which is back?
Has anyone done this before in past years?
Email | Twitter | Facebook | YouTube | Twitch
iTunes Podcast | Snapchat
A proud alumnus of teams 134 and 40 || Mentor of Team 190 || Director of Fun for BattleCry@WPI
Unread 19-01-2004, 17:54
AKA: Mitch Thompson
from coder to coder, thanks
the graphics are going to stay like that until I find a reason to improve them, its designed to test concepts, not looks. however once the core is done and the arena functions completely properly and i've worked out more of the physics based on De Anza's practice field, you'd better believe i'm going to use up all 3500 of those excess poly's per model and weld some running lights on to the bottom of my bot ;p
and in terms of build a bot, i already said its being added, heh, mostly done too...just need to clean it up so i dont have uber traffic when i put up the multiplayer server ;p
This is for USFIRST, which means its used for learning and development of skills; not for selling or personal profit, thats what Event Alpha is for On top of that...I'm only 16...poor white boy livin in a relatively ghetto area, have the laptop i built, have a g/f, and am leaving HS in 4 days to go into the world a bit further before full time college, what do i need money for potatoes for me thank you very much ;p
Oh yea...and for all of you out there who have been flipping my green box bot off the edge then dropping the goals on top of it in the abyss, i'm going to need some beta testers to push the limits and glitches out of my core; aim/email me ;p
Unread 19-01-2004, 18:33
IMDWalrus's Avatar
This is a line...
AKA: Paul
But the glitches are the fun part!
Unread 20-01-2004, 08:37
Joe Matt's Avatar
I agree totally with you. FIRST should always be non-profit for everything unless impossable. Mabey I should clarify my last statement. When I mean product, it probably ment something like a freeware app, not a cost per unit thing. Mabey the better word instead of product would have been service, or even software for basics. I'm just saying that the compelation of software, time, and other things could make this very good.
Unread 20-01-2004, 09:33
Swan217's Avatar
Swan217 Swan217 is offline
RoboShow Producer
AKA: DJ Royal Fusion
no team (RoboShow)
Rookie Year: 1999
Swan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond repute
Send a message via AIM to Swan217
Don't you gamers have a Robot to build? 4.5 weeks left...
Good job though...
Orlando Regional Planning Committee & Cohost of The RoboShow & RoboVision
Follow The RoboShow on Twitter @RoboShowLive & check out our website, www.theroboshow.net
Follow RoboVision on Twitter @RoboVisionOD & check out our website, www.robovisionod.com
"As president, I believe that robotics can inspire young people to pursue science and engineering. And I also want to keep an eye on those robots in case they try anything."
— President Barack Obama
Unread 20-01-2004, 15:41
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Rookie Year: 1996
dlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond repute
I'll make a trade with you. I did the entire kick-off animation with Lightwave, including all the models, texturing and rendering (the whole thing was done in 18 days, while interleaving work, family and about 5 minutes of sleep per day next year, I REALLY want some more lead time so I can make it more photo-realistic!). I will happily send you all the .lwo and texture files for incorporation into your simulator. In exchange, can you make a Macintosh (OS X)-compatible version?
-dave
"I know what you're thinking, punk," hissed Wordy Harry to his new editor, "you're thinking, 'Did he use six superfluous adjectives or only five?' - and to tell the truth, I forgot myself in all this excitement; but being as this is English, the most powerful language in the world, whose subtle nuances will blow your head clean off, you've got to ask yourself one question: 'Do I feel loquacious?' - well do you, punk?"
- Stuart Vasepuru, 2006 Bulwer-Lytton Fiction Contest
My OTHER CAR is still on Mars!!!
  #15   Spotlight this post!
Unread 19-01-2004, 23:33
Andrew Rosselet Andrew Rosselet is offline
None #0188 (The force from the north)
Andrew Rosselet is on a distinguished road
Send a message via MSN to Andrew Rosselet
I like ur way of thinking...
Tis quite nice, however, as you said, the user interface needs some work. I was wondering why my robot and mobile goal kept cartwheeling out of control and flying off the field. Overall tho, tis a pretty good program .... Keep up the good work!
a robotics play Mike Persico Chit-Chat 40 15-04-2003 13:44
What team are do you want to play with at nationals? Solon Jhee Championship Event 1 23-03-2003 20:38
Do all three team have to play in finals??? Scott358 Rules/Strategy 8 16-03-2003 11:00
Did anybody get the GMA video to play archiver 2001 1 24-06-2002 02:43
Petition to allow us to play music. (not my idea) archiver 2000 6 23-06-2002 22:15
