Palm OS Dashboard PRGM
Ok, let me begin by saying that i have searched for this, and found only discussion.
Is there anyone out there who has a working dashboard program for palm os? Thanks |
Re: Palm OS Dashboard PRGM
Great Idea. But unless you have a VB compiler for PalmOS, then your out of luck (Like anyone has the time anyway!)
not necessarily - a dashboard doesn't have to be written in vb, it just needs to be able to accept serial input, which is perfectly possible for the palm (its sync port is a serial port).
I ment that's all I do.
Once we all get familiar with C, there's a neat (read "free") little compiler for the Palm OS called "Pocket C" that might be usefull for writing a dashboard utility.
I have a palm program written in C that gets data from the dashboard port then prints it to the screen. It will be a dashboard program eventually I just haven't finished it yet. I will probably finish it after the robot ships.
I'm also working on wiring an LCD to the dashboard port. Right now I have it working with the RC, but it will be more work to actually get it hooked up to the dashboard. |
I've done some Palm development before. The actual program coding isn't very hard as the API is pretty straight forward but I have no idea about the serial access. I imagine it would be much harder than coding for the GUI. You might want to search in the developers section of palm.com or on google (you need to sign up, I believe, for palm.com but it is free).
do palms use windows CE? I have eMbedded Visual C++....which develops applications for windows CE...i could pretty easily port a dashboard program i would think, since all this stuff is .NET now....
i was kind of thinking they were completely different...oh well.
#11
By the way, serial access in Palm, like many other OSes, is actually quite simple. It's just like reading a file in windows. You just call a get function (can't remember the exact syntax right now) and tell it how many bytes you want to get. You can also check how many bytes are in the buffer and many other useful functions.
The hardest part about Palm programming is how anal it is about memory management. If you leak any memory or use a pointer where you should use a handle there is a good chance you will hit a fatal error. |
| New dashboard packet spec | Ameya | Programming | 2 | 08-01-2004 19:59 |
| How About A Palm Dashboard Program? | archiver | 2001 | 0 | 24-06-2002 00:52 |
| New Innovation FIRST control system and the dashboard | archiver | 2000 | 0 | 23-06-2002 22:15 |
| Palm Dashboard Software | Neal Probert | General Forum | 4 | 06-05-2002 14:16 |
| Scouting/Scoring System for Palm M3 | A. Leese | Scouting | 12 | 24-07-2001 23:31 |
