Go to Post The bottom line is this program means the world to me ,and the friends i hold dear that feel the same way....I believe it changes lives and outlooks on reality. - D@ve [more]
Unread 20-01-2004, 18:06
Jeremy_Mc's Avatar
Jeremy_Mc Jeremy_Mc is offline
GitHubber
Jeremy_Mc will become famous soon enoughJeremy_Mc will become famous soon enough
Angry If you're having MPLAB problems, LOOK HERE.
I've seen about 5 threads dealing with the same thing.
Issue #1 - USB to Serial Adapters
If you're having problems finding a driver
Look on the MPLAB CD
-or-
http://www.driverguide.com
(User=driver, password=all)
If you don't know the name of your hardware, we can't help you.
If you're using a USB to Serial Adapter and MPLAB crashes alot
Get a new or updated driver. There is a very high chance that is the cause.
(See above item for driver locations.)
Issue #2 - Compiling Problems
Library Not Found or Related Issue
Make sure your libraries directories are properly set.
Go to Project > Build > Project.
Set the 4th and 5th boxes to [Drive Letter]:\[Path to C18]\h for Include Path
[Drive Letter]:\[Path to C18]\lib for Library Path.
Syntax Error
PLEASE refer to your C book/website/good friend that knows it FIRST. DO NOT post a thread just to ask if you can use "short int." MicroChip makes these documents available for a reason.
Search CD for a list of C Programming materials.
Issue #3 - Anything Else
SEARCH.
SEARCH. SEARCH. SEARCH.
SEARCH.
or ask in this thread.
PLEASE stop posting the same question about this stuff OVER AND OVER.
Thank you.
GitHub - Collaborate on code, documentation, etc. - http://github.com
Im Having Problems With Mplab!!!! hedgehogger Programming 2 20-01-2004 17:43
Im am having trouble with the MPLAB hedgehogger Programming 7 19-01-2004 17:37
using the MPLAB IDE MPLAB SIM simulator WizardOfAz Programming 1 03-11-2003 01:24
Joystick problems archiver 2001 3 24-06-2002 02:40
Radio problems -- not archiver 2000 1 23-06-2002 22:23
