Go to Post A good way to minimize the possibility of breaking things is to minimize the number of things that can break. - s_forbes [more]
Unread 20-01-2004, 19:22
hatmaninc hatmaninc is offline
hatmaninc is an unknown quantity at this point
Question SynEdit for Delphi
Is anyone here familiar with the SynEdit components?
I'm using delphi 5 and I cant get the SynMultiSyn component (SynHighlighterMulti.pas) to work. Every time I use it I get an error, and the debugger highlights a bit of code where it calls a function:
DefaultHighlighter.ResetRange;
Is it something I'm doing wrong, or is there a problem in the code?
SynEdit can be downloaded from the SynEdit Download Page
Unread 20-01-2004, 19:29
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Re: SynEdit for Delphi
This forum is not for the Delphi programming. It is for FIRST Robotics.
Unread 20-01-2004, 19:31
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
Sorry, these forums aren't for Delphi, as it were. Delphi is an automotive company, as opposed to Borland Delphi. You might want to check the product page for SynEdit. Apparently, there's some example code for using SynEdit components at this website (about half way down the page).
Sorry for having to disappoint you. Maybe someone else on these forums may have the knowledge to help you, but the chances aren't as good as if you were to ask your question on a dedicated Delphi forum.
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
