Go to Post Remember, never underestimate the determination of thousands of FIRST students! - Jay H 237 [more]
Unread 20-01-2004, 20:24
LamdaCubed LamdaCubed is offline
AKA: Eric Fischer
#1372 (Lamda Cubed)
Team Role: Teacher
LamdaCubed is an unknown quantity at this point
2004 Drill motor and gear assembly number
I know where to order the drill motor and gear assembly from BUT I am confused about what number to order??? Anyone know? Thanks!
Unread 21-01-2004, 08:08
Unsung FIRST Hero
Ed Sparks Ed Sparks is offline
Engineer/Mentor/Inspector
AKA: FirstCadLibrary Guy, Inspector Dude
FRC #3959 (Formally with FRC-34)
Rookie Year: 1996
Ed Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond repute
Send a message via AIM to Ed Sparks Send a message via Yahoo to Ed Sparks
Re: 2004 Drill motor and gear assembly number
Gear Assembly - 2 606 200 917
Motor & Pinion - 2 607 022 890
The part numbers are printed on the boxes of these parts provided in your kit.
Ed Sparks
MECH TECH FRC-3959
Unread 23-01-2004, 15:32
Unsung FIRST Hero
Mike Betts Mike Betts is offline
Electrical Engineer
Rookie Year: 1995
Mike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond repute
Maybe I'm just having a senior moment, but I can not find the gear ratios of the Bosch drill gearbox anywhere... I know they are different than 2001 and I was not involved too much in 2002.
When I searched, I found a reference to low gear being 42.62:1
Anyone know?
Mike Betts
Alumnus, Team 3518, Panthrobots, 2011
Alumnus, Team 177, Bobcat Robotics, 1995 - 2010
LRI, Connecticut Regional, 2007-2010
LRI, WPI Regional, 2009 - 2010
RI, South Florida Regional, 2012 - 2013
As easy as 355/113...
Unread 27-01-2004, 21:03
david.clark david.clark is offline
david.clark is an unknown quantity at this point
Can anyone tell me where to order these motors from? The KOP lists boschtools.com as the supplier, but when I go there a search for the part # it doesn't find anything.
thanks
Unread 27-01-2004, 22:47
Matt Adams's Avatar
Matt Adams Matt Adams is offline
b(o_o)d
FRC #1525 (Warbots)
Rookie Year: 2000
Matt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond repute
Send a message via AIM to Matt Adams
Post Drill Motor Gearbox
The official information is as follows, all per various authentic sources... I took the time to compare actual test data to find the most likely information.
High Speed
Gearbox Ratio (Speed Input : Output)
12.07
Expected (RPM)
1629.66
Actual (RPM)
1521
Efficiency (%)
93.3%
Low Speed
42.62
Expected (RPM):
461.52
Actual (RPM):
450
Efficiency (%) *
97.5
* The 450 RPM is was was published in the game manual in 2003. I would expect it's efficiency to be not so high... dock that to around 400-425 or so would probably be a little more accurate...
I'll be posting a full Excel spreadsheet with all of the info very shortly, to compliment all of the data into one nice source.
Matt
Matt Adams - Engineer at Danaher Motion
Team 1525 - Warbots - Deerfield High School
