Go to Post The best moments of our lives fall in two categories: those that did happen and those that did not. - Jnadke [more]
Unread 22-01-2004, 03:09
lasindi lasindi is offline
FRC #1164 (Project Neo)
lasindi is an unknown quantity at this point
bool Variables, Autonomous Mode
First off, can you declare bool variables? I tried to compile a boolean variable, just because 1 bit is more efficient than wasting a whole byte on a char or 2 on a short.
Second, I looked at ifi_aliases.h in the default code. At the bottom it uses a #define compiler directive to define the macro autonomous_mode. Could anyone show me how to use this? Would you use code like
if(autonomous_mode)
/* Do whatever I want the robot to do during autonomous mode. */
in the Process_Data_From_Local_IO() function user_routines_fast.c?
Thanks for the help.
lasindi
Unread 22-01-2004, 07:35
Astronouth7303's Avatar
Astronouth7303 Astronouth7303 is offline
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Astronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud of
Re: bool Variables, Autonomous Mode
First off, you can't just use 1 bit. it has to be in a structure with 7 others. If you want just 1 bool, I would use char and set it to 0 or 255
Unread 22-01-2004, 07:49
Travis Hoffman's Avatar Unsung FIRST Hero
Travis Hoffman Travis Hoffman is offline
O-H
FRC #0048 (Delphi E.L.I.T.E.)
Travis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond repute
IFI set up a type structure called "bitid" for defining 1-bit variables:
Declare your variable:
bitid statusbyte
Define your macros:
#define gearstatus statusbyte.bit0
#define wingstatus statusbyte.bit1
#define wheeliestatus statusbyte.bit7
Seems to work fine.
Hope this helps.
Travis Hoffman, Enginerd, FRC Team 48 Delphi E.L.I.T.E.
Encouraging Learning in Technology and Engineering - www.delphielite.com
NEOFRA - Northeast Ohio FIRST Robotics Alliance - www.neofra.com
NEOFRA / Delphi E.L.I.T.E. FLL Regional Partner
Unread 22-01-2004, 10:00
Guest
Posts: n/a
By default, if you use a char to store "boolean" values, 0 is false and everything else is true. However if you have:
Code:
char boolVal=0;
boolVal=!boolVal;
// boolVal is now 255
Hence, you probably want to #define the following:
Code:
// Put this in a header file that every .c file accesses
typedef char bool;
#define true (char)(255)
#define false (char)(0)
Be sure to watch out for automatic cast of anything below above -1 and below 256 to an unsigned char.
Unread 22-01-2004, 10:02
Guest
Posts: n/a
And, there's no such thing as a real boolean variable in C, only in C++.
Unread 22-01-2004, 20:36
Thanks a lot for the help with the boolean variables. Could someone answer my question about using the autonomous_mode macro?
Unread 22-01-2004, 22:26
Guest
Posts: n/a
Where to put your auto code:
Code:
* FUNCTION:  User_Autonomous_Code()
* PURPOSE:  Executes user's code during autonomous robot operation.
* 	 You should modify this routine by adding code which you
*	 wish to run in autonomous mode. This executes every 26.2ms.
* CALLED FROM: main.c/main()
* PARAMETERS:  None
* RETURNS:  Nothing
void User_Autonomous_Code(void)
  while(autonomous_mode)
	if(statusflag.NEW_SPI_DATA)
		Getdata(&rxdata);   // bad things will happen if you move or delete this
		// autonomous code goes here
		Putdata(&txdata);   //even more bad things will happen if you mess with this
how can you use a gyro in autonomous mode magical hands Programming 3 02-01-2004 13:31
Help On Coding 2K1 Controller GregTheGreat Programming 9 05-12-2003 18:35
Programming Autonomous mode Jared Stofflett Programming 3 11-11-2003 09:32
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
autonomous mode timer Don Programming 6 09-02-2003 22:16
