Go to Post If FIRST makes a field invisible to the audience, I will buy every team a dozen Krispy Kremes. - Chris is me [more]
Unread 22-01-2004, 21:51
CyberWolf_22's Avatar
CyberWolf_22 CyberWolf_22 is offline
Programming and Electrical Mentor
AKA: Allen Gregory
FRC #2587 (Afrobots)
CyberWolf_22 is just really niceCyberWolf_22 is just really niceCyberWolf_22 is just really niceCyberWolf_22 is just really nice
System Requirements for Dashboard
What are the minimum system requirements for running the standard Innovation First Dashboard viewer (2004 controller)?
Unread 22-01-2004, 22:34
Adam Shapiro's Avatar
Adam Shapiro Adam Shapiro is offline
FRC #0555 (Montclair Robotics)
Adam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud of
Send a message via AIM to Adam Shapiro
Re: System Requirements for Dashboard
That's a good question! I'm not sure about the new version but it is probably not much different from the old one. The old version was able to work on a 100Mhz laptop running Win95. My guess is that it can run on a similar system as there haven't been many GUI additions, only new spec additions.
Mentor to Teams 555, 1929, and 2070!
Currently working in hardware design at Cisco.
Cornell University DARPA Urban Challenge - http://www.cornellracing.com
Co-Captain Team 555 - 2003,2004,2005
Trust, Love, and Magic
Unread 22-01-2004, 23:38
Damian Manda's Avatar
Damian Manda Damian Manda is offline
The Damian
Damian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud of
Send a message via AIM to Damian Manda
I installed it today on a 200? MHz machine with 64MB RAM running Windows NT 4.0. The screen needed to be in 1024x768 mode to work though. Otherwise, parts of the program would be off the screen, and there does not seem to be any way to change the window size (no resize handles, maximize button disabled).
--Damian Manda
Unread 23-01-2004, 09:20
Unfortunately there are a lot of new display items on the dashboard which require screen space. Because the display is not modifyable (as to component usage) you can not resize the window.
Unread 23-01-2004, 14:03
Astronouth7303's Avatar
Astronouth7303 Astronouth7303 is offline
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Astronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud of
I asume the dashboard was written in VB6 (like the IFI_Loader). If thats true, then you will need to have (and support) 2 DLLs:
-the VB6 runtime
-The mscomm control (mscomm32.dll?)
Likely, if you already have updated versions of these, you won't even need to install! If you need them (Or have Windows ME, which might make the install spit at you), PM me with an e-mail address and I'll send you an install for a dummy-comm app. That should install the need DLLs.
The exe itself is in the cab (it's a standard cab), Extract it out of that. It should run fine. And for anyone worried about there system being too old, VB still provides support for Pentium procs with FDIV probs.
What do you wish you knew about the new control system? Joe Ross Control System 2 09-01-2004 21:47
openFIRST switches debugging system to Bugzilla Timothy D. Ginn FIRST-related Organizations 0 28-12-2003 00:32
Need a FIRST Robotics control system kershawrobotics General Forum 3 07-07-2003 09:49
control system worth more than $500 archiver 2001 8 24-06-2002 02:00
New Innovation FIRST control system and the dashboard archiver 2000 0 23-06-2002 22:15
