Go to Post Welcome to ChiefDelphi.com. Get ready for the craziness. - Andy Baker [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 23-01-2004, 18:38
pryoplasm's Avatar
pryoplasm pryoplasm is offline
Pit Crew/Electrical
AKA: Russ
#0069
pryoplasm can only hope to improve
using older servos
i have some older servos from previous years. i was wondering if i could use them, the model i have from the kit of parts is HS-322HD and the older one(i think from about 3 years ago) is model HS-303, both servos are made by hitec. most likely a new set will be ordered, i was wondering if there is any technical differences that would make a flaw with things?
thanks in advance...
Unread 23-01-2004, 18:57
Unsung FIRST Hero
Mike Betts Mike Betts is offline
Electrical Engineer
Rookie Year: 1995
Mike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond repute
Re: using older servos
Go here: http://www.hitecrcd.com/product_fs.htm and check out the spec sheets for yourself. I can't do it for you right now as I am at work and the firewall here blocks me from that site (games)...
As I understand it, I would imagine that the 303 is not allowed under this year's rules as it is not a 322...
Mike Betts
Alumnus, Team 3518, Panthrobots, 2011
Alumnus, Team 177, Bobcat Robotics, 1995 - 2010
LRI, Connecticut Regional, 2007-2010
LRI, WPI Regional, 2009 - 2010
RI, South Florida Regional, 2012 - 2013
As easy as 355/113...
Unread 24-01-2004, 01:04
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Originally Posted by Mike Betts
Go here: [url]As I understand it, I would imagine that the 303 is not allowed under this year's rules as it is not a 322...
According to the Q/A (search for servo), servos fall under electronics (not motors). So, you would be able to use as many as you want, as long as you account for them in your $200 electronics budget.
Now, perhaps someone could ask why you can't use the motors from the EDUbot (which are basically servos) but you can use other servos.
Unread 24-01-2004, 20:12
pryoplasm's Avatar
Pit Crew/Electrical
AKA: Russ
#0069
i am not trying to make anything competition legal,i am wondering if they are technically comparable, and if they can be used interchangably...
Unread 24-01-2004, 20:22
NoRemorse's Avatar
NoRemorse NoRemorse is offline
FOCUS Integration, LLC - Owner
AKA: Brian Roberts
FRC #1023 (Bedford Express)
NoRemorse has a spectacular aura aboutNoRemorse has a spectacular aura about
Send a message via AIM to NoRemorse Send a message via MSN to NoRemorse
in that case, of course!
http://LSJBuildUp.com -Documenting the build of my LSJ, as well as other influential cars.
servos AlphaOmega870 General Forum 1 21-01-2004 17:37
Creative uses for servos? dddriveman Motors 34 19-07-2003 00:33
Can RC servos be used with EDUbot? ChrisH Technical Discussion 4 31-12-2002 01:45
Need help in creating program to use servo's to shift drive archiver 2001 19 24-06-2002 00:35
servos, chapulas, cylinders and Skyway...in other words... Jessica Boucher Motors 7 14-01-2002 19:36
