Go to Post Last I checked the Mars Rovers don't play any defense either and that's pretty cool stuff. - Rich Kressly [more]
Unread 24-01-2004, 11:38
Team 869 Team 869 is offline
Team 869 is an unknown quantity at this point
Mplab startup error
We've tried searching but no one else seems to have the same problem. When we run mplab ide a windows error occurs closing down the program. We've tried reinstalling multiple times but to no avail. Any help would be greatly appreciately.
Unread 24-01-2004, 13:50
hello world's Avatar
hello world hello world is offline
hello world has a little shameless behaviour in the past
Re: Mplab startup error
try reinstalling in a new computer. if it is a problem with one computer it should work. if it is the problem with the whole program, try getting a new MPLAB IDE 6.3 cd and reinstalling.
Unread 24-01-2004, 15:28
Jay Lundy Jay Lundy is offline
Programmer/Driver 2001-2004
FRC #0254 (The Cheesy Poofs)
Jay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to all
I had the exact same problem. In install, it says to ignore the USB stuff, so once the thing installed I pressed cancel when the USB install stuff came up.
You need to let that finish.
However, if you go into the MPLAB folder and run register.bat in the dlls folder, it will start working with your current installation.
Unread 24-01-2004, 19:48
Thanx guys, I will try what you said Jay. Yea it was weird because it worked on my computer at home. Thanx again.
Unread 24-01-2004, 23:17
Greg Ross's Avatar
Greg Ross Greg Ross is offline
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
Rookie Year: 1998
Greg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond repute
Send a message via AIM to Greg Ross Send a message via Yahoo to Greg Ross
I had a similar problem when I tried running the IDE on one of our junky old donated computers with Windows 98 (not SE). What OS do you have?
Greg Ross (The Grammar Curmudgeon formerly known as gwross)
S/W Engineer, Team 330, the Beach 'Bots
<--The Grammar Curmudgeon loves this cartoon.
“Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming "Wow! What a Ride!" Hunter S. Thompson
"Playing a practical joke means doing something mean and calling it funny." Me
Unread 25-01-2004, 04:30
Jeremy_Mc's Avatar
Jeremy_Mc Jeremy_Mc is offline
GitHubber
Jeremy_Mc will become famous soon enoughJeremy_Mc will become famous soon enough
If you're on a LAN make sure you're not running "roaming profiles." I know we have problems with MPLAB and Inventor with that. We'll logon to one computer and run the install and then logon on another computer and run the program that's been installed locally already but it tries to grab our config files from our user directory.
GitHub - Collaborate on code, documentation, etc. - http://github.com
Unread 25-01-2004, 10:41
Steven Carmain Steven Carmain is online now
Bit Twiddler
FRC #6013 (Robowolves)
Steven Carmain will become famous soon enough
We have old 98 (not SE) computers and it works fine. Make sure you don't install USB drivers. Also, you will get a message saying that the program might not function right?, but it works fine if you close it.
2016+ - Team 6013 Lead Engineer
2002-05 - Team 45 Software/Electrical
A robot is like a campfire: it takes a while to bulid it, and then everyone surounds it!
A world without standards is chaos. A world with standards is chaos.
If you're having MPLAB problems, LOOK HERE. Jeremy_Mc Programming 0 20-01-2004 18:06
using the MPLAB IDE MPLAB SIM simulator WizardOfAz Programming 1 03-11-2003 01:24
Basic Run Error BBFIRSTCHICK Programming 10 02-04-2003 22:43
EMERGENCY! EPROM FULL error?!? CHSguard72 Programming 2 05-03-2003 20:51
Basic Run Error Ulibrium Programming 12 21-02-2002 01:02
