Go to Post I think there is much to be learned from working in teams, and team projects, but even more when you go out on your own some time for something you are truly passionate about. - paul_v [more]
Unread 16-02-2004, 00:20
Robert Hafner's Avatar
Robert Hafner Robert Hafner is offline
FIRST Alumni
Rookie Year: 2000
Robert Hafner is on a distinguished road
Send a message via AIM to Robert Hafner Send a message via MSN to Robert Hafner Send a message via Yahoo to Robert Hafner
Re: Programming joysticks
Because the last bits are unreliable (from what i've read), how will this affect the program? Should I stick with a general area? example:
Code:
if (p1_wheel >= 42 && p1_wheel <= 46)
    // I am neutral
if (p1_wheel >= 250 && p1_wheel <= 254)
     // I am upperleft;
Unread 11-02-2004, 18:27
Astronouth7303's Avatar
Astronouth7303 Astronouth7303 is offline
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Astronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud of
Originally Posted by Joe_Ross
Why not #define them, instead of taking up memory?
I don't like using #define for constants. Besides, we've got memory to kill.
Unread 11-02-2004, 21:19
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
hmm... apparently the forum system managed to place a reply in a different thread... right.
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 12-02-2004, 17:54
Tridelvior Tridelvior is offline
Windbringer
#0348
Tridelvior is an unknown quantity at this point
Question Re: Programming joysticks
Do you know the non-binary values of the pX_wheel in their up- and down positions?
I am trying to use their values with a pwm and do not know what to use.
temp = p1_wheel;
if (temp==WHAT VALUE?[UP]){
pwm02=200;
else[DOWN]{
pwm02=55;
Team 348 Programmer/Animator/Slacker
Minion #341
Unread 02-02-2004, 11:11
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Ryan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud of
Originally Posted by FotoPlasma
Basically, if you can understand binary, you can take advantage of the POV hat for controlling your robot.
You also have to good at bit manipulation in C!
Unread 11-02-2004, 16:15
Erico Erico is offline
AKA: yoshi
#0618 (E.A.R.T.H squad)
Erico is an unknown quantity at this point
If u can make me a favor, can u teach me how to program the joysticks. I will appreciated. thank u
GOOD LUCK THIS YEAR
Unread 11-02-2004, 17:02
Computer Guy
AKA: Dav
the inputs from the joysticks are held in a range of variables (actually aliases), set up in ifi_aliases.h:
for instance, the x-axis of joystick one is p1_x
if you want direct joystick-to-pwm control, just use something like the following line:
pwm01 = p1_x;
Unread 11-02-2004, 17:15
Programming User
GOOD LUCK THIS YEAR
Just to expanded on what DeltaCoder said, the joysticks are refered to by pX_x and pX_y, where X is the port number the joystick is attched to. For example to access the x and y axises of the port one joystick you would use p1_x and p1_y.
The value that comes in on these pins is between 0 and 255 (an unsigned char). 0 is full to one side, 127 is center, and 255 is full to the other side. For instance, if you have the joystick all the way forward, p1_x would be 255 and p1_y would be 127. If you had it all the way to the right, p1_y would be 127 and p1_y would be 255.
You could also have a combination of the two, of course. For instance, if you where in the forward, right corner, you would get p1_x and p1_y both reading 255.
You can use these values in any way in your program. Just don't try to change their value in code; it won't work!
Hope that helps. Good luck.
Unread 24-02-2004, 20:26
iamjarret iamjarret is offline
iamjarret is an unknown quantity at this point
hey, i have a question
we plugged a motor to the pwn port that corresponds to p1_wheel(the wheel)
and teh operator interface shows that when we move the wheel, the values are changing (input), but it is not moving the motor. It is correctly mapped (pwm09 = p1_wheel
how can i get it to work
also, i would like to make code the made a pwm got to speen 255 when p4_sw_trig (trigger) is pushed(equal to 1).
my code so far is
if (p4_sw_trig == 1)
pwm12 = 255; (for this i commented out pwm12 = p4_wheel
i also tried p4_wheel = 255;
and i tried p4_wheel = 0xFC;
lastly, the y axis dose'nt work on ports 3 and 4 on any joystick i try
please help me fix my code, wheels, and y-axes
thanx
Unread 27-01-2004, 18:12
Smrtman5's Avatar
Smrtman5 Smrtman5 is offline
Dr. Bridgeport
AKA: Jon H
FRC #0041 (Robo-wariors)
Smrtman5 is on a distinguished road
Send a message via AIM to Smrtman5
I have two basic questions. First, can those old robot interfaces be programed for C or are they strictly the old stuff?
Second, does anyone have an old program with just the two joystick controls? All we want to do is hook up an old interface to a mock control board so we can make sure the trannys work.
(Note: Im the fabricator, the only thing i know about computers is how to break one)
Hopefully i can relay this answer to one of our more knowledgeable people. Thanks
Art is just an excuse for poor craftsmanship.
- Jon H
Team 41
Rowan University '10 Mechanical Engineering
Unread 27-01-2004, 20:31
Programming User
Do you mean the old robot controllers? If so, they can only do the old PBASIC stuff.
Unread 28-01-2004, 05:51
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
InnovationFirst has "Legacy Documentation" on their website. They have default code, written in PBASIC (for previous years' control systems), for both single and dual joystick driving. Here's a link to download those programs. They're listed under "PBASIC Code", but you will also need a copy of Parallax's computer program, in order to program your controller. Links are listed on that same website under "Programming Tools".
If you need any more assistance, feel free to ask.
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Programming Compatition Angela06 Programming 30 08-04-2005 23:12
Could use some help with joysticks . . . archiver 2001 5 23-06-2002 23:36
Pneumatics electrical wiring and programming archiver 2001 1 23-06-2002 23:10
Calibrating speed controllers and joysticks thedillybar Technical Discussion 4 11-02-2002 13:24
pbasic programming punarhero Programming 4 21-01-2002 23:32
