Go to Post Blasphemy! This is FRC we must over analyze everything! - Ginger Power [more]
Unread 24-01-2004, 18:59
Ryan Cumings's Avatar
Ryan Cumings Ryan Cumings is offline
Programmer and University Rejected
#0134 (Team Discovery)
Rookie Year: 2000
Ryan Cumings is an unknown quantity at this point
Send a message via AIM to Ryan Cumings
Code Repository
Would other teams be interested in sharing code with each other? Would anyone be willing to open a repository?
Unread 24-01-2004, 19:23
Obi's Avatar
Obi Obi is offline
Obi is an unknown quantity at this point
Re: Code Repository
What whould be the main purpose of a code repository? Ideas?
Unread 24-01-2004, 19:28
Guest
Posts: n/a
Re: Code Repository
A code repository defeats the purpose. Everybody should learn the programming (who wants to). Sure, we can share ideas, but we shouldn't use each other's code.
Unread 24-01-2004, 19:39
Rookie Year: 2000
Re: Code Repository
How about sharing code from years past?
Unread 24-01-2004, 19:47
briholton's Avatar
briholton briholton is offline
AKA: brian holton
#0752 (Gods of Fury)
Team Role: Coach
Rookie Year: 1997
briholton is on a distinguished road
Re: Code Repository
AHHH, glad to see your team is writing their own controller code entirely from scratch and not using ANY of the code provided by first. I do not know a single professional programmer that has not used someone else's code - it's SOP! I think the code vault would be superb not only so we all can learn from other folk's examples now, but for my classroom, i would use it throughout the year to teach with. kudos!
Unread 24-01-2004, 19:55
Guest
Posts: n/a
Re: Code Repository
Originally Posted by briholton
... not using ANY of the code provided by first ...
That's not what I meant. I don't think that we should put full implementations of specific things our robots will be doing.
However, I do agree with you that a repository would be a great place to learn and a great place to put general algorithms (like line following, etc.)
The reason why I think that full "ready-to-run" programs should not be uploaded to a repository because it encourages copy-paste. Yes, a big part of FIRST is learning from others. But a just as important part of FIRST is learning from discovery.
Unread 24-01-2004, 20:13
Rookie Year: 2000
Re: Code Repository
That is what I was kind of getting at for the idea about the repository. It took me a long time to figure out how to integrate the yaw rate sensor signal. Every place I looked did not have one example on how to do it. Granted I figured it about after about 12 hours of fustration. It just would make me wonder how long some of the other programers (minions) on my team might have taken.
Unread 24-01-2004, 21:13
Guest
Posts: n/a
Re: Code Repository
I'm currently implementing a repository at:
http://nrg.chaosnet.org/repository
Spread the word! Note: it is not finished, I'm working on it. And, you HAVE to register an account at the NRG website to be able to post code to the repository.
Hope you like it!
Unread 25-01-2004, 16:34
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
Re: Code Repository
well, i would go add my demo trig table code, but the register/login feature does not work yet, apparently. looking like it's going to be nice when it does, though!
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 25-01-2004, 16:42
Guest
Posts: n/a
Re: Code Repository
Are you sure it doesn't work?
Click "Register." Then enter the info into the fields.
Click register.
Then login using your username and password.
Unread 25-01-2004, 16:53
Computer Guy
AKA: Dav
Re: Code Repository
i get an http 404 when i click on the initial "Register" button.
Ian W. Ian W. is offline
College? What?
no team (Gompei and the Herd)
Ian W. is a name known to allIan W. is a name known to allIan W. is a name known to allIan W. is a name known to allIan W. is a name known to allIan W. is a name known to all
Send a message via AIM to Ian W.
Re: Code Repository
Two years ago, we tried this. It was called The FIRST Codex, and it was located at www.first-codex.net. It's since been taken down, as not enough interest was given by the teams at the time.
I would suggest speaking to Gui, he may be able to help set up some stuff, as he was one of the orignial people who set up the original site.
I don't know how many people remember this, but two years ago, Gui organized several programming meetings at Nationals, and we did have about 10 or 15 people come, if I remember correctly. I think that something that would be fun is if we can set that up again. I'll be attending the Championships this year, so if anyone else likes this idea, let me know and I'll try to set something up.
The idea for a code repository is a nice idea though, as long as it is kept up to date and moderated for potentially bad code (this is FIRST, but some people have weird notions of what "fun" is :-\). I say go all out for it, just make sure someone will be able to maintain it, lest it fall into oblivion (like the FIRST Codex did).
AIM --> Woloi
Email --> ian@woloschin.com
Unread 25-01-2004, 16:57
Guest
Posts: n/a
Re: Code Repository
Try this page:http://nrg.chaosnet.org/uploads/slog...l_reg=Register
Computer Guy
AKA: Dav
Re: Code Repository
When you click on what?
the initial "Register" button at the top of the Repository page.
  #15   Spotlight this post!
Unread 25-01-2004, 17:06
Computer Guy
AKA: Dav
Re: Code Repository
it seems that your form is currently pointing to "/repository/slogin.php", while the file is at "/uploads/slogin.php" - this probably isn't what you want. (note - the login form doesn't work either, same error message.
What is your most prefered programming language? Hailfire Programming 156 19-01-2005 21:42
InfraRed autonomous code ... mtrawls Programming 1 11-01-2004 00:25
Autonomous code PBoss Programming 7 14-01-2003 15:29
Does your team use the Default code. Jeff McCune General Forum 2 09-01-2003 14:46
Patent source code? Kyle Fenton Chit-Chat 3 20-10-2001 17:53
