Go to Post "Building the technology of tomorrow - sometime late tonight!" - dlavery [more]
Unread 24-01-2004, 21:27
CharlieWilken CharlieWilken is offline
#0634 (Robowolves)
CharlieWilken is an unknown quantity at this point
Drill motor brush support
The drill motors have an incredibly small piece of plastic that holds the brushes into the motor. This plastic can break with a 4 inch drop of the motor to the ground. We now have one broken and I cant figure a way to fix it. Does anyone have a technique for protecting this miniscule piece of plastic from breaking? Thanks in advance
Also does anyone have a fix for this broken piece. We are missing half the plastic piece.
Unread 24-01-2004, 21:40
dhendrix's Avatar
dhendrix dhendrix is offline
#0538 (Dragon Slayers)
dhendrix is an unknown quantity at this point
Re: Drill motor brush support
FIRST off, The drop test will work every time. Don't try that one any more.
Order a new one and a spare. We dropped one last year. The motor mount
that FIRST sends will hold the brush in. If I remember correctly.
Unread 24-01-2004, 21:49
KenWittlief KenWittlief is offline
KenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond repute
sometimes you can fix it with a small tie wrap.
Unread 25-01-2004, 00:07
Ryan Curry Ryan Curry is offline
FRC #0030 (FURY)
Team Role: Driver
Rookie Year: 1999
Ryan Curry is on a distinguished road
Send a message via AIM to Ryan Curry
I've had success putting a broken brush bat into the motors with some strong epoxy.
-Rc
Unread 25-01-2004, 09:00
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
As Ken has said earlier, a small tywrap works pretty well if all that is broken is the retaining tang. Make sure that the brush assy slides into place correctly and does not move around, then apply the tywrap around both brush assemblies directly behind the brushes. Don't forget that the fan end of the motor is the brush end. Don't cover the exhaust ports with the tywrap or the motor will overheat.
If the end assy is broken and the brushes do not align properly, there is virtually nothing you can do to fix this. Epoxy might make it ok to use on a proto robot or as an emergency spare. I wouldn't trust it for competition. I saw too many teams die in matches when their brush repair failed or the brushes fell out.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 25-01-2004, 11:12
SarahB's Avatar
SarahB SarahB is offline
SarahB has a spectacular aura aboutSarahB has a spectacular aura aboutSarahB has a spectacular aura about
Send a message via AIM to SarahB
-Rc
Actually, there wasn't any success. As soon as we removed the rubber band that held in the brush, it fell off. Thus we are now ordering a couple of replacement motors.
Unread 25-01-2004, 13:20
FRC #0030 (FURY)
Team Role: Driver
Rookie Year: 1999
I didn't mean that specific one, i ran out of epoxy before I could finish that job.
-Rc
Unread 29-01-2004, 00:37
#0634 (Robowolves)
Darn it - We broke a second one.....however we did invent a plactic insert that can hold everythng in place even when the locating surface is broken.
Coupling the drill motor with out the 15 tooth gear Chopper_Dave Motors 1 17-01-2004 01:06
Portable cordless drill press Gui Cavalcanti Technical Discussion 25 03-08-2003 22:21
drill motor mounts- again Jeff Sharpe Motors 6 07-04-2003 23:20
Emergency drill trade/sell Anarkissed General Forum 3 16-02-2003 22:37
"Motors and Drive train edition" of Fresh From the Forum Ken Leung CD Forum Support 6 29-01-2002 12:32
