Go to Post Although I've never oxy welded myself, I know it is doable - jamie_1930 [more]
Unread 25-01-2004, 00:24
mzitz2k's Avatar
mzitz2k mzitz2k is offline
Robotics Fiend
AKA: Matt Zitzmann
None #0302 (Mechanical Dragons)
Team Role: Student
mzitz2k will become famous soon enoughmzitz2k will become famous soon enough
Send a message via AIM to mzitz2k
Official Vertical Bar Ruling
So, I am asking this one last time. I know that this has been covered in a previous thread(s), but I just want to get clarification for myself and others. Is it legal to intentionally (by design) lean (not attach) to the vertical bar that supports the horizontal bar and still score the 50 points if the robot is truly SUPPORTED by the horizontal bar (not the platform)?
My judgement from the replies to the several questions posted on the US First Q&A System is:
As long as a robot is fully SUPPORTED by the horizontal bar in the y-axis (vertical) direction, then it will count. Also, the robot may not be attached to the vertical bar (because this would be SUPPORTING the robot in the y-axis). Also, if the robot is grabbing the horizontal bar from the carpet, it must be more than 12 inches off the carpet to count.
Is this interpretation correct? Thanks.
Matt
Team 302 - "The Mechanical Dragons"
Engineering Inspiration Award - Western Michigan Regional (2004)
Division Champions - Newton Division (2003)
Regional Champions - Great Lakes Regional (2003)
General Motors Industrial Design Award - Great Lakes Regional (2002)
Motorola Quality Award - Buckeye Regional (2002)
Regional Finalists - Buckeye Regional (2002)
Division Finalists - Newton Division (2001)
Regional Finalists - West Michigan Regional (2001)
Unread 25-01-2004, 00:43
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
Re: Official Vertical Bar Ruling
Why on earth would you EVER want to ask the users of ChiefDelphi for a ruling that may make or break your design? Youre asking for disaster. You dont want interpretations of rules. If Q&A answered questions werent clear enough, ask again in no uncertain terms.
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 25-01-2004, 02:17
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Rookie Year: 1999
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
SUPPORTED – If the “supporting object” is removed, the ball would not remain SCORED or CAPPED and/or the ROBOT would not remain HANGING.
HANGING – A ROBOT is considered HANGING from the Pull-Up Bar if it is directly SUPPORTED by the horizontal bar and is not touching the carpet, platforms, or goals.
If the side bar is not there, would your robot fall off?
If yes, then it is not supported.
If no, then it is supported.
It makes no mention of x-, y- or z-axis.
If it is not touching the carpet, platforms or goals, it is hanging.
Wetzel
Unread 25-01-2004, 15:36
Aidan F. Browne's Avatar Unsung FIRST Hero
Aidan F. Browne Aidan F. Browne is offline
Engineer
AKA: The Aidan-bot
Rookie Year: 1999
Aidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond repute
Note however, based on the definition of supported, that if the vertical bar were removed, and the robot would then come in contact with the Upper Deck, the robot would not count. So the greater than 12" interpretation was correct.
Aidan
Unread 25-01-2004, 20:35
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Rookie Year: 1996
dlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond repute
Cory is right. You are asking for a very specific technical interpretation of the rules. This forum, as good as it is, is not the right place to ask this type of question. CD cannot provide official answers, only the FIRST Q&A web site can. If you base your design on an answer that you receive here, and then implement a system based on that answer that runs afoul of the rules at the competitions, the judges/inspectors will not cut you any slack. Conversely, if you can show them an answer from that FIRST Q&A board that supports your design, then you are in good shape. if you don't feel that you are getting a complete answer on the FIRST system, then ask again and be sure to clearly, concisely state your real question (and where appropriate, clarify any "soft language" in a prior question that may have led to an unclear answer).
Both CD and the FIRST Q&A board are amazing resources and fonts of information. But please be sure to use them appropriately, and don't ask them to do things for which they were not designed.
-dave
"I know what you're thinking, punk," hissed Wordy Harry to his new editor, "you're thinking, 'Did he use six superfluous adjectives or only five?' - and to tell the truth, I forgot myself in all this excitement; but being as this is English, the most powerful language in the world, whose subtle nuances will blow your head clean off, you've got to ask yourself one question: 'Do I feel loquacious?' - well do you, punk?"
- Stuart Vasepuru, 2006 Bulwer-Lytton Fiction Contest
My OTHER CAR is still on Mars!!!
Unread 25-01-2004, 21:36
Stormhammer's Avatar
Stormhammer Stormhammer is offline
Team 1183
AKA: Justin
#1183 (Eagle Executioner's)
Team Role: Driver
Stormhammer can only hope to improve
Send a message via AIM to Stormhammer Send a message via Yahoo to Stormhammer
whoa whoa, wait... 12''?... like 1'?.... aw man...
1-2-3 EXE... prepare to be executed - Eagle Executioners ( no more Eagle Engineers ) #1183
Its either a Mopar or no car
Dude, WHY ARE YOU SO SLOW?!?!
Unread 26-01-2004, 10:54
mzitz2k's Avatar
Robotics Fiend
AKA: Matt Zitzmann
Team Role: Student
Thanks for your concern on my question, but I have already sent a question into FIRST. I have yet to get a response. I thought that it would be resonable to ask the CD Forum too. I would never (ever) design a robot from what CD users say - no offense should be taken, but (like you have said) FIRST has the final say when it comes to rules. I just wanted to ask the CD users that me and my team were not completely missing anything. I just wantd to see if my interpretation on this ruling was right. Thanks again for all of your support and help.
Team 302
Matt
Leaning against vertical bar 353Pobots Rules/Strategy 28 17-01-2004 19:52
Make the bar lower to get on? tkwetzel Rules/Strategy 28 12-01-2004 05:57
Vertical bar interaction Madison Rules/Strategy 5 10-01-2004 16:22
Team 68's REAL ROBOT!!! Alexander McGee Robot Showcase 137 25-02-2003 09:42
Official Forum frustration. Madison General Forum 9 01-02-2003 19:42
