Go to Post Oh... and congratulations FIRST, for launching the biggest shinny object of distraction just days before FRC kick-off. ;) - Michael Sperber [more]
Unread 25-01-2004, 16:13
Madison's Avatar
Madison Madison is online now
Dancing through life...
FRC #0488 (Xbot)
Rookie Year: 1999
Madison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond repute
Uneven Thrust Loads on Needle Roller Bearings
or "How I Need to Make A Turntable That Will Not Bind."
So, I am in the midst of designing a mechanism that rotates about a vertical axis and I'm worried that the enormous attached moment arm will cause binding in this vertical pivot joint.
McMaster-Carr shows needle roller bearings that are rated for 1900+ lbs. of thrust, but I assume that is assuming even thrust on the washers at each end of the bearing. How does an uneven load affect the performance of such bearings? Are they a viable solution for this problem, or is there some other method that's commonly used for supporting vertical axles under torque load?
Attached is a graphic and, by circumstance, a vague look at the arm design. I hope it makes my concerns clearer.
--Madison--
...down at the Ozdust!
Like a grand and miraculous spaceship, our planet has sailed through the universe of time. And for a brief moment, we have been among its many passengers.
