Go to Post The Manual is the "requirements document" for your project. - dlavery [more]
Unread 26-01-2004, 14:28
nzj1's Avatar
nzj1 nzj1 is offline
#0547 (F.E.A.R.)
nzj1 is an unknown quantity at this point
IR tracking
I was wondering if instead of tracking two IRs on the field if you could track one IR with two or three sensors on the robot and be just as effective?
Unread 26-01-2004, 14:54
mtrawls's Avatar
mtrawls mtrawls is offline
I am JVN! (John von Neumann)
#0122 (NASA Knights)
mtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to behold
Send a message via AIM to mtrawls
Re: IR tracking
I'm not sure if I understand what you are saying. The code at kevin.org/frc only tracks one IR beacon (either type-0 or type-1), and it uses four sensors, two on each servo. Is this what you mean by "tracking two IRs"? Also, you could use just "two or three" sensors -- but since they give us four, and code to use all four to boot, why not just use all four? If you don't entirely understand how the code operates, I recommend you look at it again, and also search around here in the programming forums, as there have been several threads about how the code works.
Unread 26-01-2004, 15:27
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: IR tracking
If you only track one beacon you can determine that you are located on a circle whose center is the beacon. With two sensors you can tell the distance to the center of the circle. Unfortunately you can't tell where on the circle you are without another reference of some sort. You would need to know where you started and how far and in what direction you travled since the start to be accurate.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 26-01-2004, 22:46
Oode Oode is offline
Oode is an unknown quantity at this point
Re: IR tracking
Or......
you can use the idea of a differential measurment.
TAke a snapshot of the 2 angles, go a known distance, then take another snapshot. That gives the third data point, and a "fix" of where you are.
Hmmmmm. interesting.
trouble with beacon tracking code [53] opticruzer Programming 9 27-01-2004 12:19
IR Tracking & Navigation Tallman General Forum 3 20-01-2004 17:26
File Sharing and Revision Tracking Madison FIRST-related Organizations 14 04-06-2003 18:01
Tracking Canadian teams at nationals! blueWarrior Championship Event 15 15-04-2003 21:03
Tracking Wetzel Championship Event 11 06-03-2002 18:18
