Go to Post FRC is a big tent. There's room for everybody. - Ether [more]
Unread 26-01-2004, 16:29
doy's Avatar
doy doy is offline
#1208 Ex-Lead Programmer
AKA: Jesse Luehrs
#1208 (The Super Critical Axe Men)
doy is on a distinguished road
Send a message via AIM to doy
ir beacon range
we have the beacon and receiver code running, and everything seems to be working fine - the beacon output looks correct on an oscilloscope, and the code is running without errors, but the problem we are having now is that the receiver is only recognizing the beacon if the beacon is held directly in front of the receiver at a maximum range of about 4 inches. this is using just the default code, modified so that the beacon and reciever can run on the same frc (we dont have an edu controller). has anyone else run into this problem? ive noticed that most people have been having the problem of their sensors being too sensitive, so i dont know what our problem might be.
Unread 26-01-2004, 17:23
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: ir beacon range
How did you construct your IR sensor housing?
e.g, is it exposed or in a tube?
Unread 26-01-2004, 19:54
doy's Avatar
doy doy is offline
AKA: Jesse Luehrs
Re: ir beacon range
right now both the beacon and the sensor circuits are mounted to separate breadboards for testing, both completely exposed... we havent permanently mounted anything yet.
Unread 26-01-2004, 21:49
Greg Ross's Avatar
Greg Ross Greg Ross is offline
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
Rookie Year: 1998
Greg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond repute
Send a message via AIM to Greg Ross Send a message via Yahoo to Greg Ross
Re: ir beacon range
My best guess is that, since your receivers are unshielded, they are being confused by all the IR signal reflections they are receiving.
Greg Ross (The Grammar Curmudgeon formerly known as gwross)
S/W Engineer, Team 330, the Beach 'Bots
<--The Grammar Curmudgeon loves this cartoon.
“Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming "Wow! What a Ride!" Hunter S. Thompson
"Playing a practical joke means doing something mean and calling it funny." Me
Unread 27-01-2004, 00:17
QueBall QueBall is offline
AKA: Steve Ashworth
#1086
QueBall is an unknown quantity at this point
Re: ir beacon range
Please go here for more detail:
http://kevin.org/frc/faq.html
Unread 27-01-2004, 01:16
Kevin Watson's Avatar
Kevin Watson Kevin Watson is offline
La Cañada High School
FRC #2429
Kevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond repute
Re: ir beacon range
As I haven't tried this configuration, I'd suggest sprinkling some debugging printf()s around your code to see what's happining within the Sensor_Stats array. I'd be particularly interested if the beacon data is being discarded because the pulses aren't within the type-0 or type-1 time windows. This would be indicated if Sensor_Stats[n].Invalid_Count was incrementing.
-Kevin
Kevin Watson
Engineer at stealth-mode startup
http://kevin.org
Unread 27-01-2004, 02:46
FRC #2429
Re: ir beacon range
Where in the circuit was the 'scope probe attached? The gate (pin 1 of Q1) or the LED? Did you see a five volt swing on the 'scope? Are you sure you built the beacon correctly (you should have swapped pins 2 and 3 of Q1 if you built it using FIRST's document)?
-Kevin
Kevin Watson
http://kevin.org
Unread 27-01-2004, 09:01
Just Itinerant
Re: ir beacon range
I have found the IR sensors to be susceptible to clutter from multiple modulated IR sources. The beacon waveform becomes obscured by all the noise. This could be the case with an unshrouded sensor and a beacon in a small room with lots of reflections.
Unread 27-01-2004, 11:37
cbolin's Avatar
cbolin cbolin is offline
Programming & Electrical
FRC #0342 (Burning Magnetos)
cbolin is a splendid one to beholdcbolin is a splendid one to beholdcbolin is a splendid one to beholdcbolin is a splendid one to beholdcbolin is a splendid one to beholdcbolin is a splendid one to beholdcbolin is a splendid one to behold
Re: ir beacon range
Hi,
We get strong and well-defined waveforms on the oscope at close ranges. At a farther distance, say 20 feet, we show occasional hits. We took a tube (an ink pen) to filter out a lot of ambient stuff.
Also, we used a digital camera set to night vision to view the LEDS. Really, really bright orb of IR light. Turn off the night vision, and we see only well defined glowing IR LEDs. We have to orient the IR beacon such that the IR sensor is pointed along the axis running from the top to the bottom of a particular LED. We have the beacon on a moveable cart which allows us to rotate it for maximum signal strength.
Are the beacons used in competion comprised of several LEDs or is it a single omni direction IR source?
Our scope probe connected between the 33 ohm and LED cathode.
Our students have mounted two sensor in tube housing on a support mounted to the servo. Tonight, they will experiment with code to move the servo left and right until IR is detected. We will not worry about which beacon we are looking at.
We will be able to use this rig to experiment with distance, IR shielding for the sensors, etc.
Regards,
Chuck
Unread 27-01-2004, 12:44
FRC #2429
Re: ir beacon range
Thanks for pointing this out. Yes, it's true that you should, with the exception of the little window, cover the sensor package with infrared opaque material (dark heat-shrink tubing works well) unless you want the beacon to be detected from behind the sensor as well. This is because the entire package is made of infrared-transparent epoxy that allows the infrared energy in from all angles, not just through the little hemisphere of a window. I've added this information to the FAQ.
-Kevin
Kevin Watson
http://kevin.org
Unread 29-01-2004, 16:46
doy's Avatar
doy doy is offline
AKA: Jesse Luehrs
Talking Re: ir beacon range
sweet... it just magically started working today... thanks for the help anyway(:
Official Beacon Tracking Code Posted Kevin Watson Programming 41 18-02-2004 21:04
edu and ir beacon alan koch Robotics Education and Curriculum 4 26-01-2004 22:43
Making a beacon indicator LED burn its brightest without burning out DanL Electrical 7 26-01-2004 08:05
IR Sensor Range Problems KBMSora Technical Discussion 3 19-01-2004 14:10
Optical range sensor Ben Mitchell Technical Discussion 9 12-01-2002 00:11
