Go to Post Come on, guys, it's two weeks 'til build. Personally, I'm gonna go outside for a little before I forget what my neighborhood looks like in the daylight. :) - Libby K [more]
Unread 26-01-2004, 22:18
dddriveman's Avatar
dddriveman dddriveman is offline
Former Driver 1038, 979
AKA: Driveman
FRC #1038 (Thunderhawks)
dddriveman has a spectacular aura aboutdddriveman has a spectacular aura about
Send a message via AIM to dddriveman
Angry 5/8 keyed shaft trouble
Our keyted shaft this year is exactly the right size but it will not fit into our bearings very easily w\o geting stuck. Any advice PLEASE HELP ME!!!!!!!!!!!!
bty: the size of the bearing opening is .623
and the shaft is .625
"I'm sorry, after all he is just a wookie!"
Unread 26-01-2004, 22:24
DaBruteForceGuy's Avatar
DaBruteForceGuy DaBruteForceGuy is offline
aKa - Steve Bennett
FRC #0125 (NUtrons)
DaBruteForceGuy is an unknown quantity at this point
Send a message via AIM to DaBruteForceGuy
Re: 5/8 keyed shaft trouble
two things you could do... first is get yourself a 5/8 drill bit and bore out the bearing (fancy vice work if you are using a roller bearing)... also, the other side is to take some very fine grit sand paper and sand your shaft... be careful to do the whole shaft though so you may fit something the whole length up... grease her up and good luck to ya!
Team
810 > 2001-2005 - Student Founder
125 > Present - College Student
---The pessimist complains about the wind, the optimist hopes that the wind will change... the realist adjusts the sail.
***<Therapist> Tell me, is the glass half full or half empty?
***<Engineer> Neither, the glass is too big.---
....Uh, GO NUTRONS!
Unread 26-01-2004, 22:32
ShadowKnight's Avatar
ShadowKnight ShadowKnight is offline
FRC #1719 (Umbrella Corporation)
ShadowKnight has a spectacular aura aboutShadowKnight has a spectacular aura about
Aye, sandpaper most likely would most likely be your best bet. Hint on using it, roll the sandpapaer around the shaft so that you sand evenly the whole circumference of the shaft. It may take a while but it's easier than having to go out and shell out the bucks to purchase 5/8" shaft and have it machined and wait, or wait for keyed 5/8" shaft to come via mail. I hope that helps...God bless
Unread 26-01-2004, 22:38
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Liquid wrench makes things fit that seem like they won't. Give it a good soaking. Also, make sure that there aren't any burs on the shaft. I would not go boring your bearing.
Unread 26-01-2004, 22:49
aKa - Steve Bennett
FRC #0125 (NUtrons)
... yea come to think of it you're probabaly using a ball bearing and those really aren't the greatest things to be boring out. Brass bearing on the other hand are ok...
Team
....Uh, GO NUTRONS!
Unread 26-01-2004, 22:54
Unsung FIRST Hero
Ed Sparks Ed Sparks is offline
Engineer/Mentor/Inspector
AKA: FirstCadLibrary Guy, Inspector Dude
FRC #3959 (Formally with FRC-34)
Rookie Year: 1996
Ed Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond repute
Send a message via AIM to Ed Sparks Send a message via Yahoo to Ed Sparks
We gave up long ago trying to force fit those nice precision bearings on non-precision shafting. We now bite the bullet and order precision shafting (slightly undersized) from McMaster-Carr (see "Keyed Shafting"). The more force you apply in assembling these two parts, the greater the odds that you will have to dis-assemble these two parts at the worst possible time.
-or-
A lathe, some emery cloth, and time ................
Ed Sparks
MECH TECH FRC-3959
Unread 27-01-2004, 06:56
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Team Role: Coach
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
there was a post earlier stating that the 5/8 keyed shafts do not fit again this year that comes in the kit with the bearings.....
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 27-01-2004, 07:33
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
We have had good success chucking the shafts in a lathe, running at medium high speed and using a file. This will take off material faster than emery so check often with verniers or calipers. Stop when the bearings slide freely. This takes two passes as you swap ends of the shaft in the chuck.
Keep the file moving just like you were filing a stationary piece and clean the file frequently.
Andy Brockway
Team 716, The Who'sCTEKS
Unread 27-01-2004, 11:54
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Adam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to behold
Send a message via AIM to Adam Y.
The edges of the shaft could have be knurled. This usually happens when you drop the shaft on its end. When this happens the end actually mushrooms and becomes bigger. This results in a shaft that does not fit. Also, since your bearings are getting stuck on the shaft at certain areas that means the shaft has burs on it. Take a piece of emery cloth to it. Do not use sandpaper. That will make the problem worst. Also since emery cloth is designed to take material away from the shaft do not do it too much.
If either a public officer or any one else saw a person attempting to cross a bridge which had been ascertained to be unsafe, and there were no time to warn him of his danger, they might seize him and turn him back without any real infringement of his liberty; for liberty consists in doing what one desires, and he does not desire to fall into the river. -Mill
Unread 27-01-2004, 12:09
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
we had a similar problem with an OD ont firring into an ID we had 4 rookies with sandpaper for 3 hours to solve that problem,
Unread 27-01-2004, 17:04
Dick Linn's Avatar
Dick Linn Dick Linn is offline
no team (Synergy)
Dick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond repute
Send a message via AIM to Dick Linn
Our shaft was precisely at .6250 while the bearing holes are about .002 under. We're ordering another shaft from MSC (page 1802), which should be anywhere from -0.0005 to -0.0015 under. Hopefully we'll get one that's on the small side and won't have to sand much. I didn't check the McMaster-Carr equivalent to see what it's tolerances were.
BTW, a .002 press-fit isn't unusual but makes it a pain to get things in and out. In normal service, you wouldn't want the inner bearing race to start spinning on the shaft, or it could end up welded to the shaft.
Richard Linn
Proud father of Marine LCpl. Karl R. Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 28-01-2004, 10:33
Mr. Ivey's Avatar
Mr. Ivey Mr. Ivey is offline
Mark Ivey
AKA: Mark
Rookie Year: 2000
Mr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of light
Send a message via AIM to Mr. Ivey
They were made like that for a reason. Look at the shaft from last year, and look at this year's shaft. This year's shaft is a lot nicer, it's set like a gear shaft in a car or something to that extent. The reason it's so hard to get a bearing on there is because they need to be pressed on there by a bearing press, and pulled off by a bearing puller. You can get the puller at a NAPA or another auto shop. To press them, get a piece of soft wood and a big hammer. Find a work bench with a hole drilled in it that's bigger than the shaft, but smaller than the bearing, or something of the liking. Tap the shaft into the bearing using a rubber hammer until it's just fitted inside of the bearing. Then center the shaft and the bearing over the hole in the bench. Place the soft wood over the other end of the shaft (the one that's pointing up), then slowly drive the shaft through the bearing to a spot that you have marked. Be sure to hit the piece of wood exactly where the shaft is on the other side. Go very slow and be very exact. This is what I have done to get the bearings on, to get them off, I just get my puller out of my mechanics tools at home.
Hope that helps.
ivey
When you tell a student not to do it, you shouldn't do it. Or else you will wind up with a 3/8" drill bit in your finger... Like I did...
Unread 18-05-2004, 07:16
magnetnerd's Avatar
magnetnerd magnetnerd is offline
AKA: Brett
#1364 (RYOBI KMHS Robotics)
Team Role: Student
magnetnerd is on a distinguished road
Send a message via AIM to magnetnerd Send a message via Yahoo to magnetnerd
Our shaft seems to be a little bit on the small side...the bearings, gears, etc. slide on and off with ease. Last year our shaft was aluminum and we had steel gears, this year we're using steel shaft and steel gears. Any ideas on how to keep the bearings where they are?
Do not meddle in the affairs of nerds, for they are subtle and quick to anger.
Unread 18-05-2004, 09:03
Dick Linn's Avatar
no team (Synergy)
Originally Posted by magnetnerd
.... Any ideas on how to keep the bearings where they are?
We use shaft collars, which are readily available from MSC. Price is typically in the $1.50 - $4. range.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
  #15   Spotlight this post!
Unread 18-05-2004, 09:49
Ali Ahmed's Avatar
Ali Ahmed Ali Ahmed is online now
FRC #0004 (Team 4 ELEMENT)
Ali Ahmed is a splendid one to beholdAli Ahmed is a splendid one to beholdAli Ahmed is a splendid one to beholdAli Ahmed is a splendid one to beholdAli Ahmed is a splendid one to beholdAli Ahmed is a splendid one to beholdAli Ahmed is a splendid one to behold
If you have accsess to a lathe, put the shaft in there and take some fine sandpaper to it. We find that this works really well and it is better then having someone just sit there and sand becuase this will keep it nice and circular.
Student: Team 22
Mentor: Team 4
supplier for 5/8" shaft david.clark Kit & Additional Hardware 2 17-01-2004 18:13
Problem with 5/8 in. shaft in this years kit echos Kit & Additional Hardware 5 14-01-2004 21:21
Can you stop a pneumatic pump at half shaft mjt902 Pneumatics 16 06-02-2003 11:58
Need Help on Shaft Mounting... archiver 2001 3 23-06-2002 23:29
shaft drive Joseph F Technical Discussion 5 03-02-2002 17:51
