Didnt want to cross post, so if a mod believes this would be better in Programming/elsewhere, please let me know, or move it.
I have coded in my pressure sensor for everything as ordered, and technically, it should all work. The sensor returns a 1 to turn off, a 0 to turn on, and all works perfectly in that respect (ie, turns on when it reaches a certian pressure etc). My problem is this, the sensor turns off the pump at 80PSI, and turns it back on at 30PSI! I could have sworn it was supposed to be either 65/55 or 125/115, yet it does not! Is this a defective piece, or do i have something hooked up incorrectly? Thank you all, 219 |
| spike for pressure switch? | Rob Colatutto | Rules/Strategy | 4 | 23-02-2003 15:42 |
| pressure sensors | archiver | 2001 | 0 | 24-06-2002 02:15 |
| Need help with 255 Variable | Joseph F | Programming | 18 | 26-02-2002 14:49 |
| Error found in programming for the pump and pressure switch | sjharobotics | Programming | 4 | 06-02-2002 17:46 |
| Pneumatic pressure sensor | Curtis Williams | Pneumatics | 3 | 04-02-2002 20:09 |
