Go to Post "Your really pretty and I like your bot" - prettycolors91 [more]
Go Back   Chief Delphi > Technical > IT / Communications > 3D Animation and Competition
Unread 28-01-2004, 20:51
eNc eNc is offline
AKA: Andre
#0820 (Delta Tech)
eNc is an unknown quantity at this point
Send a message via MSN to eNc
Splines
hi,
i have an arc spleen and a line spleen i want to make the long (horizontally) which modifier must i use ?
Unread 29-01-2004, 01:22
Salik Syed Salik Syed is offline
FRC #0701 (RoboVikes)
Salik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud of
Send a message via AIM to Salik Syed
Re: Splines
Originally Posted by eNc
hi,
First off.... your question doesn't really make any sense. But i will try to infer what you are saying .... do you want to make them strech longer... you can just use non-uniform scale! i guess i am probably misunderstanding your question...clarify
Team 701
Unread 29-01-2004, 06:33
kcy88's Avatar
kcy88 kcy88 is offline
Animator
AKA: Kevin
FRC #0075 (Roboraiders)
kcy88 is a jewel in the roughkcy88 is a jewel in the roughkcy88 is a jewel in the rough
Send a message via ICQ to kcy88 Send a message via AIM to kcy88
Re: Splines
yea, i think he wants to make them longer. Just move the vertices.
Team 75 - Roboraiders
Hillsborough High School Robotics
2006 Boston Regional Autodesk Visualization Award
2006 Boston Regional Engineering Inspiration Award
2006 New Jersey Regional Engineering Inspiration Award
2005 New Jersey Regional Autodesk Visualization Award
2005 Duel on the Delware champions
2005 Brunswick Eruption 4 champions
Unread 29-01-2004, 10:40
Re: Splines
for the arc spleen if you want the same angle arc...don't move veertices or NU scale it will mess up the arc... i would say just type it in in the properties box how big you want it...altho you can get it pretty close just by drawing it
Team 701
Unread 29-01-2004, 15:34
Matt Hallock Matt Hallock is offline
#1188 (Oaktown Crewz)
Matt Hallock is on a distinguished road
Send a message via ICQ to Matt Hallock Send a message via AIM to Matt Hallock Send a message via Yahoo to Matt Hallock
Re: Splines
Just use non-uniform scale by selecting the object but do not go into the modifier properties and select segments and vertices.
Lead Animator for Donder-Kimball High School, team #1188.
Splines - Vertex # Jack 3D Animation and Competition 0 09-04-2003 21:19
Question about splines Daishichimaru 3D Animation and Competition 2 22-01-2003 09:20
Splines, terrain, and conformity Daishichimaru 3D Animation and Competition 1 06-02-2002 19:34
