Go to Post I have yet to see an error where disabling the watchdog was the correct decision. - EricVanWyk [more]
Unread 29-01-2004, 18:52
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Adam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to behold
Send a message via AIM to Adam Y.
Getting off CMT pulleys
Gosh darn it. I installed a CMT pulley and I did not know that it would be permamently stuck on the globe motor. Does anyone have any ideas of getting them off of the shaft?
If either a public officer or any one else saw a person attempting to cross a bridge which had been ascertained to be unsafe, and there were no time to warn him of his danger, they might seize him and turn him back without any real infringement of his liberty; for liberty consists in doing what one desires, and he does not desire to fall into the river. -Mill
Unread 29-01-2004, 19:12
Rickertsen2 Rickertsen2 is offline
Umm Errr...
None #1139 (Chamblee Gear Grinders)
Rickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant future
Send a message via AIM to Rickertsen2 Send a message via Yahoo to Rickertsen2
Re: Getting off CMT pulleys
What's a CMT pulley?
1139 Alumni
Unread 29-01-2004, 19:23
Adam Y.'s Avatar
Adam Y.
no team (?????)
They are just a pulley with a special hub that was in one of the robot kits.
Unread 29-01-2004, 21:59
Gary Bonner Gary Bonner is offline
FRC #3974
Rookie Year: 2000
Gary Bonner has a spectacular aura aboutGary Bonner has a spectacular aura about
If I recall correctly, putting the set screw in the other hole releases the hub if you didn't over torque the screw in the first place.
Unread 30-01-2004, 07:08
Jack21 Jack21 is offline
Jack21 is an unknown quantity at this point
you could try a small gear puller (common at most flea markets)
Inventor part -> 3ds max? DanL Inventor 7 12-12-2003 08:17
tool and part names angier314 Chit-Chat 0 23-04-2003 19:12
Can we use part of a container on our robot? Rick General Forum 1 10-02-2003 20:10
Can I reduce the number of similar part files? roknjohn Inventor 2 29-01-2003 21:36
team 497 needs a part Andrew Dahl General Forum 0 25-02-2002 13:22
