Go to Post Mr.Lavery You Make My Day - Rohith Surampudi [more]
Unread 30-01-2004, 01:01
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
pic: MVRT 115 El Toro 7 teaser
Unread 30-01-2004, 01:02
Rickertsen2 Rickertsen2 is offline
Umm Errr...
None #1139 (Chamblee Gear Grinders)
Rickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant future
Send a message via AIM to Rickertsen2 Send a message via Yahoo to Rickertsen2
Re: pic: MVRT 115 El Toro 7 teaser
Originally Posted by CD47-Bot
Thread created automatically to discuss this image in the Picture Gallery.
Niceee!!!! Planetary inside of the wheel?
1139 Alumni
Unread 30-01-2004, 01:06
activemx's Avatar
activemx activemx is offline
A M X
AKA: Akshay Dodeja
Rookie Year: 2000
activemx is a glorious beacon of lightactivemx is a glorious beacon of lightactivemx is a glorious beacon of lightactivemx is a glorious beacon of lightactivemx is a glorious beacon of light
Send a message via AIM to activemx Send a message via Yahoo to activemx
Well its more like the gearbox for the Drill inside the wheel.
2005 - Present - FIRST Volunteer(Inspector, Ref, Judge)
2000-2004 MVRT 115
Unread 30-01-2004, 14:57
Collin Fultz's Avatar
Collin Fultz Collin Fultz is offline
no team (IndianaFIRST)
Team Role: Leadership
Collin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond repute
is that for a crab-drive type of drive train?
Collin Fultz
Unread 30-01-2004, 15:10
Greg Needel's Avatar Unsung FIRST Hero
Greg Needel Greg Needel is offline
REVving up for a new season
FRC #2848 (All-sparks)
Greg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond repute
that is known as a planetary gear set where there are center shafts (sun gears) that connect to the outer gears (planets)
btw that drive looks really cool..what materials are the gears made out of(knowing that they will have to be robust to take the wearing that the wheels do)
also what are you guys using for out side material... I understand if you can't answer because it is only a teaser but i am looking forward to seeing those things up close and personal
Unread 30-01-2004, 16:24
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
Based on what Inventor colors certain materials, the gears are steel (pretty obvious) everything light gray is 6061 aluminum.
[edit] that doesnt look like a planetary gearbox. See the pictures of 258's swerve modules from last year. Im betting it's the same concept.
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 30-01-2004, 21:19
Veselin Kolev's Avatar
Veselin Kolev Veselin Kolev is offline
X51 Production Company PGM (TM)
Veselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond repute
Yup... its a really shiny design. I've got it in the shop and its... really shiny. Yea by the way I designed it. So... ask away about how it works. Yup... I didn't want it revealed.. but it got out. Have fun.
By the way, it costs 1600 bucks for all 4 modules, so we won't have anything else on our robot this year. Maybe a battery. Nope.
Yea just kidding. Just.. watch out.
[edit] By the way, this is the old design. As you can see, the wheel WAS made from 3 peices. Now... one. Yea... hogged out 1.5 inches of solid aluminum. By the way, to give you an idea of how big it is... the wheels are 6" diameter.
Unread 30-01-2004, 23:31
Cory
Well... team 258's design was huge and heavy, like 20 pounds per module. Also, this design is different because the motor and the wheel are on the same axis, and the gear reduction is INSIDE the hollow wheel. This makes for a very compact design, and actually very robust. Let me post some more pics, since the design has changed a bit.
Unread 31-01-2004, 00:08
Unsung FIRST Hero
Bill Gold Bill Gold is offline
Retired -- 2006
Rookie Year: 1999
Bill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond repute
Just for the record...
Our modules were heavy, but not that heavy. They could have been extremely light if we had done some simple machining on the gears, and used different brackets to mount the modules. The drill assemblies were about 10lbs (including the vertical shaft, aluminum washer, mounting bracket, and sprocket) and the CIM assemblies were 12-ish lbs. Our sweep diameter was quite small, too (about 6.8" for the drill module, and 8.5" for the CIM module). Our sweep diameters could have been even smaller had we not designed to fit under the 14" bar.
Also, having the wheel and the motor share centers doesn't necessarily make your module's sweep diameter small, especially when you're talking about a module for the CIM motor. What makes the sweep diameter small is trying to place the midpoint of the length of the motor and geartrain directly over the pivot point of the module. If you don't do that, you're already behind the game when it comes to conserving space. I don't mean to say that you're not significantly cutting down the sweep. It looks nice.
Veselin,
I'm curious as to what pitch gears you're using in your assemblies. We used 20DP gears, except for a 0.7M gear that mated with the drill motor pinion. I don't really have a reference point, but it looks like you're using 24DP or smaller gears. Looks nice Veselin. I'm looking forward to seeing it at events .
Unread 31-01-2004, 00:30
[/quote]
Veselin,
I'm curious as to what pitch gears you're using in your assemblies. We used 20DP gears, except for a 0.7M gear that mated with the drill motor pinion. I don't really have a reference point, but it looks like you're using 24DP or smaller gears. Looks nice Veselin. I'm looking forward to seeing it at events .[/quote]
Gear reduction for the CIMs is 20 pitch, and for the drills its all .7 mod. Boy what a pain it was to get those gears!!! Yea... mostly aluminum, except for the shaft the whole thing rests on.. thats steel. Gears too...
So yea, its a really nasty, but cool, design. We're geared to go about 10 ft/s, so we're fairly fast. The machining was really crazy though. As I said, the wheels are made of solid blocks of aluminum. Most of the parts needed to be CNCed. So, see you all at the competitions.
Any more questions, I practically live here.
Unread 31-01-2004, 00:53
Rob Colatutto's Avatar
Rob Colatutto Rob Colatutto is offline
Roboticsrob
FTC #10092 (Green.Griffins;)
Rob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to behold
I'm curious as to what you guys chose your main strategy goals to be this year that you feel swerve is nessesary. Yes its a great for added mobility, but is the weight and complexity, and not to mention at least one other motor to turn them really worth it for you guys? If you don't want to discuss your strategy that's fine, just pointing out that if you have the ability to build something, it doesn't mean you always should.
That aside, does your new design with the wheels from a single round of aluminum still have the reductions inside of the wheel or have they moved outside?
Follow me on twitter @roboticsrob and my FTC team @griffins10092
Unread 31-01-2004, 13:48
Oh yea... we hollowed out this enormous block, so it still looks very much the same. Just less bolts to hold it together. But yea... I don't think that we really NEED swivel. You never need anything truly, you could always use the drill motors provided by FIRST. Swivel drive might come out to be useful in this year's game. You never really know how the game will be played out. Our team voted for swivel, so now we have swivel. For me, its just a design challenge. I find more satisfaction in building the robot than winning with it. Hey, thats just me. I don't represent my team too well hahaha.
And by the way on the issue of weight, the drill module is 6 pounds, the CIM is 7.5 pounds. Not too heavy I would say.
Unread 02-02-2004, 05:43
Ken Leung's Avatar Unsung FIRST Hero
Ken Leung Ken Leung is offline
Dare to Live!
FRC #0115 (Monta Vista Robotics Team)
Rookie Year: 1999
Ken Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond repute
Send a message via AIM to Ken Leung
I think that's a really great reason to build this drive system. I am very proud of how you guys challenge yourself every year with something new on the robot. I remember at 01 it was the auto-balance code, 02 was the 4 motor drive system, and 03 was the stacker. I cannot wait to see this drive system from one of the best robot builders in the Bay Area. Very cool! Be sure to post real pictures as soon as possible.
Hardware Test Engineer supporting RE<C, Google.
1999-2001: Team 192 Gunn Robotics Team
2001-2002: Team 100, 192, 258, 419
2002-2004: Western Region Robotics Forum, Score Keeper @ Sac, Az, SVR, SC, CE, IRI, CalGames
2003-2004, 2006-2007: California Robot Games Manager
2008: MC in training @ Sac, CalGames
2009: Master of Ceremony @ Sac, CalGames
2010: GA in training @ SVR, Sac.
2010-2011: Mechanical Mentor, Team 115 MVRT
~ * MVRT 115 Steals STACKs *~ VIDEO ~* activemx Robot Showcase 3 02-04-2003 10:15
Team 115 - El Toro 6 activemx Robot Showcase 3 23-02-2003 15:45
Image Discuss: Team 115 - El Toro 6 securing boxes CD47-Bot Robot Showcase 2 19-02-2003 16:36
Image Discuss: MVRT 115 Teaser 1 CD47-Bot Extra Discussion 2 02-02-2003 22:19
Team 115 Monta Vista El Toro IV archiver 2001 1 24-06-2002 01:15
