New Exec Summary Form
Be advised, update 6 includes info about a revised executive summary form. Be sure to use the new form. Good luck.
Re: New Exec Summary Form
Is anyone else having a problem editing the new form? I can open it in Adobe Reader 6.0 but when I try and type something into the form fields, I get the error message saying I can't save it (which means we can't submit it along with our Chairman's Award Word document). The FIRST web site indicates that it should be editable using Adobe Reader 5.0. I can edit and save it using Adobe Acrobat 5.0 (which I have on my PC at work).
The Adobe web site indicates that the "Not Allowed" security settings must be changed in the "Change the Document" area but I don't think I can do that. Am I doing something wrong? |
I'd ask in the Q&A and email FIRSTR at frcteams@usfirst.org
We have a full version of Adobe Acrobat, but I do not know of a version of just Acrobat Reader that can actually edit and change a file. I could be wrong, but I don't think I am. |
I had the same problem today. I just updated Adobe to 5.0 and when I tried to save it, I got the message that said I couldn't save it because I needed the full version. I'm currently talking to my IT support at work to see if I can get the "full version." If not, I'm in the same boat and won't be able to submit my Chairman's application either.
As suggested, I e-mailed FIRST and posted a question to the Q&A. I will let you know what I hear back.
In reader you should be able to use the text tool to select, copy the form from the .pdf file and paste in all into a blank Word Document and then save it as a .doc. I'd test that out and if it works for you, directly ask in the Q&A and email if that's acceptable.
FIRST is recognizing the problems we are having and have posted the following on their website, "We are currently working to resolve the problems encountered with the Executive Summary Form. A new form will be in place shortly. Thank you for your patience."
"Change the document" is not available in the reader. It's only available in the full version. This is the same problem people had when FIRST released the 2004 manual. If you only have the reader and downloaded the password protected manual you had to type in the password everytime because you can't change the document and remove the password. This is why most people downloaded the manual again after they posted the nonpassword version. It would inhale audibly for FIRST to require people to purchase the full version to submit the Chairman's application.
I just opened the Exec Summary Form and it did not come up as a pdf which is good. Do we copy it and submit it as page 5 of the chairman's entry or do we attach it when we send in the 4 pages. Anyone know??
Shawn |
#10
You would send it in as separate attachment.
#11
Our executive summary will probably get tweaked a bit more, but you get the idea.
| Chairman's Award Executive Summary | Jacqui Sutton | Chairman's Award | 26 | 07-02-2003 14:20 |
| Custom Pneumatics order form | Andrew Schuetze | Kit & Additional Hardware | 1 | 10-01-2003 20:34 |
| Yet another time limit question (about exec summary) | Caroline | Chairman's Award | 1 | 06-02-2002 17:14 |
| Competition Detail Summary | kmcclary | Off-Season Events | 3 | 15-11-2001 11:30 |
| Weekly summary | David Kelly | CD Forum Support | 2 | 29-06-2001 11:30 |
