Go to Post Don't be affraid of trying new things... Even if people say you are crazy, even if you get insulted, even if it involves a lot of time and money, try it. You can't know if it'll work or not if you didn't try it yet. - EDesbiens [more]
Unread 31-01-2004, 12:43
Mercutio Mercutio is offline
Atticus Finch Wannabe
#1213 (The Grobots)
Mercutio is on a distinguished road
More than two air tanks?
We've been in FIRST for two years, so we have four pneumatic accumulator tanks -- one set from this year and one set from last year. In the rules, it says that "there is no limit to the number of solenoid valves, air cylinders, and connecting fittings you may use on your robot," but it also says that "the pneumatic system uses compressed air from a 12V DC powered compressor that discharges into two air storage tanks." Are we allowed to use more than two tanks on our robot? I don't think there would be a safety concern, since all the pressures in the system would remain the same.
~Aaron
"If we knew what we were doing, it wouldn't be called research, would it?"
—Albert Einstein
<X3 What can I do? You broke the tie wraps that were holding together my heart. ^_^
Use of tanks from prior years. Alex N. Pneumatics 6 13-01-2004 22:19
Where to get air muslce pneumatics? Adam Y. Pneumatics 5 27-12-2003 23:17
Pneumatics and last year's storage tanks Darwin695 Pneumatics 3 04-02-2003 02:13
What are pneumatics? Aignam Pneumatics 23 16-10-2002 21:17
Air Fare to Florida archiver 2000 0 23-06-2002 22:16
