Go to Post Now, FIRST has taken over my life (and my harddrive)! - Kate00 [more]
Unread 12-02-2002, 16:02
Brett W Brett W is offline
#0843 (WYVERNS)
Brett W is on a distinguished road
Why?
Why do no teams use the fisher price motors is there something wrong with them? Are they not reliable? Do they Break? Are there lots of teams who use them and just post no pictures? These answers would be greatly appreciated.
Brett
Unread 12-02-2002, 16:33
Kris Verdeyen's Avatar
Kris Verdeyen Kris Verdeyen is offline
LSR Emcee/Alamo Game Announcer
FRC #0118 (Robonauts)
Kris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond repute
We used the FP motors on last year's robot to control a 2 DOF arm with a goal grabber on the end.
I think that they are good, moderately torquey motors that are fine as long as you're not planning on jarring the output really hard (i.e. running into a wall while using it on a drivetrain). The weak point is the plastic geartrain.
Although I have heard some venom concerning these motors. Let's see what some of the FP haters have to say. (Personally, I just think that they're jealous of Barbie's pink corvette)
...Only a few people are awake and they live in a state of constant total amazement. -JP Shanley, Joe vs. the Volcano
Unread 12-02-2002, 16:38
jonathan lall's Avatar
jonathan lall jonathan lall is offline
FRC #2505 (The Electric Sheep; FRC #0188 alumnus)
jonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond repute
Send a message via MSN to jonathan lall
We've messed around with them fairly extensively, and they're not as horrible as you may have been led to believe. I've been told that even though they are torquey, they have parts that get damaged from wear. However, I suggest you post this question at firstcanadianregional.org, for a better answer.
Unread 12-02-2002, 17:12
AdamT's Avatar
AdamT AdamT is offline
#0401
Rookie Year: 2000
AdamT is on a distinguished road
We are using them, they seem to work well when powering a spindle. It's hard to find a use for a motor designed to pull a 6 year old around when it's going on a 130 pound bot. Our use sems to work.
~Adam
Unread 12-02-2002, 19:02
Elgin Clock's Avatar
Elgin Clock Elgin Clock is offline
updates this status less than FB!
AKA: the one who "will break into your thoughts..."
FRC #0237 (Black Magic)
Elgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond repute
Send a message via AIM to Elgin Clock
Transmission problems
The transmission is just too bulky!
The influence of many leads to the individuality of one. - E.C.C. (That's me!!)
Unread 12-02-2002, 19:18
bmusser bmusser is offline
Brian Musser
FRC #1504 (Desperate Penguins)
Rookie Year: 2000
bmusser has a spectacular aura aboutbmusser has a spectacular aura aboutbmusser has a spectacular aura about
Wink FPs aren't bad
We are using the FPs for drivetrain, but do not use the gear box. We come straight off the pinion gear that is pressed onto the motor shaft.
Unread 12-02-2002, 19:41
Ken Leung's Avatar Unsung FIRST Hero
Ken Leung Ken Leung is offline
Dare to Live!
FRC #0115 (Monta Vista Robotics Team)
Rookie Year: 1999
Ken Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond repute
Send a message via AIM to Ken Leung
They get hot easily
The only down side about the F-P motor is that it tend to get hot really fast. Just look at the size of it, and think about how much surface area for heat to excape.
Besides, people tend to use the gearbox that came with the motor, and the plastic gears inside that gearbox tend to break under high load. Although, that won't happen too easily if you use it right.
A lot of team use the drill motor because they want to use the drill transmission to shift gears, which is pretty easy to do with a servo or pneumatics, whereas the fisher price will need a custom gear shifter.
Over all, Drills and Chiaphua's are still the most powerful motors in the collection. They can take the heat better than the FP, so why not let them be the toasters, and have the FP power a really strong arm or a high speed ball mechanism.
Unread 13-02-2002, 13:00
AAbrams AAbrams is offline
#0393 (Full Metal Jackets)
AAbrams is an unknown quantity at this point
Talking
We used them last year on "SPYKE" our robot. You can see them on each of the sides. It had great pulling/pushing power. We would put people on the stretcher and take them up and down on the ramp last year. We would use them again this year but we want to be quicker. And we put some heat sinks on them with fan to keep them cool.
http://www.geocities.com/mhsfullmetaljackets/spyke.html
Tony
Captain 393
Unread 13-02-2002, 14:20
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Rookie Year: 2000
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
We are using both of them this year. They will be operating our arm. One for raising/lowering the upper arm and one for raising/lowering the fore arm. We built custom made gear boxes. You can see the gear box in the Picture Gallery.
Wayne Doenges
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 13-02-2002, 15:14
ChrisH's Avatar Unsung FIRST Hero
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Rookie Year: 1998
ChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond repute
We've used the FP's with gearbox every year since they were introduced. But we don't drive with them. They make a terriffic winch. Just mount the motor and run your cable. Of course the cabling is the hard part...
Christopher H Husmann, PE
"Who is John Galt?"
Unread 14-02-2002, 00:09
Don Taylor Don Taylor is offline
#0343 (Metal in Motion)
Don Taylor is an unknown quantity at this point
We use them and like them, a lot of torque, decent transmission, etc.
Don
Team 343
Metal in Motion
Unread 18-02-2002, 01:31
roboticscom13's Avatar
roboticscom13 roboticscom13 is offline
Rookie Year: 2000
roboticscom13 is an unknown quantity at this point
For the third year in a row, we are using the FP motors as drive motors, however this year we took off the custom gearbox and attached the end of the FP motors to the drill motor with a custom made cuppling design.
They are working as well as they did the other two years. The only thing is, is that like it was alreeady mentioned those motors do get hot quickly so if you do go with them do keep an eye on it.
Unread 26-02-2002, 03:46
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Rookie Year: 1999
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
We have one powering our superscooper!.
Viva Olancho!
Unread 13-03-2002, 15:54
Perseus's Avatar
Perseus Perseus is offline
Takin' a Break from FIRST
Perseus is an unknown quantity at this point
We used the FIsher price motors(with two Bosh's) on our drive for our 1st two years. This year, we are using the two bosh's and the two chiaphus. I think the reason most teams are not using the FP motors is because the chiaphus are, in my opinion, better. They have better rpms, i believe 15000 (boshes are 20000). We do use the FP though; for our device that goes to the endzone
The Few
The Proud
The Zoroastrians
  #15   Spotlight this post!
Unread 13-03-2002, 22:07
hemihead hemihead is offline
#0086 (Team Resistance)
hemihead is an unknown quantity at this point
FP Motor use
FP motors are great...when used inside of their , er, design envelope.
Inside of the envelope (for Team 86) means elimninating the last stage of gear reduction, making a steel hub for the second-to-last stage gear, and taking off power at a really useful RPM with a stub shaft. The sped is very close to the drill motor output shaft in low range. We have successfully used a FP and Drill motor chained in parallel.....very nice, very easy, very simple.
Motors that overheat are most likely being run way below their peak power and efficiency points. Close to stall speed always means heat.
Our only FP failures have been due to 1.) Driving off the bridge full throttle and pancaking onto the rug....major impact load on plastic gears. 2.)practice driving on asphalt where the same thing happens...wheel slip then grab impact loads the gearsets.
Knock on my head, no failures to date on the gearbox in competition. Did have a motor fail (smoke and stink and everything at 2002 KSC ....no motor autopsy results yet....I think it was a defect or fluke....it wasn't really being beaten on that hard when it failed.
