Go to Post You must wear safety glasses at all times, so please bring them. - Don Wright [more]
Unread 14-02-2004, 20:54
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
Re: Newbie Autonomous Question(s)
also, remember the built-in deadzone on the Victors, which is approximately 10 in either direction, so 117 and 137 are right on the edge of this deadzone - the robot is going to move almost not at all. i'd recommend something close to 150 and 100 or so at the least. your problem is probably that you're setting both of the motors inside the deadzone, so the robot doesn't move.
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 16-02-2004, 10:02
platt platt is offline
FRC #1345
platt is an unknown quantity at this point
hey i am a new team and i am i a great need is there a code for the stupid banner sensore some plz help
Unread 16-02-2004, 11:23
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Ryan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud of
What sort of code? I assume you mean line following or something similar. Do a search for banner or line or something like that. There's tons of stuff that has already been said about this sort of thing. If you can't find what you need, post again.
Unread 16-02-2004, 11:35
Phil_Lutz's Avatar
Phil_Lutz Phil_Lutz is offline
Phil Lutz
#0851 (Froggers)
Phil_Lutz is on a distinguished road
Send a message via Yahoo to Phil_Lutz
Originally Posted by Texan
Third, make the power that the motors are driven at a little higher. I'm not sure if your problem was that it wasn't moving, but the way it is now, it will either move really slow or not at all.
The Victor 884 speed controllers have a deadpan (no movement spot) between 117 and 137 with 127 as neutral. Therefore, you are not getting outside the speed controllers "don't move" range.
Increase the numbers to something like 90 and 164.
Phil
Unread 16-02-2004, 11:45
LBK Rules's Avatar
LBK Rules LBK Rules is offline
1467 '06 Alumni
AKA: Anthony Rinaldi
no team (HSRO)
LBK Rules will become famous soon enoughLBK Rules will become famous soon enough
Our Victors don't have a deadpan. going 107:147 makes our robot overshoot the line. (I thought the 883 had the deadpan, and not the 884.)
Our team has been trying to code the banners, and we just can't get it to work right.
If somebody can please post some working line fowolling code, I know all of us newbies woud greatly appreciate it.
Anthony Rinaldi
Team 1132: 2003
Team 1467: 2004 - 2006
Unread 16-02-2004, 11:51
Phil_Lutz's Avatar
Phil Lutz
#0851 (Froggers)
Are you using the 884's in the kit? They do have a deadpan.
Also, calibrate the Victors. This might be your problem.
Phil
Unread 16-02-2004, 13:47
Programming User
Well, I can't guarrantee this works, but if you want to look at it...
PHP Code:
// Check if the right sensor is reading the line
if(lineDetectorLeft == ON_LINE)
// Turn right
driveMotorLeft 127;
driveMotorRight 254;
else if(
lineDetectorRight == ON_LINE)
// Turn left
driveMotorLeft 254;
driveMotorRight 127;
else
// Go forward
driveMotorLeft 254;
Subsitute pwmXX for the driveMotorLeft and Rights, the lineDetectorLeft and Rights with the digital inputs they are on, and the ON_LINEs with the value that the sensors read when over the line. This is a very simple algorithm and can be improved, but it gives you the idea. Put it in its own function and continually call it and it will (should) faithfully follow a line.
--EDIT--
You can also adjust the speeds passed to the motors. The way it is now, it might lose the line because it is too fast.
A better autonomous method.. randomperson Programming 4 24-02-2004 18:02
Initializing autonomous mode Mr. Lim Programming 7 02-02-2004 07:26
variable? manodrum Programming 11 01-04-2003 17:20
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
Autonomous Kill Switch UCGL_Guy Programming 8 15-01-2003 17:39
