Go to Post We honor those who are unsung - those without a trophy or a plaque to show their efforts. Those who may or may not get those things... but will still be on the sidelines, helping to guide FIRST in all the right directions. - Amanda Morrison [more]
Unread 02-02-2004, 14:29
Astronouth7303's Avatar
Astronouth7303 Astronouth7303 is offline
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Astronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud of
OI and analog: Zero value
Get this: no joystick (infinate resistance, no voltage) has a value of 127.
Now take a potentiometer and wire it to a analog port. Turn it all the down.
It will read: 127, 0, ..., 127, ..., 255. A little heads up! Or is this unusual?
Unread 02-02-2004, 16:00
Dave Flowerday Dave Flowerday is offline
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Dave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond repute
Re: OI and analog: Zero value
It sounds like you connected ground to one side of your pot and +5 to the other. If so, you're supposed to leave the "ground" side unconnected. This is explained on page 5 of the FRC OI guide at IFI's site. From that document, "In the event that an analog input is less than 0.05V, a value of 127 will be generated." This is on purpose so that if nothing is connected to a joystick port, an internal pulldown resistor in the OI will pull the analog pins down to 0 volts and the OI software will translate that to 127. This way, if you accidentally unplug your drive joystick (for example), your robot won't start running full tilt backwards!
